viggen exhaust - The Saab Link Forums
Old 10-07-2007, 04:18 AM   #1
jtviggen's Avatar
Send a message via AIM to jtviggen Send a message via Yahoo to jtviggen
viggen exhaust
hey guys
i know this has been looked at a couple of times but;
question for you
im still confused on the whole turboback vs cat back exhaust
what do i need for each???
and what would sound better???
i was looking at the JT exhaust on GS for my viggen
but not too keen on the tip on it i like the viggen tip alot and how it looks in the cutout on the bumper cover.
thanks
-josh
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 04:44 AM   #2
RBatsch's Avatar
Hey jt,
what other kind of improvments are you planning.....IC, ECU? I'm not sure if decreasing your exhaust pressure while not improving your intake is a good idea....could run lean??
That said you want GS 3" DP v2 and for the rest of the exhaust Nick has recommended the Simons to me (correct Viggen tip). I've done the DP, IC, filter and now plan to do the exhaust, fuel regulator and ECU. The Saab Sport would have been an interesting option, but it's no longer made.
Best of luck and let us know what you decide...
Robert
RBatsch is offline
Old 10-07-2007, 04:55 AM   #3
jtviggen's Avatar
rite now i have an hyperboost BPV and open air intake
and plan on doing ecu upgrades as well with the exhaust
and suspension too
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 05:00 AM   #4
jtviggen's Avatar
hey this is one i found on thesaabsite.com:
93 98-03 Sport Exhaust System Turbo 2.5 inch Viggen-Aero II 00603 polished oval rear end 3 inch X 5 inch Simmons
is this what you were talking about???
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 06:20 AM   #5
drewz airflow se's Avatar
i say run saabsport exhaust and a 3inch DP
^CLICK ME^
drewz airflow se is offline
Old 10-07-2007, 06:23 AM   #6
saabkid37's Avatar
the saab sport looks like poo on a viggen....i know because i have one.
the jt looks very good in the bumper and sounds amazing on the vigs...
saabkid37 is offline
Old 10-07-2007, 06:24 AM   #7
Rudedog's Avatar
This is what I have and I have with a stage 4 tune and have been very satisfied.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 10-07-2007, 06:24 AM   #8
You can put tip on it
^CLICK ME^
Old 10-07-2007, 06:59 AM   #9
jtviggen's Avatar
ok
turbo back vs cat back???
opinions???
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 07:41 AM   #10
JK
JK's Avatar
Originally Posted by jtviggen View Post
ok
opinions???
I think you need to understand what each of those terms mean.
Then we need to understand what you want. We can't just tell you what you want...because we don't know what your needs are.
Turbo-back: This means replacing all of the exhaust from the turbo to the tailpipe
Cat-back: this means all of the exhaust from the mid-pipe to the tail pipe, this does NOT include the downpipe.
Downpipe: this is the part of the exhaust from the turbo to the catalytic converter - upgrading this part from the stock 60mm (around 2.5 inch) to a 3 inch downpipe will net you the most performance gains and allow you to run more agressive software.
Now, we need to know what you are looking for---
Do you want to replace the stock stuff just for a different sound and you don't care about performance? If that is the case then you want to replace the stock cat-back exhaust with either a saabsport (2.5"), Simmonsn (2.5"), ferrita (2.5"), JT (3") or have a custom built cat-back made in 2.5", 2.75", or 3"
Is performance more important to you? Then the first thing you want to do is upgrade the downpipe to a 3" unit (either the JT downpipe or the "GS V2" from genuinesaab.com). From this point you can opt to either upgrade the rest of the system as well (adding a cat-back to the 3" downpipe would mean you are replacing the exhaust form the turbo to the tailpipe, hence ''turbo-back''
If its performance and sound you are seeking but you don't have the money to buy a downpipe and an aftermarket cat-back you can just upgrade the DP and then have the center resonator from the stock exhaust replaced with straight tube, this will get you a very nice sound and will not cost much more than just the price of the downpipe.
always a SAAB guy at heart
JK is offline
Old 10-07-2007, 07:47 AM   #11
Legit's Avatar
The 3" JT system is by far the cheapest.
The complete 2 muffler catless system comes with a 3" DP and its only $579.
I have heard the one muffler option sounds very ricey.
A SaabSport system is $385 + 472.50 (DP) = $857.50
EDIT:
The JT is not stainless like the SaabSport, its aluminized steel.
2002 Viggen Convertible
Legit is offline
Old 10-07-2007, 07:48 AM   #12
mcrowley's Avatar
Turbo back all the way if you're planning on any sort of ecu tune.
Even on a stock car you'll notice a difference.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 10-07-2007, 07:51 AM   #13
JK
JK's Avatar
Where did you get that info? I've heard 3" exhaust with one muffler, and it certianly does not sound ricey! It sounds much less ricey than the saabsport in fact (which has one 2.5" muffler).
JK is offline
Old 10-07-2007, 07:52 AM   #14
jtviggen's Avatar
i like the sound i have now out of the viggen exhaust and looking for performance as well
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 07:58 AM   #15
JK
JK's Avatar
Then I would suggest getting the 3" downpipe first and have the center resonator replaced with straight tube. You don't need to upgrade the cat-back right away, the 2.5" Viggen exhaust is fine for mild to moderate tunes.
JK is offline
Old 10-07-2007, 07:59 AM   #16
jtviggen's Avatar
yea but i heard the stock viggen exhaust is not 2.5
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 08:05 AM   #17
JK
JK's Avatar
It's 60mm, which (according to Google) is 2.36" so, not quite 2.5" less than a 1/4" different though.
Regardless, what are you going to do with the car? Stage 4 right away? Wait a year or two before you buy an ECU upgrade? Do you understand that even if you want to do the saabsport or some other 2.5" or 3" later you'll still want to upgrade to the 3" downpipe first?
So, my advice, again, tell us what you are going to do with the car right away.
If you're not doing stage 4 right off the bat then just replace the stock DP with a 3" one and leave the rest of the stock exhaust in place. If you have $2200 and feel like doing stage 4 right off the bat then upgrade the entire exhaust, buy an upgraded intercooler, and get a tune!
JK is offline
Old 10-07-2007, 08:14 AM   #18
jtviggen's Avatar
i plan on doing the exhaust and suspension first then later engine upgrades
so i would need the downpipe for a turboback rite???
1999 9-3 Viggen
jtviggen is offline
Old 10-07-2007, 08:21 AM   #19
JK
JK's Avatar
Turbo-back is the just a term for replacing the entire exhaust. Please read the first post I made, it is explained in there.
(so, yes, if you are replacing the entire exhaust you would be replacing the downpipe)
JK is offline
Old 10-07-2007, 10:18 AM   #20
jtviggen's Avatar
ok i think i got it now thanx
1999 9-3 Viggen
jtviggen is offline
