Lightweight 16" rims - The Saab Link Forums
Old 10-12-2007, 05:50 AM   #1
8valvegrowl's Avatar
What are peoples thoughts? Any experiences? After autocrossing my Sport Edition F2's and my Klingons I've decided I need a lighter wheel (although the Klingons feel about 2 lbs lighter than the F2's).
I also want to go a slightly smaller diameter overall (cheaper tires, slightly shorter gearing effect)
What's the lightest Saab factory 16" wheel?
I like both of these aesthetically speaking....especially the second set.
I don't think I've ever seen these latter pair on a car before...nice looking though...aftermarket fitments are hard to find, and the offsets are usually not stellar for a lowered car...weight is the most key thing though....My F2's weigh about 22lbs a piece....I'd like more like 18-20 lbs I think (less would be great, but I can't afford Volks, gramlights or SSR's....not that they make Saab fitments anyway)
8valvegrowl is offline
Old 10-12-2007, 05:53 AM   #2
NickTurbo900's Avatar
I can weigh the first 'Arc' wheel tonight, but it will have an all season on it.
ASA? Cheap and light I think.
SSR makes a 5 x 110.
NickTurbo900 is offline
Old 10-12-2007, 06:08 AM   #3
Hey, thanks for checking that out...tires generally add 20-25 pounds...if you note the tire model I'm sure I could find a weight for it....
ASA's are decently light...19.5 lbs for the 16" EM9. I'm just wondering if I could get pick up some stock wheels that weren't in the prettiest condition when someone upgrades. I'm trying to do this on the cheap...
I still haven't found any SSR's in 5 x 110...but even if I did, they are way out of my price range right now.
Old 10-12-2007, 06:17 AM   #4
The tire is a Yokohama Avid A/S in the standard Arc size.
Its on my car that my GF took to work.
Old 10-12-2007, 06:19 AM   #5
Sweet, I appreciate it...
Old 10-12-2007, 06:24 AM   #6
5x112 will fit also. I am running 5x112s on my 02 93 with no adapters and original wheel bolts. I hope this helps you find a bigger selection of rims.
93nut is offline
Old 10-12-2007, 06:26 AM   #7
Saab doesn't make any wheels that are particuliarly light. I have seen 16" BBS RK1's on Saabs. Thats as close to OEM and light as you are going to get as they likely weight about 15-16.5lbs each.
Jameson is offline
Old 10-12-2007, 06:42 AM   #8
JK
JK's Avatar
I have a set of Arc wheels without tires that I can put on my scale this weekend.
always a SAAB guy at heart
JK is offline
Old 10-12-2007, 06:56 AM   #9
$5 says they are over about 20-23lbs.
Jameson is offline
Old 10-12-2007, 08:02 AM   #10
The Yoko AVIDs weigh 24 lbs.
The Klingons seem lighter than I'd expected. I'm not looking for superlight wheels....just as light as I can find with stock fitments.
My Sport Edition F2's are heavy...some may be due to tire weight...I need to find out what the two different Sumitomos I have weigh....
Old 10-12-2007, 08:22 AM   #11
So the Klingons are definitely lighter than the F2's...the tires on the F2's weigh 21.7 lbs, the tires on teh Klingons weigh 21.8 pounds (pretty light for a 225....must be why they didn't last more than a year).
I'm trying to find out the true weight of the F2's, but it's got to be 22-24 lbs at least.
EDIT.
Found it. Weight of the 17" F2 is 24 lbs.
Old 10-13-2007, 10:20 AM   #12
Anybody weigh the Arc rims perchance?
Old 10-13-2007, 11:17 AM   #13
The steel 16s MAY be lighter, assuming they needed less metal to be as strong as he alums.
Old 10-16-2007, 03:28 PM   #14
Yeah, steelies might be lighter than my 17" F2's, but I can't imagine they are lighter than some of the 16" alloys Saab has made in recent years.
Old 10-16-2007, 03:29 PM   #15
Red DIC's Avatar
My 15" delta's weight like 15 lbs.
Red DIC is offline
Old 10-17-2007, 06:52 AM   #16
Yeah, the Deltas were pretty light...I mounted snows on those and sold them to a kid with an NG in Starksboro a few months ago...15's are a thought...but I am probably going to install Aero/Viggen front rotors and calipers this winter, so I can't use 15's.
Old 10-17-2007, 01:32 PM   #17
Red DIC's Avatar
When's the subie coming out?
Red DIC is offline
Old 10-17-2007, 01:35 PM   #18
drewz airflow se's Avatar
my mom rocks those on here combi 9-3
^CLICK ME^
drewz airflow se is offline
Old 10-17-2007, 01:38 PM   #19
Old 10-17-2007, 01:40 PM   #20
Originally Posted by NickTurbo900 View Post
not feeling them as much with that tire size.
^CLICK ME^
