NOS?? - The Saab Link Forums
Old 08-26-2004, 12:56 AM   #1
NOS??
Can a nitrous system be added to the 99-02 saabs? Has anyone done this mod and if so, any data collected on performance increases?
blackonblack93 is offline
Old 08-26-2004, 11:41 AM   #2
NOS can be added to most cars, NA or turbo.
The real question is whether it can be added safely. The guys at the shop wil say, "No problem. An easy 50 horses and your car stays safe."
That's probably true the first few times you run NOS, but gas is as addictive as crack and a few bottles later you'll be at a stoplight revving against some musclehead's Mustang. You'll step on the gas and you'll feel the familiar torque rush and BANG!...the sickening sound of a wayward piston driving itself though a cylinder wall.
So....if your car isn't a daily driver, then go for it. If you need your ride for essential transportation, then stick with the turbo...
Plus, as the saying goes, you'll still be boosting when the other guy's bottle runs out...
Old 08-26-2004, 03:53 PM   #3
trexturk's Avatar
Send a message via AIM to trexturk
You can install nitrous on your car.
Just make sure you get the kit that sprays nitrous and fuel throught 2 seperate lines into the same nozzle. If you look at the ZEX kits, it relies on the cars computer to add the extra fuel.
Also, any setup you do is safe as long as its done right with the correct jets in.
I was also considering getting a kit and had an idea.
Get the kit, spray into the throttle body up top. Then get a purge set-up and spray on the intercooler, in front of it to cool it down.
Just an idea
Now: 04 Nogaro S4
Past: 99 Stage 4 9-3
trexturk is offline
Old 08-26-2004, 05:30 PM   #4
HNNLIC
Blaque's Avatar
I'm currently looking at nitrous as well...actually the ZEX kits like trex was talking about.
From what i've heard, the best and safest way to use Nitrous is to use a wet system that mixes the correct amount with the fuel. They have extrememly safe kits nowadays that mix the correct amount of Nitrous with a given amount of fuel so there's no issue of detonation.
Blaque is offline
Old 08-26-2004, 05:58 PM   #5
trexturk's Avatar
Like you were saying, its true.
Thats why there is the jets that fit inside the nozzles. I can't remember if the nitrous jet is begger then the fuel, or vise versa.
I also hear that the wet system is the best for turbo cars
Now: 04 Nogaro S4
trexturk is offline
Old 08-26-2004, 08:43 PM   #6
There are definitely safe ways of adding nitrous, but really, no sane person adds nitrous to a daily driver. Unless, of course, you plan on upgrading your engine internals, or you can source a donor engine that you can build from the bottom end up.
If that was the case......If you knew you had a rock-solid engine, then why not?
You can easily handle a wet 50-shot without much trouble, possibly even a 75 or 100....
But, be VERY CAREFUL adding nitrous to an engine with an upgraded ECU that's already playing on the knife edge of EGTs and A/F ratios. The performance gains in ECU mods come, in part, by shaving off the built-in safety margin of the factory ECU. Adding nitrous presses you further along the knife edge...
Old 08-26-2004, 08:59 PM   #7
Old 08-27-2004, 12:52 AM   #8
Nitrous
Thanks for all the input on the addition of nitrous. My friend runs a 100 shot, wet nitrous kit in his S60t and absolutely loves it. He has it set up to spray at WOT only. He generally uses the spray at the drag strip only but on occasion has the urge to put away a porsche or two
Old 08-27-2004, 01:33 AM   #9
Administrator
bollman's Avatar
Send a message via ICQ to bollman Send a message via AIM to bollman
I would strongly discourage the use of NOS, at least at T7-engines with standard pistons. They seldom withstand more than 300hp and with NOS you will probably get one shot sooner rather than later...
bollman is offline
Old 08-29-2004, 12:50 PM   #10
DC_SAAB's Avatar
Posted: Fri Aug 27, 2004 9:33 am Post subject:
gonna have to go with the bollman on this one....in all cases.
you have to have a pre-rich mixture during injection of NOS to prevent torching those pistons, and pinging that bad-ass SAAB to death. otherwise it might not even be cost effective considering you have to keep replacing NOS..as compared to building the car up with the right components to get that hp your wishing for.
You might find a kit for $300, plus cost for getting it installed for about the same, and buying the bottle of NOS for just 50hp. Starts to add up after a few replacement bottles, especially when you consider, what it's doing to your engine.
Change/upgrade the ECU, filtration, and exhaust will probably result in better numbers and you'll appreciate it more without the head-ache of blowing up your car from experimenting with NOS.
