Boost issues. - The Saab Link Forums
Old 10-29-2007, 07:17 PM   #1
NahumCC's Avatar
Boost issues.
Seems since getting the viggen core on other day all I've done is re-assemble the cold side hose constantly. Bought some T-clamps today for where I have the extension done and am slowly getting pushed to picking up 2 more t-clamps for the cold side of the intercooler and the delivery pipe. I believe that is where an issue I recorded on my phone is occuring in that I'm seeing constantly waving boost around part throttle.
Another problem has been that when I floor it in one gear it'll have full 18-20psi and then I'll shift and have 15, shift again and be down to 10. This never happend on the dual pass so this further adds to my losing boost on the intercooler plumbing.
However one fun video for the night. 27psi SPIKE. God I love T5 in cold weather.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 12:52 AM   #2
BPC valve needs cleaning and or BOV is leaking. Hell, I would even check the waste gate for spring resistance.
93nut is offline
Old 10-30-2007, 03:20 AM   #3
NahumCC's Avatar
No way my forge valve is leaking. I installed the next spring up when I put in this ECU so at 10 psi where thats happening it will deffinitely be shut.
I'll clean the BPC and see what happens. I also know where I can pick up a nice shiny forge actuator second hand.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 03:26 AM   #4
mcrowley's Avatar
The spike sure makes it sound like you've got a bpc issue.
Last time I had one go bad it did similar stuff to what you're describing.
I wouldn't waste your $ on a Forge actuator just yet.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-30-2007, 07:09 AM   #5
NahumCC's Avatar
Thanks Mcrowley. I have the hook up for 100 if I want it, i just have to call the guy but I'm not gonna get it for now. Picked up 2 more constant torque clamps and will make sure that there is no leak and clean the bpc and see how it goes.
I had to watch the guy with the viggen in town today go the other direction and I so wanted to turn around and play.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 07:15 AM   #6
moose's Avatar
ya something is definitley wrong cause i make more boost with my T25 and it holds to 5500.
undercover Moderator
Stg. no go
moose is offline
Old 10-30-2007, 07:19 AM   #7
mcrowley's Avatar
What Forge valve do you have? How many miles on it?
If its been around for awhile, take it apart, check the o-rings and re-grease.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-30-2007, 09:24 AM   #8
NahumCC's Avatar
Had the valve for a year. Had it apart back in September when I got the ECU from JAK and all looked good. I have the dual piston BOV that Nick carries.
Also, what is the proper method for cleaning a BPC valve? I know to use something like wd-40 or PB blaster but would brake parts cleaner be ok (all I have right now). I know you just squirt it in there but is there anything else to it. If this doesn't clear up the issue I'm gonna rig the car to run base boost and disconnect the BPC until I order a new one to protect the MOSFETS in the ECU.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 10:38 AM   #9
mcrowley's Avatar
Get some electric parts cleaner from an auto parts store or radio shack, etc. I got some stuff that was made specifically for cleaning solenoids (what the bpc is) that dries w/o leaving any kind of residue.
You can also try something as simple as compressed air and that may do the trick.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-30-2007, 10:39 AM   #10
NahumCC's Avatar
Thanks.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 03:18 PM   #11
NahumCC's Avatar
Cleaned out the BPC and got my other 2 constant torque clamps on. Still had the same problem and was beggining to see clutch slip happen.....:sigh:. I knew it was coming sooner or later. 140k, original clutch, twice the amount of boost.
My car is now rigged to run in base boost and even though its baseboost is 7 psi +/-.5 psi I was able to watch it run up to 10 psi at 4000 rpm.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 03:24 PM   #12
drewz airflow se's Avatar
Spec time!
^CLICK ME^
drewz airflow se is offline
Old 10-30-2007, 04:16 PM   #13
NahumCC's Avatar
Originally Posted by drewz airflow se View Post
Spec time!
Yeah.........don't know how I'm gonna swing it. Would rather not have to extend my loan on the car. I'll eventually break the news to mom and dad and see what I can get.
Oh well new BPC, slave cylinder, viggen pressure plate, spec disc, spec billet flywheel. I'd say thats a pretty healthy xmas wish list.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 04:17 PM   #14
Damn that flywheel gives me saab wood.
^CLICK ME^
Old 10-30-2007, 05:03 PM   #15
JK
JK's Avatar
Spoiled?
I wish someone else would pay for my car toys.
SRSLY though, getting clutch slip for the 1st time is kind of a bittersweet feeling. I was a little pumped because I knew I was making quite a bit of power to get a nearly brand new clutch to slip without a tuned ECU.
Anyway, save you pennies...er, tell your parents to.
always a SAAB guy at heart
JK is offline
Old 10-30-2007, 05:39 PM   #16
NahumCC's Avatar
Originally Posted by JK View Post
Spoiled?
Actually JK my parents really don't help out with my car. Every now and then they might help me with a big repair but that usually means I'm doing some major work around the house when I'm home and other tasks. It's a fair trade but my parents also know that I do quite a bit of work on my own car and there cars as well when I'm home and something is wrong so it really does even itself out.
In the meantime I'll start saving and will probably make a trip of it to Nick's shop again to make sure it gets done right whether I'm helping out or not. For something this big I'm not gonna risk leaving my car stranded with no mechanic competent in my opinion around here with my car.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 05:40 PM   #17
mcrowley's Avatar
Clutch slip happens.
Don't act so surprised
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-30-2007, 05:42 PM   #18
NahumCC's Avatar
I wasn't so much suprised as, "well looks like the intercooler and suspension just got pushed back."
2013 FR-S
NahumCC is offline
Old 10-30-2007, 05:46 PM   #19
mcrowley's Avatar
Yeah, it happens.
Don't put off replacing it at all if you can.
First sign of slip I changed mine.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-30-2007, 06:51 PM   #20
NahumCC's Avatar
Yeah, it happens.
Wish that was possible but its not. I'm gonna talk to my bank tomorrow before I talk to my parents.
2013 FR-S
NahumCC is offline
