Descreening the MAF? - The Saab Link Forums
Old 10-28-2007, 08:12 AM   #1
Legit's Avatar
Is it safe to do this?
2002 Viggen Convertible
Legit is offline
Old 10-28-2007, 08:26 AM   #2
Out of curiosity, will you see any sort of gain from it? Free mods aren't really worth it if you risk something that can be detrimental.
Topher is offline
Old 10-28-2007, 08:28 AM   #3
Legit's Avatar
Im getting a new MAF soon so ill see if it does anything. Think about it. The holes are tiny in the MAF so by taking it out, its less restrictive.
EDIT: If you think stuff will get in the engine from this, it would have already happened because the air filter actually filters the air, not the MAF, surprise!
Legit is offline
Old 10-28-2007, 09:07 AM   #4
saabkid37's Avatar
you will gain nothing imho.
saabkid37 is offline
Old 10-28-2007, 09:13 AM   #5
Legit's Avatar
Ill gain like +20whp + the drivetrain gain of 78%. That should put me at about 300whp.
Will it throw off the MAF?
Legit is offline
Old 10-28-2007, 09:15 AM   #6
90SPG's Avatar
Send a message via AIM to 90SPG
x2
I dont think it is worth the potential damage to the MAF.
By the same reasoning the air filter is the much bigger restriction than the screens of the MAF, I see no reason to mess with it and risk breaking something for a possible hp or two. I would say the biggest gain will be had when you swap in a brand new MAF or even cleaning your old one.
'90 900 SPG (RIP rust)
'86 900 SPG (DD)
'86 900S
"A car with an image so immaculate it can hold confession and communion."
90SPG is offline
Old 10-28-2007, 12:12 PM   #7
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
The only thing that the screen does is remove the turbulence from the airflow so the MAF can get an accurate reading. By removing it you make it so your MAF can not accurately gauge the amount of air entering your engine and it will throw your fueling off.
mlemorie is offline
Old 10-28-2007, 12:18 PM   #8
mcrowley's Avatar
Originally Posted by 90SPG View Post
x2
x3
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-28-2007, 12:40 PM   #9
Legit's Avatar
Thanks for the info
Legit is offline
Old 10-28-2007, 12:42 PM   #10
StX221's Avatar
This has bad news written all over it if you pull that screen.
In addition to smoothing the airflow, I must assume that it is also there to prevent something from hitting the tiny sensors that pick up all that fancy information that makes your car run nicely
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 10-28-2007, 01:18 PM   #11
Legit's Avatar
Thats why ill try it when I get my new MAF
Legit is offline
Old 10-28-2007, 01:48 PM   #12
Deez Nutz
Palmer's Avatar
In the c900 world, you can remove the screen in the AMM...MAF to all you new car types. I did it to one of my AMM's and felt no difference.
If you have a leftover, might as well give it a shot. Just don't break the little tiny wires. Then it wont work at all...
S55/LC100/KL
Palmer is offline
Old 10-28-2007, 02:19 PM   #13
JK
JK's Avatar
My take - if there is no gain, and you risk damaging stuff, then why even consider doing it?
The screen is there for a reason. It does NOT prevent the car from making lots of horsepower (I'd be willing to bet that none of the higher powered T7 cars on this forum took out the MAF grid) then it is NOT a good idea.
It's not a way to make power, only a way to risk having the sensor misread, or risk damaging the sensor when removing it.
Don't do it, just buy a tune instead.
always a SAAB guy at heart
JK is offline
Old 10-28-2007, 02:32 PM   #14
Legit's Avatar
Ok thanks, I dont think ill be doing this. I read on some VW and Chevy forums that they noticed a gain after performing the "operation".
Legit is offline
Old 10-28-2007, 02:45 PM   #15
90SPG's Avatar
I've always wondered if those screens are put in to evenly regulate the flow of air and not there to act as a filter. I would be afraid of doing anything to disrupt what goes on inside the MAF.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 10-28-2007, 04:12 PM   #16
JK
JK's Avatar
I don't think they're there to stop shot from getting in the MAF. Think about it, although small, the holes are definatly large enough to a particle though, while in operation, to damage the wires.
I think they are either there to even out the airflow, or they are there to keep the unit from being damaged while out of the car (sitting on a parts shelf, while being installed in the car, during shipping, etc.)
Its just a good idea to leave 'em in. If you want some real gains get a turbonator.
JK is offline
Old 10-28-2007, 04:43 PM   #17
Its a common free mod in the turbo buick community, but they have 2 and I think only remove the 1. How many do T7 cars have? (screens)
Old 10-28-2007, 05:25 PM   #18
Deez Nutz
Palmer's Avatar
T-7 has screen in the MAF, and down in the throttle body.
S55/LC100/KL
Palmer is offline
Old 10-28-2007, 10:38 PM   #19
Adrenaline406's Avatar
Some of those cars have much larger much thinker screens, i had a guy bring in his from an old buick i believe, the thing was about 1.5 inches deep (3-4cm)
I would say that you could take out one safely if you felt like it.
I'd say theres no issue removing grid 1 because if you keep an air filter on as long as the car is on, you have a sealed environment that should protect the sensor.
The other side though is not so good, if you turbo decides to go south, then you might have some stuff coming back up that pipe destroying the sensor.
(yes, sometimes i have this kind of time...)
Adrenaline406 is offline
Old 10-29-2007, 05:29 AM   #20
Trollerator
abdukted1456's Avatar
Bad Idea. this is a very crucial sensor and you risk ruining the calibration and how it works. it's made to work WITH a screen.
get a downpipe.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