There's more cost effective yet reliable means to increase power than using NOS. I suppose if your alreay raced-built, and ready for the big leagues my point is a mute one.
hope you make the right decision..., but good luck either way.
DC
DC_SAAB is offline
Old 06-13-2006, 11:32 AM   #11
stevehayes01's Avatar
Ok I am going to dig this thread up..... Can anyone show any cases good or bad about NOS use on a SAAB?
Allot of guys use a 35HP shot to spool the turbo quicker on launch in boosted applications. Just curious who has actually run a system on their saab and what the results where.
stevehayes01 is offline
Old 06-13-2006, 12:17 PM   #12
Trollerator
abdukted1456's Avatar
it sounds like an inane idea to me. (and not like "dude... insane!"... like really insane)
I would consider using it to chill the exterior of th eIC to icy temps though
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 06-13-2006, 12:20 PM   #13
Makeyousaab's Avatar
I can't say whether or not the NOS works well with our cars or at all, i know our Engine management system is more advanced than alot of cars that use NOs.....but one thing I do know is that using NOs is a violation of your insurance company's policy. It's also illegal to have it "turned on' which just means that the valve to the bottle must be closed on the street. But if you crash your car and you're running nitrous the insurance company won't pay for a thing.
~Dave
Makeyousaab is offline
Old 06-13-2006, 12:37 PM   #14
Ok abdukted I knew you would think it crazy......
And as for the insurance well thats a completlty different discussion but the use of NOS on a street car is regulated state to state and as far as I know there is no federal law against it. Here is Fl. I see cars all the time at the "local hangouts" (SONIC) with full NOS kits installed with the cops just hanging out and checking out the rides and the kits. If it was that big of a deal here they would be writing tickets.
As for NOS on a boosted motor here is what ZEX has to say about it....
Q: What is the difference between a "wet" nitrous kit and a "dry" nitrous kit?
A: A wet nitrous kit mixes nitrous and enrichment fuel by means of an injector nozzle that is mounted before the throttle body. This mixture is then drawn into the engine through the throttle body and intake manifold. A "dry" nitrous kit injects only nitrous with it’s injector while at the same time, increasing the engine’s fuel rail pressure to feed enrichment fuel through the engine’s own injectors.
Q: What is better, a "wet" or "dry" kit?
A: It all depends on the application. A "wet" kit is ideal for both normally aspirated applications as well as forced induction applications. It can require a little bit more installation time than a "dry" kit, but is easier to tune if greater than stock HP settings are to be experimented with. A "dry" kit is excellent for normally aspirated combinations that have a return style fuel system. They are very easy to install and are a great "first time" nitrous system. It is not recommended that "dry" systems be used on forced induction engines.
Q: Will nitrous affect engine reliability?
A: As long as the nitrous system is installed per the instructions and the set-up procedures are followed, there is usually not any increase in engine wear.
The bad part.....
Q: Can I have a performance "chip" in my ECU while using my nitrous system?
A: Generally the answer is NO. Most performance "chips" on the market advance ignition timing to gain additional horsepower. This additional timing, when using nitrous, can cause engine damaging detonation. The only exception to this are "chips" that have been specifically programmed for nitrous use.
Old 06-13-2006, 12:43 PM   #15
From Nitrous Express....
Q. Are there any dangers or things to stay away from while using nitrous?
A. Of course, NX recommends that no more than an additional 20 horsepower per cylinder be used on a stock engine, with a stock fuel pump. Always be sure you are using clean, uncontaminated nitrous. Also, be sure you have the highest octane fuel available, I.E. 93 octane premium for, stock compression, street cars and the highest motor octane fuel available for competition type vehicles.
Q. Is there a trade off for engine reliability and power produced with nitrous?
A. When used according to factory recommendations, shortened engine life should not be a concern.
Q. Does nitrous increase cylinder temperatures and combustion chamber pressure?
A. No, cylinder temperatures should stay the same when the correct nitrous air/fuel ratio is used. Yes, increased cylinder pressure equals increased horsepower.
Q. Can I use nitrous on my high compression engine?
A. Yes, but the proper octane fuel must be used to prevent detonation.
Q. Can I use nitrous on my turbo or supercharged vehicle?
A. Yes, NX specializes in turbo-supercharged nitrous applications.
Q. Why does nitrous have such a scary reputation?
A. There has been some very shoddy nitrous "kits" sold to unsuspecting customers over the last 20 years; this along with the abuse nitrous has suffered from "idiots" who damage their own engines.
