Do I Need an A/F Gauge?? - The Saab Link Forums
Old 09-24-2007, 11:36 AM   #1
Passenger 57's Avatar
I would like to get a MBC+A and through searching have discerned that I will need a boost gauge, but do I also need a A/F ratio gauge as well??? I've got a 99 9-3 HOT, btw.
Also where can I get some aluminum 90 deg bends for my DIY intake? Any ideas???
Thanks for the help!!
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Passenger 57 is offline
Old 09-24-2007, 11:43 AM   #2
Deez Nutz
Palmer's Avatar
You should get a boost gauge if you increase the boost above stock.
If you are going to get an A/F gauge (you don't for an MBC+A) save your pennies, and get a wideband A/F gauge. They are about 200+ dollars, and not really needed unless you are doing some serious tuning.
As for the bends, I was in a checker auto on Larpenteur last week, and they had a section for building your own intakes, with clamps and mounts and junk.
S55/LC100/KL
Palmer is offline
Old 09-24-2007, 11:47 AM   #3
Not sure what model you have.. But you really dont need the a/f gauge for a boost controller. Saabs have a safety fuel cut built in. So the engine management wont let the engine lean out in that regard.
Stage: power back on the road
fieldsc is offline
Old 09-24-2007, 12:35 PM   #4
2k193turbo's Avatar
A narrow band air-fuel gauge certainly won't hurt and is much better than nothing.
2k193turbo is offline
Old 09-24-2007, 12:39 PM   #5
Deez Nutz
Palmer's Avatar
Yeah, but at this point 50 bucks is best spent on something else...
Like a spare DI or a Drop-in filter.
S55/LC100/KL
Palmer is offline
Old 09-24-2007, 12:59 PM   #6
laxian55's Avatar
Narrow bands arent anything more than a lightshow. Dont waste your money until you can afford to buy a wide band and do some serious tuning. They will only show the extremes of your a/f range and aren't accurate at all. Besides with stock engine management you wont lean out at 15.5 psi.
laxian55 is offline
Old 09-24-2007, 01:15 PM   #7
Thanks for the info guys
Old 09-24-2007, 01:34 PM   #8
Drew in Houston's Avatar
The problem with a narrowband is that it can only tell you whether your AFR is above 14.7:1 or below (lambda 1). That's it. If you're trying to tweak your idle it would be useful, otherwise it won't tell you anything meaningful because it can't.
Drew in Houston is offline
Old 09-24-2007, 02:31 PM   #9
Marks9-3's Avatar
Ive had mine since before I got a new ECU...Stage 3 and Stage 4...I have used it ummm....never. Even an EGT gauge will be much more usefull than your standard A/F gauge.
Get a K&N panel filter and then mod your intake box with a 3" tube for the same money. Will be much better with the MBC+A.
Marks9-3 is offline
Old 09-24-2007, 03:36 PM   #10
Red DIC's Avatar
You don't need a boost gauge either, contrary to popular belief.
Red DIC is offline
Old 09-24-2007, 04:11 PM   #11
Marks9-3's Avatar
Yeah you dont NEED one, but tuning an MBC+A on a car with a real boost gauge (mine) and a friends who didnt have one at the time seemed the same till our butt dyno failed cause when I installed a boost gauge on his car his peak boost was only about 13psi. I retuned it to peak performance after that, but actually knowing real numbers is much better when tuning.
Marks9-3 is offline
