Unhappy Viggen part 2 - The Saab Link Forums
Old 07-18-2007, 08:58 AM   #1
So I started a new thread because the plugs are taken care of. I found a gapper that I had in an old tool box. It had 1.02mm so I used that.
Went for an adaption run and saw a nice 17psi then a pop and car died. Ruh-roh. Pop the hood and the bpv hose was blown clean off. Popped it back on and all was well.
I knew what had happened. Its happened before. My delivery pipe nipple caves in on itself under high boost and allows the hose to come off. THis time I took a pic to show you. IN the past while its hot I insert the handle of a screw driver to reform it and allow it to cool. But this seems to keep happening. The car is sure boosting good though
I wonder if there is anything I can do, even tempted to do an aluminum delivery pipe. This is annoying.
Jameson is offline
Old 07-18-2007, 09:02 AM   #2
So my first idea was to the black nipple off the DP is so smooth, perhaps scuffing it up with a 60gritt sanding block would give it more bite to have the hose stay on.
Jameson is offline
Old 07-18-2007, 09:19 AM   #3
Champ's Avatar
Super glue.
Kidding, but what about cutting a little piece of aluminum tubing and glueing it inside that nipple?
Champ is offline
Old 07-18-2007, 09:21 AM   #4
Moonracer's Avatar
Find a metal bushing to insert in the tube. Then when you clamp it down it won't collapse.
Moonracer is offline
Old 07-18-2007, 09:24 AM   #5
Can that get sucked in though? That sounds kinda risky.
Jameson is offline
Old 07-18-2007, 09:25 AM   #6
Originally Posted by Champ View Post
Super glue.
Might work, just worried about it hurting flow.
Jameson is offline
Old 07-18-2007, 09:26 AM   #7
lms
What he said ^^^^^Find a piece of pipe (aluminum, SS, etc) that will slide in that opening super tight-maybe glue. Cut to size and it will not collapse anymore. Try to find a very thin piece and make sure it does not go into the delivery pipe. Then clamp with constant torque clamp.
lms is offline
Old 07-18-2007, 09:32 AM   #8
Trollerator
abdukted1456's Avatar
or you could plug the BPV right in, instead of using a silicone or rubber tube there (not sure if you are or not). it would be harder to remove it but it would keep the nipple thingie from collapsing.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 07-18-2007, 09:48 AM   #9
Champ's Avatar
Epoxy
Champ is offline
Old 07-18-2007, 09:53 AM   #10
Deez Nutz
Palmer's Avatar
Epoxy is no joke.
I would think it would be easy enough to find a tube or something to put in there..
S55/LC100/KL
Palmer is offline
Old 07-18-2007, 09:58 AM   #11
dan-the-kid's Avatar
Why not heat up the nipple then quickly put the BPV back on, like to melt them together? Or heat up the outside of the BPV at the connector to the intake.
dan-the-kid is offline
Old 07-18-2007, 09:59 AM   #12
Azrael's Avatar
How about some PVC with PVC cement? That ought to hold up just fine.
Originally Posted by Hirsch
If you grab a tiger by its tail, you better be prepared to deal with the fucking fangs on the other end.
Azrael is offline
Old 07-18-2007, 10:02 AM   #13
I can't believe that you don't have a SS or some kind of metal delivery pipe especially with your mods on your Viggen.
Old 07-18-2007, 10:08 AM   #14
Moonracer's Avatar
I believe if you look inside the tube there is a step to keep anything from goin inside the tube.
Old 07-18-2007, 10:42 AM   #15
Aluminum/SS delivery pipes have been shown to cause more damage than good up to/around 400hp where the airflow becomes a restriction. Until that point, the plastic stays cooler than aluminum/SS and as such performs better.
Aero02 is offline
Old 07-18-2007, 10:48 AM   #16
NOOB
The stock delivery pipe is good to 400hp.
Jameson is offline
Old 07-18-2007, 10:49 AM   #17
Hmm, is that possible? That could solve the problem. I am using blue Silicone right now I got from Nick T.
Jameson is offline
Old 07-18-2007, 10:50 AM   #18
PVC is thick and would certainly cause an air restriction. The DP outlet is only about 1-1.2" in diameter.
Jameson is offline
Old 07-18-2007, 10:51 AM   #19
I have tried heat to the outlet of the delivery pipe and then expanded it to allow it to cool. But once it gets hot again it deforms.
Jameson is offline
Old 07-18-2007, 10:54 AM   #20
saab4life93t's Avatar
i could see thiss as being really anoying lol... give nick at gs a call get a nice ss or aluminum delivery pipe for it...
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
