Crazy Steering Rack Idea... - The Saab Link Forums
Old 08-14-2007, 05:28 AM   #1
liketheword's Avatar
So, the placement of our steering rack causes many handling woes. We have braces and bushings to make it more livable. Correct? Well why hasn't someone come-up w/ a way to mount it lower and make bracket to connect to the wheels at a lower point as well? IIRC the 9-5 has a lower mounted rack.. Why cant that just be adapted to suit our needs? Anyone else ever thought about this one...
Vitamin SAAB
liketheword is offline
Old 08-14-2007, 08:40 AM   #2
People got nothing on this one...?
Vitamin SAAB
Old 08-14-2007, 09:51 AM   #3
dan-the-kid's Avatar
I don't know much about the steering/suspension system, as that I don't know whats better having the rack in front, behind, or on top of the wheels.
It could be genius, but if it were some one would have done it already.
dan-the-kid is offline
Old 08-14-2007, 11:33 AM   #4
Not so... If it hasn't been done yet doesn't mean it isn't feasible. That kind of thinking will get you no-where fast.
Any contributions?
Vitamin SAAB
Old 08-14-2007, 12:13 PM   #5
JK
JK's Avatar
The only thing I can think of is that placing it lower would create a need for custom strut housings. If you were to make an adapter on the stock strut mount it would probably cause more flex and poor steering tendencies than the stock rack would.
You could do it though...it would just take lots of work for a one-off thing.
always a SAAB guy at heart
JK is offline
Old 08-14-2007, 12:54 PM   #6
Is there a reason stock 9-5 strut housings couldn't be used to achieve this setup?
Vitamin SAAB
Old 08-14-2007, 07:26 PM   #7
Bump... Could use a little more input guys..
Vitamin SAAB
Old 08-14-2007, 07:30 PM   #8
StX221's Avatar
9-5 struts will be 1)probably too long, and 2)definitely not the same setup. the 9-5 has a coilover type setup. spring over a macpherson strut.
iirc, the 9-3 has a different setup with a shock, and not a strut.
the other reason why the 9-5 steering setup is so good is that the rack is sandwiched (in the center of the rack), between the rear motor mount, and the subframe. it is locked in place, and not moveable. aka...no torque steer. but wheel hop city..
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-14-2007, 09:08 PM   #9
codesplice's Avatar
Unless my terminology is way, way off.... my car has a spring over a mcpherson strut. I don't have the 9-5 WIS to see if it's any different from the 9-5 though.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 08-14-2007, 09:10 PM   #10
JK
JK's Avatar
yeah, 9-3 certainly has a strut.
JK is offline
Old 08-15-2007, 04:48 AM   #11
stig's Avatar
What would be the benefit of having it mounted lower, other having the weight lower?
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 08-15-2007, 04:52 AM   #12
8valvegrowl's Avatar
There is no benefit to mounting it lower....only mounting it more rigidly and/or reducing the articulation points....a wider beefier rack with shorter end links would be an improvement. Or a massive bracing scheme to prevent firewall and rack movement.
Oh and 9-3's and 9-5's both have struts...but they are of completely different designs and in no way swappable. (Subframe design is different, control arm design is different, ball joint design is different....you get the idea...)
8valvegrowl is offline
