Handling gains - The Saab Link Forums
Old 10-09-2007, 09:15 PM   #1
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
Handling gains
What kind of handling gains could I expect to see from the Taliaferro (sp?) 35mm drop springs ALONE. How much stiffer are they from stock springs. I say alone because I cant afford them and the new shocks to go with them. Or what about that 6 point front subframe brace? I am looking around to see what I want to do to my car next to improve the handling. I dont want to do a rear swaybar yet as I race auto cross at my school, and the sway bar would jump me up 2 classes instead of just 1. My car is a 95 900S NA btw. Thanks in advance.
mlemorie is offline
Old 10-09-2007, 10:25 PM   #2
I would wait and save uo the money for shocks as well.
Lowering springs with stock shocks is not a good choice, your car will be lower but the handling can be crap since the stock shocks does not work well together with lowering springs.
I think the 22mm rear antiroll bar is a much better choice then the 6-point brace.
But still, I would get shocks and springs at the same time. Makes a HUGE difference to the handling of the car.
Pade is offline
Old 10-09-2007, 10:56 PM   #3
Red DIC's Avatar
You can double stack the rear sway bar without people noticing too much...
Red DIC is offline
Old 10-10-2007, 01:48 AM   #4
Curlymurt's Avatar
DIP had one in the for sale forums. I don't know if it's still available or not. Definitely don't get springs without the Koni adjustables.
Curlymurt is offline
Old 10-10-2007, 03:28 AM   #5
codesplice's Avatar
Have you looked into the GenuineSaab steering rack clamp + brace? Or how about some nice poly bushings? I'd highly recommend both of those if you're not interested in doing a sway bar yet.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 10-10-2007, 11:18 AM   #6
Do the brace and the bushings make that noticeable of a difference? I know they would be a good improvement, but I wasnt sure just how much of a change they would actually make in the handling.
mlemorie is offline
Old 10-10-2007, 11:48 AM   #7
codesplice's Avatar
The brace will help significantly with torque steer to make hard acceleration much more manageable. The bushings well help a lot with keeping the wheels on the ground. The rear ARB is still probably the biggest bang for the buck, but the clamp/brace and bushings will also make a pretty substantial difference.
2007 9-5 2.3T Wagon
Old 10-10-2007, 12:01 PM   #8
JK
JK's Avatar
I don't think he will suffer from any torque steer with a n/a 900S.
Wheels, tires and Konis will help out imensely! Also the bushings would be a great improvement for the money. Springs alone wouldn't do as much for you as buying Koni shocks/struts alone.
I have Konis and stock springs in my 9-3, and it handles great, albeit with a higher center of gravity than if it had lowering springs.
always a SAAB guy at heart
JK is offline
Old 10-10-2007, 12:42 PM   #9
codesplice's Avatar
Oh yeah, completely forgot about that.
2007 9-5 2.3T Wagon
Old 10-10-2007, 02:47 PM   #10
liketheword's Avatar
Personally on a NA 900S i would say RARB along w/ Shock/Spring combo nice wheels and tires you would have a tidy ship.
Vitamin SAAB
liketheword is offline
Old 10-10-2007, 04:11 PM   #11
adidas_007's Avatar
I can say personally, having a 95 900 & also having a far amount of Suspension mods, first was the 22mm bar was first, then polys, & new shocks, with a good set tires, you can feel a big differance. Brakes are really good to upgrade too IMO.
I also got the steering rack clamp & brace, & after this past weekend at saabtober fest, I think it really came in nicely.
http://www.cardomain.com/ride/735088
-22mm Rear Sway Bar - Genuinesaab.com
-Bilstein Shocks and Struts
-EBC Green Stuff Brake Pads - Front and Rear - Car-Stuff.com
-K&N Filter
-Nokian Tyres RSI's - Winters
-Optima Red Top Battery
-Falken fk452
-Polyurethane Front ARB Bushings - Genuinesaab.com
-Polyurethane Suspension Bushings Inner - Genuinesaab.com
-Polyurethane Suspension Bushings Outer - Genuinesaab.com
-Sport Transmission Mount (Urethane insert) - Genuinesaab.com
-Steering Rack Brace & Clamp Kit - Genuinesaab.com
-Three Double Spoke Evo Style 17" Ronal Rims
-Zimmerman Drilled Rotors
2010 9-5 Aero
2004 9-5 Aero 5pd Stg 3 Wagon, 1 of 18 Made
1990 900 Convertible
2007 Cbr600
adidas_007 is offline
Old 10-10-2007, 04:59 PM   #12
SPEND THE MONEY ON TIRES. Spring and struts and bars are NOTHING without good tires.
