Aftermarket sway bar - Not sway bar at all - The Saab Link Forums
Old 07-18-2007, 12:32 PM   #1
Ok well I got my sway bar in the mail today and went ahead and installed it. I wish I had looked at the rear suspension before ordering one. Because on a NG900 The sway bar is not hooked into the chassis. Which makes it completly pointless.
I dont know where everyone is getting this "Get a sway bar they make the car handle on rails" It virtually changes nothing. If anything its a rear axle stiffener. Does not affect roll in any way. Well there goes my money.
frostycrowd is offline
Old 07-18-2007, 12:33 PM   #2
Trollerator
abdukted1456's Avatar
I like the improvement on my car.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 07-18-2007, 12:34 PM   #3
I dont see how it can improve anything on a car if its not connected to the chassis.
Old 07-18-2007, 12:44 PM   #4
Champ's Avatar
It keeps the tires from travelling farther apart from each other than it would without it (think in corners when the car leans one way), and this in the end reduces body roll and keeps the car much more level, giving you more traction at the front tires.
Maybe you aren't driving it hard enough, grandma.
I noticed a difference on the 1997 NG 900 that I had a while back when I installed it.
Champ is offline
Old 07-18-2007, 12:47 PM   #5
Im not saying I went out and drove it hard around corners. I have barely taken it for a drive down my street. Just from the looks of it it seems like it can do very litt.e I got the "Race only" one and from weaving I noticed very little difference.
And would the huge solid rear end not do the same thing?
Old 07-18-2007, 12:49 PM   #6
Deez Nutz
Palmer's Avatar
So basically, you decided this before any type of meaningful test drive.
Therefore you have no basis for any sort of opinion.
Go do a "real" test drive, and come back.
The legions of happy owners cannot be wrong.
S55/LC100/KL
Palmer is offline
Old 07-18-2007, 12:50 PM   #7
b dash rian's Avatar
the sway bar keeps the rear axle from flexing, and in doing so, particularly with the "race only," will nearly eliminate that flex. Go into an open parking lot and start throwing the car around, you'll notice the difference
b dash rian is offline
Old 07-18-2007, 01:34 PM   #8
codesplice's Avatar
+1.
Give it a try before you let your superior automotive knowledge get in the way of proven experiences of hundreds of satisfied owners.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 07-18-2007, 01:39 PM   #9
basically what everyone is telling you is the sway bar keeps your saab from doing this.....
which pretty much nails it on the head. I dont really post much on here but I saw your rediculous statement and just had to rebut.
ricot83 is offline
Old 07-18-2007, 01:40 PM   #10
codesplice's Avatar
^^ lol
2007 9-5 2.3T Wagon
Old 07-18-2007, 02:24 PM   #11
and on your good ole Jeep, the sway bars are linked to the chassis.
Old 07-18-2007, 02:35 PM   #12
VWSAABVT's Avatar
cool, now go drive your Saab, and if you don't like your new part send it to me
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 07-18-2007, 02:39 PM   #13
Champ's Avatar
What's your hangup? The sway bar doesn't need to be hooked to the chassis to work as intended.
From Wikipedia:
A sway bar (also stabilizer bar, anti-sway bar, roll bar, or anti-roll bar, ARB) is an automobile suspension device. It connects opposite (left/right) wheels together through short lever arms linked by a torsion spring. A sway bar increases the suspension's roll stiffness -- its resistance to roll in turns, independent of its spring rate in the vertical direction.
It works to connect the rear tires together, not allowing them to roll the car. The thicker sway bar does this. The chassis has nothing to do with it. You are the only person to ever not notice the difference. Go and test drive, then complain after.
Champ is offline
Old 07-18-2007, 02:42 PM   #14
liketheword's Avatar
Adding the 22mm RARB made quite a difference on my car! I know several others who have said the same. It's not like the part will change your life but it will change the handling characteristics of your car.
Vitamin SAAB
liketheword is offline
Old 07-18-2007, 02:47 PM   #15
NickTurbo900's Avatar
The difference is significant. Slap some wide, sticky tires on there and go find some onramps at 60 mph.
Then come back and tell us!
NickTurbo900 is offline
Old 07-18-2007, 02:57 PM   #16
Drew in Houston's Avatar
I have the 22mm bar and I have to say I was disappointed. I'm not a racecar driver for sure, but when you take it to the limit the car still understeers like a pig. You have to be doing something really ridiculous to get even a hint of oversteer out of it. Neutral drift? Bah forget about it.
If I were going to do it over again I'd probably save my money.
Although now that I'm thinking about it, I should probably try things with a few psi less in the rears and see what that feels like.
edit: Frosty, what psi are you running front/back, and what are the condition of your tires?
Drew in Houston is offline
Old 07-18-2007, 03:26 PM   #17
Drew the rate at which you let off the throttle will also help the car rotate. In autox situations, I let HARD off of the throttle, punch the brake real quick and turn...this allows the car to step out and rotate.
It's not easy to do.
But fun...
Topher is offline
Old 07-18-2007, 03:31 PM   #18
Welcome to driving a front wheel drive car. Understeer is part of it. And you dont have to be doing something too ridiculous to get oversteer, try a Scandinavian whip, even if you do it by accident, its not ridiculous, but will certainly induce your beloved oversteer. Then try the same with a 9-3 without a rear sway bar. You WILL feel the difference. On ramps are noticably better, with much less rear end "flop" so to speak.
Old 07-18-2007, 03:49 PM   #19
What is this?
just to show I tried:
http://www.google.com/search?q=Scand...ient=firefox-a
Old 07-18-2007, 03:51 PM   #20
Its actually called the Scandinavian Flick..
http://www.tcsracing.org/scandinavianflick.htm
http://video.google.com/videoplay?do...66053826889673
Aero02 is offline
