This is kinda performance/mod based-power steering findings... - The Saab Link Forums
Old 10-03-2007, 09:32 AM   #1
a12
a12's Avatar
I have posted on here a few times about a problem I was having with my power steering. The pump was blowing fluid out past its shaft seal, but only when it got hot and I took "full lock" turns. I believe the problem lies in the pressure relief valve portion of the pump. I do not want to put a new one on as they are very expensive (over $400 from eeuroparts) and don't want to put a used one on that could fail at anytime. I am gonna try one of two things:
-replace pump with earlier style pump (which I think is either same pump with different p/n or very similar).
-or this is possibly an option as it looks almost identical to the pumps on our cars and is the least expensive option.Inlet and outlet are the same, shaft size is the same.
http://store.summitracing.com/partde...5&autoview=sku
If anybody can find any specs on the Saginaw TC or Type 2 series pumps that would be great.I will continue looking and post what I find.
The reason I am posting this is so we can possibly find a cheaper option as the power steering systems on these cars tend to be a weak point and parts are expensive.
a12 is offline
Old 10-03-2007, 10:21 AM   #2
Nick Taliaferro
GenuineSaab's Avatar
I know from experience that with stock drive ratio they do no hold up well to extended high (7200+) rpm use. I was planning to make a larger, slower pulley for my cars here to play with.
Nicholas Taliaferro
GenuineSaab is offline
Old 10-03-2007, 11:17 AM   #3
a12
a12's Avatar
Oh that would be cool also. Do you have any tech specs on the Saginaw Tc series?
a12 is offline
Old 10-05-2007, 03:38 PM   #4
a12
a12's Avatar
Update: Took the pump pressure relief valve assembly apart and cleaned it. There was some rust and a lotta "milk" (ps fluid and water mix) stuck in there. Gonna try to rebuild it if I can find a kit. Apparently some volvos use the Saginaw TC series pumps, as well as a bunch of other cars. Some of the volvo power steering rebuild kits are like $10 or $15 so this would be great if it works. If not, napa has rebuilt ones for $239.00. They are rebuilt so there must be a kit out there somewhere.
a12 is offline
