Intake cone VS filter - The Saab Link Forums
Old 09-26-2004, 06:58 PM   #1
Administrator
Boxerchip's Avatar
As far as performance what is better for HP and torque? the cone clearly pulls hot air but is it so free flowing it makes up for the heat?
1998 BMW M3-ECU, intake, tein coils w/ pillow ball uppers, sway bars, W7 w/ 1000 watt JL, short shift, DSSR, uuc exhaust, BBS CH 18s.
2001 Audi S4-Sold
1999 STAGE III VIGGEN-Sold
2000 9-3-Sold
1992 900S- Sold
Boxerchip is offline
Old 09-26-2004, 07:14 PM   #2
if u dothe 3 inch airbox mod and put in a different filter i doubt it woud flow much different but it would pull colder air.... as far as horsepower i think they are about the same
ricot83 is offline
Old 09-26-2004, 07:51 PM   #3
Administrator
Boxerchip's Avatar
but what is better.... little worse air flow or faster flow and hot air.... anyone ever dyno their car with 3 inch box VS cone?
2001 Audi S4-Sold
2000 9-3-Sold
1992 900S- Sold
Old 09-27-2004, 06:06 AM   #4
Trollerator
abdukted1456's Avatar
I am trying to decide right now whether to get a BSR optiflow kit or just drop in a K&n or JR into the airbox and do the 3" mod....
any dyno data anyone has comparing the two would be great. i have heard people agrue for and against each option, but no clear consensus as to which is better...
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 09-27-2004, 06:11 AM   #5
2k193turbo's Avatar
I've had both a K&N w/airbox and the BSR cone intake on my car. The cone definetly sounds better, it has a throatier growl and the turbo spool is much louder. I don't think it's a huge increase in power over the airbox, but seems like the turbo spools faster with the cone. Especially with the SMBC.
The cone probably sucks in some hot engine air, but the heat shield is designed to bring in fresh air from the hole that the stock airbox snorkel comes through.
You do have to go through and remove the stock airbox resonator piping or it blocks the fresh air from getting in.
My gut feeling is that the cone is superior, but without a Dyno test it's hard to say.
All the extra noise sounds great, but it could be a placebo effect.
2k193turbo is offline
Old 09-27-2004, 06:14 AM   #6
rcmdesign's Avatar
Doesn't anyone live near a dyno?
Rob
Swedish Performance
rcmdesign is offline
Old 09-27-2004, 06:51 AM   #7
just outta curiosity....when you say cone filter, you mean you just put a cone filter in place on the stock airbox, the cone filter is still in the same location as the stock airbox?
saabvos is offline
Old 09-27-2004, 07:14 AM   #8
2k193turbo's Avatar
This is the one that I'm using
http://www.genuinesaab.com/detail.asp?PRODUCT_ID=XF.970
It's a cone filter with a heat shield.
The heat shield looks like it's made of black ABS plastic, but it is really metal thats been painted
Did I say BSR before...... I meant Optiflow
Old 09-27-2004, 07:27 AM   #9
Administrator
Boxerchip's Avatar
I am using the same thing but Ive heard some peoploe say they lost 30HP by using this filter over a drop in. (due to engine heat)
just need someone to dyno this stuff
2001 Audi S4-Sold
2000 9-3-Sold
1992 900S- Sold
Old 09-27-2004, 07:41 AM   #10
Nick Taliaferro
GenuineSaab's Avatar
I have one on my Viggen. We definitely did not loose any power. I also monitored the intake temp on my daily drive. It was not any higher... The same did not apply to the intercooler to throttle pipe made of metal though.. Saw a bit of heat soak there.
On a turbo the intake temp is a an issue just not huge since after it is compressed the temperature rise is quite great. Flow is the greatest concern on the turbo intake side. Intercooler efficiency is the biggest issue.
Nick T
GenuineSaab is offline
Old 09-30-2004, 08:03 AM   #11
Administrator
Boxerchip's Avatar
Thats exactly what I was thinking... oh well ill get a dyno done and see whats up. unless you already have one?
2001 Audi S4-Sold
2000 9-3-Sold
1992 900S- Sold
Old 10-15-2004, 12:38 PM   #12
Trollerator
2k193, what does the resonator box do? By removing it, will it open a path to let in all sorts of debris into the engine bay?
do you have any pics of it? removed or installed, either would be helpful. gracias.
1990 900 turbo vert
2004 9-5 aero sedan
Old 10-15-2004, 01:12 PM   #13
dude if u look down behind the bumper there is a resonator there and its huge just remove it and u get better colder air in
ricot83 is offline
Old 10-15-2004, 03:27 PM   #14
If you are looking for better flow and nice sound, get the cone. Also lets you hear the Recirc valve better for the racer boy bov sound! As Nick said , in a turbo car, flow to the turbo is of optimum concern. The second that air gets near the 100+f compressor, that get compressed(which will heat air in and of itself) any gains from a CAI are lost. A larger FMIC with more surface area and larger IC piping would help much more than any CAI would.
The Vigg is offline
Old 10-15-2004, 06:09 PM   #15
2k193turbo's Avatar
Unfortunately I don't have pics..... But.........
If you jack up your car or put it on ramps and get under the car on the passenger side.
look up behind the foglight there is a black box about the size of an ice cream container, thats the resonator box.
there is one large (4'?) rubber hose that leads to the inlet on the airbox
there is another large rubber hose that leads from the resonator box up to the fender
Take it out, you'll hear the difference right away!
Old 10-20-2004, 03:46 PM   #16
DC_SAAB's Avatar
maybe this one might interest you....
hope it helps
DC
DC_SAAB is offline
Old 10-20-2004, 05:12 PM   #17
Administrator
Boxerchip's Avatar
how the hell does that work? im sooo confused.
2001 Audi S4-Sold
2000 9-3-Sold
1992 900S- Sold
Old 10-20-2004, 06:20 PM   #18
DC_SAAB's Avatar
time for enlightenment ohh grasshopper...
works the same way the cones do with a aluminum sheild panel, only doesn't suck air from all directions, and .....well the hell with the technicals.., I just like the way it looks, sounds and feels...
the cold air still makes its way in from that snorkel hole above the foglight but the filter is a foam type, recleanable like the K&N style filters. This one's used for a lot of road rallys supposedly... oh yea., and I like it..
DC
DC_SAAB is offline
Old 10-20-2004, 07:24 PM   #19
Administrator
Boxerchip's Avatar
I still dont get it... just looks like tube to me.... how would that be any better than just taking the intake off.
2001 Audi S4-Sold
2000 9-3-Sold
1992 900S- Sold
Old 10-21-2004, 02:15 AM   #20
DC_SAAB's Avatar
... :P
DC
DC_SAAB is offline