Fine get a sway bar and springs. But if you are rolling on some half ass all seasons, you are wasting time and money.
You said you want to autox. And apparently competitively, evidence by the fact that you were concerned about jumping up two classes. I agree.
Prioritize, if you want to be good at autox:
1. Max performance summer tires or R compounds
2. Brake pads
3. Struts
These all keep you in stock class, in most regions. Then drive the shit out of your car. Don't start doing any mods until you are comfortable that you have exceeded the limits of the cars potential.
I absolutely love trouncing a guy that is driving a boosted, tubbed, slick tire Miata with 300hp. In a bone stock 9-3ss.
MODIFY your driving ability. Then worry about the car. That's what the good, better, best drivers do.
I did it backasswards on my Z build and sometimes I regret it. But only sometimes.
Topher is offline
Old 10-10-2007, 05:03 PM   #13
For emphasis...
TIRES are the single most important piece of material on your car. They are the only thing that connects your car to the road. They help you stop. They help you turn. They help you accelerate.
If you aren't using something that provides grip then you are just giving away performance (and safety).
I roll on Max Performance Summers and hi-perf winters. I scoffed at everyone who had multiple tire sets. Until I got rid of "high perf" all seasons.
All seasons are good at everything. But great at nothing.
Topher is offline
Old 10-10-2007, 05:29 PM   #14
Red DIC's Avatar
Originally Posted by Topher View Post
For emphasis...
x10000
Red DIC is offline
Old 10-10-2007, 05:30 PM   #15
Red DIC's Avatar
Elaborate. Now.
Red DIC is offline
Old 10-10-2007, 05:54 PM   #16
Elaborate. Now.
I could barely drive it without spinning it at Autox events as it was, on stock power and old ass suspension. Then I did all of this:
70k mies when I purchased it.
Now has a 280 z engine with a 240z head...10.5:1 compression
swithched rearends from 3.4 to a 3.93
switched the 4sp to a 5sp late model
replaced stock tach with a 5in monster tach in original location
Unilite distributor, MSA headers wrapped in high temp header wrap, 2.5exhaust, crane cams ignition box, crane hi-perform coil, Energy Suspension poly urethane bushings everywhere, eibach springs, tokico struts, MSA strut tower braces front and back, Suspension techniques sway bars front and back, switched carbs to SU's with airhorns and K&N filters, seats replaced with Corbeau's, corbeau 4 point harnesses, ported and polished head, ARP rod bolts, Holley Redline fuel pump and regulator, modified oil pan with traps, Nissan Motorsports Turbo oil pump, Goodridge stainless steel brakelines, Hawk carbon metalic pads, Taylor Hi-Pro 8mm plug wires
Interior is pristine...no cracks on dash, aluminum switch plate, toggles fuel pump, ignition box, foglights and rev limiter switch....push button start in cigarette lighter position, Momo Dshaped wheel, MSA quick steer knuckles
Got rid of the airpump, emissions control, no cat, got rid of the air conditioning (no need for any emissions control...grandfathered due to the year of vehicle)
Yokohoma tires
MSA Front spoiler
mods came as I could remember them sorry for the weird order. I am sure there is more I have done in the past 2-4 years but I can't really remember everything right now.
Topher is offline
Old 10-10-2007, 06:08 PM   #17
Yokohoma tires
MSA Front spoiler
Ummm...WHEN DO I GET TO SEE THIS CAR!?!?
Vitamin SAAB
Old 10-10-2007, 06:29 PM   #18
Once I bring it to MN.
Topher is offline
Old 10-10-2007, 06:39 PM   #19
8valvegrowl's Avatar
Umm...most classes won't let you run an R compound tire unless you want to run with the big hairy dogs...
But Topher's advice is top notch...tires are the key.
Get some Falken Azenis RT-615's or some Proxes RA-1's (or if you have the bucks, Yoko Advans). ANd get practicing.
8valvegrowl is offline
Old 10-10-2007, 06:44 PM   #20
I have 235/45/17 Yoko Advan A046's.
Wow. Do they rock or what.
Topher is offline
