Oh Baby. - The Saab Link Forums
Old 09-10-2007, 06:11 PM   #1
NahumCC's Avatar
Oh Baby.
Ok so here is the big update everybody. Not sure whats leaking oil specifically now on my 9-3 but the suspects are oil feed line, oil filter, or oil return from turbo. Good thing is its not much oil but I'm keeping my eye on it all closely.
On for the best part though.
It would be going into the car tonight however a discovery during install found that the board itself is upside down . I mean I could plug it in and run with it but not knowing for certain how the ecu is grounded i'm not risking it at all. A quick trip to the computer center in the morning and they'll have a torx head small enough (my smallest was just barely to big). However if somebody can confirm that the ECU doesn't have to be bolted or in the slot of the ECU tray to be grounded I'd be willing to plug it in. Just not enough room to have it in the slot and get the wiring harness turned upside down.
2013 FR-S
NahumCC is offline
Old 09-10-2007, 06:22 PM   #2
spgproject's Avatar
neato. i'm assuming that's a jak-in-the-box?
i think the "big update" will come after it's installed. enjoy!
-Sir William Lyons
spgproject is offline
Old 09-10-2007, 06:23 PM   #3
NahumCC's Avatar
Yup Jak's software. However until I find out that I can put it in and not have to have the ECU bolted down in its tray to be grounded I can't run it until I have the board flipped in the morning. Stupid Murphy's law.
2013 FR-S
NahumCC is offline
Old 09-10-2007, 06:30 PM   #4
dan-the-kid's Avatar
I bet as long as you can fit it in there part of the way, as to have metal is touching metal, I think you'll be good to go. At least for some "test" runs.
As for the ECU it self, get a Swedish chick sticker, like painted on that c900 valve cover, and paste your head on it. Then slap it on. I bet it will add more HP then your HOT ECU upgrade
dan-the-kid is offline
Old 09-10-2007, 06:55 PM   #5
mcrowley's Avatar
I think you're doing the right thing by waiting. Circuit boards tend to not like being tossed around inside a car. They also don't like crappy grounds.
Get it secured in there and grounded properly.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-10-2007, 07:38 PM   #6
saabkid37's Avatar
pfff you should see the cu in the honda. just chillin on the floor rollin around in the turns haha.
saabkid37 is offline
Old 09-10-2007, 08:29 PM   #7
NahumCC's Avatar
Actually I got a hold of Jak and he told me it was good to go. I love it. He gave me an aggresive tune for the t25 but since I got my td04 on yesterday I would guess it mellows it out some. Tomorrow I'll get the case taken care off and then install it in the bracket.
Jak thanks a million.
2013 FR-S
NahumCC is offline
Old 09-10-2007, 08:52 PM   #8
NahumCC's Avatar
Jak what would be your rough guess as to what power I have now until I can get it on a dyno.
2013 FR-S
NahumCC is offline
Old 09-10-2007, 09:22 PM   #9
Heath's Avatar
Hey congrats on the purchase!
Saabkid37.....my honda ecu slides around on my floor board also. Crome Pro all the way
Heath is offline
Old 09-11-2007, 03:23 AM   #10
jak
Im glad you like it man
it should be a pretty kick ass tune for a 15T5CM probably a tad agressive....
if you get a 6 cm housing it will be time for bigger injectors & a remap
lets see where the ECU settles in at in the taller gears & make a decision about wheather I should send another or not
Id like to see a slip on it as is though
too bad you arent closer we could run down to the shop I tune for
have a great week
JAK
jak is offline
Old 09-11-2007, 05:35 AM   #11
NahumCC's Avatar
I'm calling the local Ivy Tech school in Evansville today as they have a mustang dyno..........only car dyno in Evansville now. Otherwise I will have to make a trip upto Mt. Carmel, Illinois (about a 45 minute drive) as that is the next closest dyno other then Nick that I know of. The trick will be finding one that can data log the A/F for you Jak.
2013 FR-S
NahumCC is offline
Old 09-11-2007, 05:49 AM   #12
jak
the mustang will give a more conservative result then a dynojet will there is probably about a 11% difference +-
let me know how that goes....
hey! get some fresh plugs in that bad boy gap them down to .035 check them at every oil change & change them every 3 oil chnges
take care
JAK
jak is offline
Old 09-11-2007, 05:58 AM   #13
NahumCC's Avatar
I'll be doing that. Plugs were changed last oil change and I alway gap to .85 to .9 mm.
I have a few things to order from Nick here consisting of new crush washers for oil drain, oil feed line, and plugs. Once money comes in though.
However I do have a set of brand new T7 plugs that came in the tuning kits at SOC. Whats your opinion on those or should I just wait till I get new 7es11 from Nick.
2013 FR-S
NahumCC is offline
Old 09-11-2007, 06:16 AM   #14
StX221's Avatar
just go to the local napa or carquest and pick up the plugs. they should stock them. basically the same cost, no shipping and you get them the day you need them.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 09-11-2007, 06:44 AM   #15
NahumCC's Avatar
Nobody stocks them around here. Plus I prefer to support those that support saab and all my stuff shows up the next day when I order from Nick.
2013 FR-S
NahumCC is offline
Old 09-11-2007, 07:41 AM   #16
jak
dont use the plugs from the tuning kits they are 6EV or something
rong heat range & wrong material
if you have a fairly fresh set of 7ES in your car thats cool
if you get any missing at above 24PSI gap them down a little
I run 35PSI boost only & I have to gap to .026 & using the 8 heat range gapped that close the car runs like crap cold
take care
JAK
jak is offline
Old 09-11-2007, 07:48 AM   #17
StX221's Avatar
24psi on a stage 3...with a t25? even though nahum is going to the td-04. isnt expecting to see 24+ psi a tad bit high?
seems like 24 is what one might expect to see on a stage 4 with a td-04 going full out.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 09-11-2007, 07:56 AM   #18
moose's Avatar
thats what i get with my T25 and its the shit.
undercover Moderator
Stg. no go
moose is offline
Old 09-11-2007, 07:58 AM   #19
StX221's Avatar
15psi and 265whp has got me fooled then.
you t5 suckers should upgrade
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 09-11-2007, 08:18 AM   #20
mcrowley's Avatar
I'm pretty sure Nahum's got a TD04 on there now.
..and Nick don't be knockin T5. Last I checked it walked away from you on the way back from Carlisle
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
