A/C Delete - The Saab Link Forums
Old 07-18-2007, 01:43 PM   #1
codesplice's Avatar
A/C Delete
Tired of chasing down problems with my compressor, so I'm just gonna pull the shit and run a short belt.
What parts do I need and what else needs to be considered?
Gotta run to work - have some good answers for me in 5 hours or so
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 07-18-2007, 06:38 PM   #2
StX221's Avatar
splice, before you run and pull it all.
there are TONS of things that can cause the compressor not to kick on.
like for example, the a/c fan on my radiator seized up the other day. blew a fuse, and now the compressor wont kick on. EVERYTHING has to be perfect for it to work. a/c systems can be very fussy.
but if you can live without a/c, and dont want to track it down anymore, ditch it!
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 07-18-2007, 06:52 PM   #3
2k193turbo's Avatar
I wonder how much all of the AC stuff weighs?
2k193turbo is offline
Old 07-18-2007, 06:53 PM   #4
Not much.
My guess is less than 15-20lbs when its all said and done.
Jameson is offline
Old 07-18-2007, 07:03 PM   #5
my guess is closer to 30
mulletmaster is offline
Old 07-18-2007, 08:35 PM   #6
codesplice's Avatar
Aye, my buddy and I over at Meineke ran over pretty much everything that could cause an A/C system to not work. Spent about four hours dicking with it today with still no luck. Not to mention that I'm currently in the hottest part of AL's summer and I'm still alive - so I think I can adjust to it.
The weight isn't as big an issue to me as is the reduced drag (for lack of a better word) on the serp belt - plus removing the condenser would give me plenty of room for a nice ballin FMIC.
So does anyone have any input as to HOW to actually go about doing this?
Thanks.
2007 9-5 2.3T Wagon
Old 07-19-2007, 04:34 AM   #7
2k193turbo's Avatar
I haven't done it on a Saab but I've done it on other cars and it's pretty easy.
Dump the freon (in a legal manner of coarse), remove the compressor, condenser and lines, install the short belt and put whatever you had to take apart back together.
Try to keep the AC components in decent shape so that you can put them back in if needed (if you care about resale value).
Between the lighter weight and less parasitic drag I bet you'll feel the difference.
Old 07-19-2007, 09:15 AM   #8
Marks9-3's Avatar
Code, you're gonna be blown away at how much more room by your IC you will have without the condensor. I have all mine removed except the compressor.
Marks9-3 is offline
Old 07-19-2007, 09:28 AM   #9
codesplice's Avatar
Awesome, I'll probably do this not next week but the week after. Keep any tips and info coming my way
And Mark.... I love the sig. "Modded". lol
2007 9-5 2.3T Wagon
Old 07-19-2007, 09:32 AM   #10
Editor
I think that it won't be much of a performance modification, more like weight reduction. The pulley on the compressor doesn't put a huge load on it, not anywhere near as much as you'd think.
John, do research on belts. If you want a short belt, I've got one, and I'm almost positive it's for a 9-3. The number is : 6PK 2345. Please see this thread for information:
https://www.saablink.net/forum/showthread.php?t=19165
PM me if you're interested.
Les Bouquins is offline
Old 07-19-2007, 09:45 AM   #11
Editor
I had to hold this thing 6 ft. in the air when my car was on the lift, trying to get the engine bolted back in... after 10 - 15 seconds it becomes pretty damn heavy.
John, are you planning on getting rid of the condenser AND the compressor? That would be a decent chunk of mass! Doubt you'd notice it, though.
Old 07-19-2007, 09:45 AM   #12
codesplice's Avatar
Awesome Thom, thanks. I'll probably take you up on the offer as it gets closer to time to do this.
Yeah, I'll be removing both condenser and compressor
2007 9-5 2.3T Wagon
Old 07-19-2007, 10:04 AM   #13
2k193turbo's Avatar
Yeah, unless the compressor is under load there isn't much drag, but it all adds up.
I think the (very general) rule of thumb is 100lbs/10hp = 1/10th of a second in the 1/4 mile.
You might gain close to a 1/10th in the 1/4 by dumping your AC.
Old 07-19-2007, 05:33 PM   #14
I removed the condenser per Mark's advice, much better flow to the IC.
As for the belt, as long as you still have your stock pulleys intact this one will work.
https://www.saablink.net/forum/showth...highlight=belt
Old 07-19-2007, 07:32 PM   #15
codesplice's Avatar
Cool, thanks. I'm assuming that belt will also still work even if I do remove the compressor, yes? Good.
Thanks all for the input. I'm feeling much better about this project now
2007 9-5 2.3T Wagon
Old 07-19-2007, 07:41 PM   #16
saabsbreakdown's Avatar
Send a message via AIM to saabsbreakdown
Delete the compressor!!!! its the best mod EVAR
Car 178 - 1975 Saab 99 EMS
saabsbreakdown is offline
Old 07-19-2007, 07:44 PM   #17
codesplice's Avatar
Wrong. Installing a PA is the best mod ever.
Ask Thom.
2007 9-5 2.3T Wagon
Old 07-19-2007, 07:47 PM   #18
Ask Thom.
I've got a PA. It's called not having a roof and yelling at people.
Old 07-19-2007, 07:48 PM   #19
Omg Too Off Topic Quick Lets Edit All The Postes
Old 07-19-2007, 07:51 PM   #20
codesplice's Avatar
Omg Too Off Topic Quick Lets Edit All The Posts
*fixed
2007 9-5 2.3T Wagon
