GS poly transmission mount AUTOMATIC - The Saab Link Forums
Old 06-20-2007, 05:36 AM   #1
Trollerator
abdukted1456's Avatar
this piece is truly impressive on sheer looks alone. and the contruction is top notch. it is SOLID and full of firm poly.
after having gone through 2 OEM mounts at only 64K miles, I decided this was worth looking into. Also at stage 3+ it just makes sense.
after driving the car with this installed, I noticed a crisper throttle response. Also I noticed that the car felt FASTER... like as if before the engine and transmission just did not make contact as much or something. the car jus really wants to move immediately now, and I feel like it is putting more power where it belongs... there is some vibration in the cabin, but it is not much to speak of since already having the car on lowering springs, poly control arm bushings, poly arb bushings, and half firm set koni shocks. it just shifts nicer and more solid. I guess that is the best way to sum it up, the car feels so much more solid.
I absolutely reccomend this for even a mildly tuned automatic. i broke my first OEM mount on stock software at 20K miles and the one I just replaced with this poly mount was dry-rotted with about 40K on it.
A+++++++ to genuinesaab.com on this product
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 06-20-2007, 05:41 AM   #2
soccerrplyr's Avatar
I just put mine on yesterday. Two of the three rubber stabilizers were cracked all the way through and the third was half way on the oem one. Yours in the pic looks cleaner than the one i got though. It had lots of small bubbles and the top section had lots of deeper scrapes like it had been used. Its all aesthetics though and hidden when installed so i didn't make a big deal of it and call nick at genuine saab
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 06-20-2007, 05:52 AM   #3
Red DIC's Avatar
how hard was this to install? Though im not an auto driver
Red DIC is offline
Old 06-20-2007, 05:54 AM   #4
Trollerator
I had my mechanic put it on when he was adjusting my exhuast. it sounds easy, but with a sucky floor jack, and a car that is so low I can barely even get the jack under the car to begin with, I just had him throw it on there for me.
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 05:54 AM   #5
it takes longer to jack the car up and get a good clearance to work under. There are 4 16 mm bolts to unscrew. That's it, although the two horizontal bolts are hard to get at and screw/unscrew
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 06-20-2007, 05:56 AM   #6
Red DIC's Avatar
i believe i need both mounts, but wasn't sure how much of a bitch it was to o them.
Red DIC is offline
Old 06-20-2007, 05:58 AM   #7
NahumCC's Avatar
I could use both mounts as well..............My 9000 must hate me right now getting neglected under my mothers right foot (its light as a feather). The 9000 needs all 5 mounts (both lowers, both torques, and trans).
2013 FR-S
NahumCC is offline
Old 06-20-2007, 05:58 AM   #8
mcrowley's Avatar
Nice! That looks like a fairly substantial piece.
How'd the exhaust work out?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-20-2007, 05:59 AM   #9
Trollerator
Mike: Scott got it dead center no problem. I will be seeing him more often I think
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 06:00 AM   #10
Trollerator
swivel socket
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 06:02 AM   #11
It was my wrench that was of an off size that causes short turns before it hit things
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 06-20-2007, 06:05 AM   #12
mcrowley's Avatar
Told ya dude
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-20-2007, 06:20 AM   #13
Trollerator
we also talked about making my car a 5 speed
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 07:47 AM   #14
mcrowley's Avatar
Now that would be a fun project.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-20-2007, 07:51 AM   #15
Trollerator
if I had money, yes , yes it would.
those guys at RL smith are real nice.
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 09:33 AM   #16
mcrowley's Avatar
Yeah.
Thursday night last week I stopped by when they were doing an oil change on an old 70's Maserati....which held 12 quarts of oil.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-20-2007, 11:34 AM   #17
Editor
And what did they say about that? I'm curious.
Les Bouquins is offline
Old 06-20-2007, 11:43 AM   #18
Trollerator
most of the $$ would be labor. they seem to think it's doable. for not much more than the cost of a rebuilt automatic plus labor.
parts:
ecu
wiring harnesses
pedals
clutch
flywheel
transmission
mounts
shifter/linkage
instrument cluster
i think there is more i am forgetting obviously little bits and bolts
to me the sticking point would be if I could get my ecu reflashed for cheap or if nordic/GS would make me buy a whole new ECU for a 5 speed.
also, i don't have a few grand lying around to experiment with this right now
the car is pretty quick already, I have been meaning to get a video....
1990 900 turbo vert
2004 9-5 aero sedan
Old 06-20-2007, 01:15 PM   #19
Red DIC's Avatar
I highly doubt they'd make you pay $500, prob just a reflash, all they're doing is loading files onto it.
Red DIC is offline
Old 06-20-2007, 01:16 PM   #20
parts:
ecu
wiring harnesses
pedals
clutch
flywheel
transmission
mounts
shifter/linkage
instrument cluster
I paid $240 for an ECU reflash. I doubt it would be any different in your case.
Jameson is offline
