Stage 4 - The Saab Link Forums
Old 10-07-2007, 07:39 AM   #1
spanky's Avatar
Send a message via AIM to spanky
Stage 4
i put my stage 4 chip in and i am only getting a boost spike of 15 psi then is settles around 10-11. i dont know what i should look for or should try to get this to put out the right psi.
97-900se blk/blk 5speed, 2.3 aero motor, td04 18t......SOLD
92 dodge w250 cummins.....SOLD
97 900SE blk/blk, 5speed, TD04, upgraded fmic-----Back in the game
03 f250 CCSB Lariat 6.0
spanky is offline
Old 10-07-2007, 07:46 AM   #2
mcrowley's Avatar
First thing that you should check when you've got boost issues with a T5 car is the BPC.
Second, check the other usual stuff: wastagate actuator, spark plugs, good fuel, etc
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-07-2007, 07:49 AM   #3
Legit's Avatar
Is it safe to run a mbc with the software?
2002 Viggen Convertible
Legit is offline
Old 10-07-2007, 07:55 AM   #4
JK
JK's Avatar
Its not ideal.
When I was only seeing around 17psi from my JSP stage 4 tune all it took was cleaning the BPC a few times with WD40, that got me seeing 25-27psi peak, settling back down to around 23-25psi.
Give it a try - spray WD40 in the ports of the BPC, let it soak in a bit, then drain it. Repeat that a few times and it should be nice and clean. Then shoot a low pressure blast of air at the holes (I wouldn't use more than 10-20psi from my air compressor for fear of breaking the brass disk in the BPC valve).
always a SAAB guy at heart
JK is offline
Old 10-07-2007, 07:57 AM   #5
lms
Is it pinging at all during wot?
lms is offline
Old 10-07-2007, 12:18 PM   #6
spgproject's Avatar
kinda pointless
-Sir William Lyons
spgproject is offline
Old 10-07-2007, 01:21 PM   #7
spanky's Avatar
no i didnt have the mbc on the car when i put in the chip, the car has had super in it since i have been driving it, and when i put chip in i put in a new set of NGKs. but i will try the bpc
spanky is offline
Old 10-07-2007, 02:01 PM   #8
mcrowley's Avatar
Well, remember your plugs won't last as long with a tuned ecu in the car.
Pull them every so often and check the gap. I usually have to replace mine every oil change.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-07-2007, 02:07 PM   #9
saabkid37's Avatar
i blew the gap to over 1mm on some es-11's on a stock car...i think that might be bad...
saabkid37 is offline
Old 10-08-2007, 05:49 AM   #10
spanky's Avatar
i cleaned out the bpc yesterday, and now i get a spike of around 19 then it settles at 15-16. but should i be getting more with stage 4?
spanky is offline
Old 10-08-2007, 05:56 AM   #11
moose's Avatar
YUP!!! check vac. lines, wastegate might be fluttering, and check the BOV it might be opening if you have the lighter spring in it. Unless you have the stock recirculating one.
undercover Moderator
Stg. no go
moose is offline
Old 10-08-2007, 06:41 AM   #12
You can also flip the bov so the face is pointed towards the hood instead of toward the headlights. Helps to keep it closed underboost.
Stage: power back on the road
fieldsc is offline
Old 10-08-2007, 06:53 PM   #13
spanky's Avatar
ya i have a forge blow off, and how could i tell if my wastegate is fluttering, and what could i do to fix it.
spanky is offline
Old 10-08-2007, 07:14 PM   #14
JK
JK's Avatar
What spring do you have in it? I have the second heaviest in my Forge 001 and mine starts to blow open around 25 psi...when I had the lighter spings in there I couldn't get more than 20 psi.
Clean the BPC again. I did it at least twice, maybe 3 times before it really got cleaned out.
JK is offline
Old 10-16-2007, 10:10 AM   #15
Heath's Avatar
Anyone have a pic of this orientation to ensure mine is as stated?
I assume the "face" is where the vacuum line attaches?
Heath is offline
Old 10-16-2007, 11:22 AM   #16
mcrowley's Avatar
You want the piston/spring/face/etc in the valve perpendicular to the cold side intercooler pipe. In a 9k, facing up. NG900/9-3/9-5 facing toward the driver's side of the car.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-16-2007, 03:29 PM   #17
Heath's Avatar
So if the valve was transparent the actual piston would look as though it would slide through the nipple allocation in the cold side charge pipe if all other materials of the valve were dissolved away?
This is a little confusing depending on which way the valve is mounted. I mean I could mount it a couple ways and consider it perpendicular to the pipe and simply twist the unit 90 degrees past one of those ways and consider it parallel.
I'm looking for a pic to clear all doubt.
Heath is offline
Old 10-16-2007, 04:44 PM   #18
mcrowley's Avatar
I know this is a 9k engine bay, but it should give you an idea...same principle applies. See how the vac line is facing up? Usually it faces toward the front of the car.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
