Exhaust, Sr20 style - The Saab Link Forums
Old 09-19-2007, 08:08 PM   #1
Exhaust, Sr20 style
Well most my buddies with 240s have an exhaust system that goes straight back from the downpipe then curves up to the muffler. I want to do the same thing with my saab and will probably get it done this week. My reasoning is it will flow alot better then the gobs of bends it needs to go the stock route, and it would also make it possible to do a 3 inch instead of 2.5.
Basically after the flex pipe, its going to be 2.5 or 3 inch (have not decided yet) straight back down the center line of the car. It will go right under the gas tank (I am making a heat shield out of sheet metal, and wrapping that portion with Exhaust wrap) and then right after the rear axle it is going to cut gradually up to the driver side and curve back to straighten it out into the muffler/tip. Anyone try this or see any problems with this? Will like input before I go lay down some moneys.
frostycrowd is offline
Old 09-19-2007, 08:13 PM   #2
liketheword's Avatar
I am thinking hot exhaust+gas tank= no good. Neat idea though. Just wouldn't do it on on a car I cared about..
Vitamin SAAB
liketheword is offline
Old 09-19-2007, 08:17 PM   #3
That seems to be a concern of alot of people. I really think with a heat shield and wrapping that 2 foot section that it would not be very hot, not to mention it is toward the rear of the car where the exhaust is dramatically cooling down. Or so I hope, I do not want to find out the hard way
Old 09-19-2007, 09:33 PM   #4
bsuarmy's Avatar
well if you ignite we'll all know its a bad idea. go forth and test it for us!
bsuarmy is offline
Old 09-19-2007, 09:36 PM   #5
Deez Nutz
Palmer's Avatar
Wrap that shit, dog.
Good luck, and take pictures!
I would also like to point out that the 9-3 (along with most new cars) has a plastic gas tank.
Be safe.
S55/LC100/KL
Palmer is offline
Old 09-19-2007, 09:56 PM   #6
laxian55's Avatar
That will hang down even lower off the bottom of the car, there is an indentation in the floor boards for your stock exhaust, and we all run 3" without a problem.
laxian55 is offline
Old 09-20-2007, 04:11 AM   #7
NickTurbo900's Avatar
I think your ground clearance will be 4 inches lower than the lowest spot on your gas tank if you do that. Take a tape measure and get under your car and look at what this means.
I would doubt the bends in the stock exhaust system pose any restriction whatsoever if you are using a 3" system.
NickTurbo900 is offline
Old 09-20-2007, 04:17 AM   #8
codesplice's Avatar
Yeah... unless you're gonna lift your car four inches before you do this (do it! hella rally stylez!), hanging a 3" pipe underneath the car will cause all sorts of clearance issues.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 09-20-2007, 05:32 AM   #9
The plastic gas tank is more likely to melt due to the heat. Plus the ground clearance would be a another big concern as mentioned.
Vitamin SAAB
Old 09-20-2007, 07:43 AM   #10
CooperS7777's Avatar
If you still have your plastic mid mount mud flaps - you allready know how much those rub Im sure. A full 3" exhaust outside of the channel will sit as low if not lower than those do.
I doubt however that the tank would melt from the exhaust heat - Im sure it has quite a high melt/flash point being a gas tank and exhaust temps that far back are pretty low.
CooperS7777 is offline
Old 09-20-2007, 07:46 AM   #11
JK
JK's Avatar
I doubt the gas tank would be an issue, the exhaust already runs very close to it, and the OEM heat shield makes things fine.
But as others suggested, this is not going to work well any time you are on a road that is not flat. Any time you straddle any sort of hump you're going to get massive dragging problems, possibly crushing the exhaust INTO your tank
Also, keep in mind that there are 500+ hp ng900/9-3s running around with the exhaust running in the stock location. The gains probably don't outweight the bennefits.
Now, that said, go try it and report back!
always a SAAB guy at heart
JK is offline
Old 09-20-2007, 07:51 AM   #12
make the exhaust terminate on the side between the front and rear doors, sort of like cobras..
Stage: power back on the road
fieldsc is offline
Old 09-20-2007, 07:56 AM   #13
codesplice's Avatar
Cool idea.... but you'd still have it hanging 4" below the rest of the car.
2007 9-5 2.3T Wagon
Old 09-20-2007, 07:58 AM   #14
That wont pass inspection in most states. It might even be federal that the exhaust has to dump past the rear most operable window.
Old 09-20-2007, 08:02 AM   #15
codesplice's Avatar
It'll fly in Alabama :lendostar:
2007 9-5 2.3T Wagon
Old 09-20-2007, 10:13 AM   #16
Powar's Avatar
Send a message via AIM to Powar
That isn't a concern for us here in KY.
Powar is offline
Old 09-20-2007, 10:14 AM   #17
Drew in Houston's Avatar
Side pipes!
Drew in Houston is offline
Old 09-20-2007, 10:27 AM   #18
prophet's Avatar
screw side pipes. open headers.
A 40 ounce to freedom is the only chance I have to feel good even though I feel bad
prophet is offline
Old 09-20-2007, 10:53 AM   #19
codesplice's Avatar
And then you spool the turbo with hopes and dreams?
2007 9-5 2.3T Wagon
Old 09-20-2007, 10:58 AM   #20
bsuarmy's Avatar
through the hood stacks...turbo spooled with hopes and dreams. 80 psi agressive tune!
bsuarmy is offline
