Oil Cooler Install - The Saab Link Forums
Old 08-01-2007, 09:15 PM   #1
Spoolin900SE's Avatar
Send a message via AIM to Spoolin900SE
Oil Cooler Install
Ok so my stock oil cooler cracked around one of the fittings, and I had planned on replacing it so I took this as the time. I went the route of stainless braided lines and AN fittings for several reasons.
Has anyone else that has installed an aftermarket cooler used the stock oil ports? (I do not want to use an oil filter spacing puck) If so what type of fittings did you use?
I used 20mmx1.5 to -10AN adapters. I wish Saab had used so simple fittings instead of the ones they did. I have tried pipe dope and Permatex thread sealant(which is meant to be great stuff) on throughly acetoned threads to seal them, but no luck. DRIP DRIP DRIP!
My next step is either welding AN fittings onto the stock steel pieces or pulling off the oil filter block and welding on my AN fittings.
Spoolin900SE is offline
Old 08-01-2007, 09:21 PM   #2
NahumCC's Avatar
Did you use a crush washer where the AN fittings go into the filter housing?
2013 FR-S
NahumCC is offline
Old 08-02-2007, 02:32 AM   #3
No, i was going to use an o-ring, but the fittings bottom out before the hex does. I might cut some threads off and try that.
Old 08-02-2007, 04:20 AM   #4
NahumCC's Avatar
Thats your issue right there. Send Marty a PM and he can find out what the actual thread pitch was. Almost sounds like its a M20x1.0 since M20x1.5 bottomed out before making a seal.
2013 FR-S
NahumCC is offline
Old 08-02-2007, 12:21 PM   #5
No, its the right thread pitch, the fittings screw in smotthly. The prob for using an o-ring is that there are more male threads than female, thats why i said i may cut some threads off of the fittings and try that.
Old 08-02-2007, 12:51 PM   #6
Here are some pics of it so far.
After i took this picture i realized the cooler was not leve; and fixed it.
The fittings that wont seal.
Old 08-02-2007, 02:01 PM   #7
Teflon tape?
Old 08-02-2007, 04:32 PM   #8
Makeyousaab's Avatar
Originally Posted by mike saunders View Post
Teflon tape?
YUP
~Dave
Makeyousaab is offline
Old 08-02-2007, 06:08 PM   #9
No the Permatex thread sealant has teflon in it and is meant to out perform the tape.
Old 08-02-2007, 07:00 PM   #10
NahumCC's Avatar
See I thought the pitch referred to the length of the threads from the tip to there base. Guess I was wrong. Have your tried stacking crush washers to solve this issue? I would love to do an oil cooler like that btw as I think what we have stock is trash and doesn't do its job sufficiently.
2013 FR-S
NahumCC is offline
Old 11-04-2007, 04:27 PM   #11
Spoolin, how did you end up fixing this?
~Dave
Old 11-04-2007, 04:31 PM   #12
Red DIC's Avatar
I hope you didn't pay too much for that oil cooler, that looks like one directly out of a 9k...
Red DIC is offline
Old 11-04-2007, 07:06 PM   #13
spanky's Avatar
Send a message via AIM to spanky
how much does an oil cooler help, and do the ng900 have then stock. i would look on my car but it is 400 miles away.
97-900se blk/blk 5speed, 2.3 aero motor, td04 18t......SOLD
92 dodge w250 cummins.....SOLD
97 900SE blk/blk, 5speed, TD04, upgraded fmic-----Back in the game
03 f250 CCSB Lariat 6.0
spanky is offline
Old 11-04-2007, 07:09 PM   #14
Red DIC's Avatar
NG's and 9-3s have them stock. Some members are concerned about them more than others, unless yours isn't working or your making ridiculous amounts of power, your money is better spent elsewhere.
Red DIC is offline
Old 11-04-2007, 08:57 PM   #15
NahumCC's Avatar
The problem I have with the stock ng900/og9-3 oil cooler is that its very thin size and its location (under the intercooler and out of any direct airflow) bothers me. A 9000 intercooler isn't much better sitting right behind the radiator in the engine bay.
I'd personally like to get an oil temp gauge running in my car sometime soon to start tracking oil temp numbers along with my pressure numbers to see where the stock oil cooler keeps things and then eventually switch to a good setup that has a nicer contact area and place it in a source of direct airflow.
2013 FR-S
NahumCC is offline
Old 11-05-2007, 03:08 AM   #16
mcrowley's Avatar
Except for n/a's.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 11-05-2007, 04:43 AM   #17
Red DIC's Avatar
Originally Posted by mcrowley View Post
Except for n/a's.
N/A's don't have them? you poor guy
07 Bmw turbos don't have them either.
Red DIC is offline
Old 11-05-2007, 04:53 AM   #18
M20 with 1.5mm pitch is the correct thread size. Please note that the hole is not "threaded" to the bottom and many pre-made nipples will "bottom-out" before seal surfcase meet.
One way to solve the matter is to shorten the nipple
http://www.npr.fi/~heikki/oilcooler/oilcooler-nipat.jpg
and to use copper seal for sealing
http://www.npr.fi/~heikki/oilcooler/...ler-nipat2.jpg
http://www.npr.fi/~heikki/oilcooler/...aikallaan1.jpg
Leg from 9000, but works with NG900 as well.
9-3 at least the T7 ones do not have threaded connections anymore.
http://www.npr.fi/~heikki/misc/oilcooler9-3b.jpg
Vigge is offline
Old 11-05-2007, 08:05 AM   #19
a12
a12's Avatar
Vigge:I have been wanting to do an oil cooler upgrade/replacement for a while and my 99 9-3 has the newer,non threaded style holes on that housing. Can I simply get one from a ng900 and bolt it on or is there anything else needed?
a12 is offline
Old 11-05-2007, 08:10 AM   #20
moose's Avatar
HAHAHA
like the install the SS lines look fancy.
undercover Moderator
Stg. no go
moose is offline
