Trionic 7 - The Saab Link Forums
Old 07-22-2004, 03:12 PM   #1
Trionic 7
New Topic for the "Intricacies of Trionic 7" ... lol As best I can explain them. Whether anyone is right or wrong, let's have a discussion and not barge into Kevin Y's thread. :P
I will start making posts on it in a sec. Gonna send a few thread's discussions here first.
Adrian~
SaabTuner is offline
Old 07-22-2004, 03:37 PM   #2
"By "shape of the airflow" do you mean the density and rate at which it passes the hot wire? If not, what does this mean? If so, how would either of these throw off the readings when the MAF sensor is measuring the mass of the air? The air has a mass regardless of the manner in which it passes the hot wire and I don't see how opening would change things. How is opening the intake any different in regards to VE than a difference in outside air temp or elevation? There are always going to be slight variations in VE if this is the case. If it is not the case, changing the ease of which air reaches the turbo (not changing the amount of air that can pass through the intake AFTER the turbo) should not have an effect on the VE either. The fact that the turbo doesnt have to work as hard to reach a target boost does not change anything in the engine. It only changes the rate at which the turbo spools. Is this a change in VE if T7 is constantly varying boost regardless of turbo effort?"
The airflow over the wire may not be uniform. Imagine if ALL of the air somehow (not possible) goes AROUND the hot wire that is used to measure the airflow. It would not know about the air it does not "touch" and it depends on the uniformity of the flow for its calculations on airflow to work.
That being said, the screen over the front of it SHOULD make the airflow uniform and keep it accurate. (Though the oil from the filter has been known to cause problems.) But it could cause small changes which could make it run either richer OR leaner. It's up to you. I found that a clean filter helped as much as a performance one.
That's also a GOOD reason NOT to remove that screen. You can remove it on the C900's with the Bosch Jetronic. It can cause very bad readings sometimes.
"So, Adrian, should I have anything to worry about if I'm bypassing the MAF sensor and using the T5 intake and throttle body in putting a B205R into a 97 SET?
I'm still planning to the use the T5 ECU, but with an eventual Stage 4 SQR upgrade..."
The MAF sensor is only important if you are using the T7 engine management system.
However there are a number of mechanical differences between the B205 and B204 ... not the least of which is a better flowing head on the B205R. The B205R also has weaker pistons than the B204, and longer connecting rods.
The B205R HEAD on a B204 block would be nice. The B205R has Nimonic exhaust valves and a very good flowing head, but with very BAD camshafts. (Though the cams are very good for spool up, it's the exhaust cam that's particularly bad for outright power.) So with better cams the Nimonic valves and good flowing ports it would not only be tolerant of higher EGT, but it would also generate more hp.
Of course the B205 block's rods and pistons are also lighter than the B204, which means they get better mileage, however since you're going for a MapTun stage 4 I'd use the B204 block if available. Or I would upgrade the pistons.
Specs for various differences between the two:
B204L
Weight: 340 lbs
Rod length: 153 mm
Inlet Cam specs: 240 Duration and .341" Lift
Exhaust Cam specs: 240 Duration and .341" Lift
B205R
Weight: 346 lbs (B235R actually only weighs 2 lbs more)
Rod Length: 159 mm (B235R uses same length as B204L)
Inlet Cam specs: 231 Duration and .327" Lift
Exhaust Cam specs: 228 Duration and .318" Lift
The longer con rods in the B205R actually cause you to NEED shorter (and thus weaker, but lighter) pistons. Very good if you want to rev the pants off it, but not particularly good if you want to up the boost a ton.
I think they maaaaay be stronger than the B235R's pistons, but don't quote me on that. Not completely sure, they should be slightly taller, which would make them slightly stronger.
Interesting project though, the B205R is stil a very good motor, with some aftermarket forged pistons it should have no trouble reaching 400+ hp.
Adrian~
Old 07-22-2004, 04:14 PM   #3
Many thanks for the detailed info...
I'm not planning to go past 300hp, so I'll probably keep the engine internals semi-virginal for now. Of course, if and when I need a head gasket, all bets are off. (Although, I'll have the cams from the B204 just sitting around...)
Many of the folks I've talked to about this project recommended upgrading to a T7 to go along with the engine. Some cited limited upgradability of the T7 software; others were worried that the since T7 has many more data-collection points than T5, it would be a nightmare to try to mate it to a T5 car...
Old 07-22-2004, 04:32 PM   #4
Thanks for the "shape" explaination. In a 9-3 application where the filter often attaches directly to the MAF sensor, I can see where problems could arise. In the CAI setup designed for T7 9-3's and also in the intake for the 9-5 this would not be a problem as the air would have traveled up a tube mixing to uniformity prior to reaching the MAF sensor.
Also, I still do not understand if or how opening the intake to the turbo would change VE if the overall volume of the intake system after the MAF was not changed....after all, the amount of air entering the engine would not change as is the case with an exhaust where the amount of exhaust gas leaving the engine does change.
xaamottomaax is offline
Old 07-22-2004, 04:36 PM   #5
"ive got a follow up question for that:
You were saying that the sensors are conflicting, and thus making alot of bolt on mods useless. If you upgrade your ECU software to say... stage 2 then add a bunch more bolt on mods will the ECU still do the same thing it does as stock and adjust the fuel/ air mix to produce the programed HP? or will it run lean?" Boxerchip
Unfortunately (or perhaps fortunately) most of the aftermarket sofware works in much the same fashion on a reprogrammed version of T7 as it does on stock T7. (At least to my knowledge.) Similarly with T5.
Any bolt on mod the ECU is not programmed for on any engine management system CAN cause problems. Usually it's no big deal, but sometimes it is.
As far as the sensors being in conflict, that's the best way I can explain T7 adapting DOWN. Even if the sensors are NOT in conflict it will not increase power very much. You will still get the same milligrams/combustion because of how T7 is designed, but you may reduce pumping losses slightly. (Which are unrelated, and affect mileage more than power.)
Trionic's theory was based off the O2 sensor giving bad feedback during a closed loop Multiplicative adaption window. But while those are common (30 seconds of every 5 minutes) they cannot occur during open loop.
And as even Mark E pointed out, in order for the ECU to make a multiplicative adaption it would need to first start to run a little leaner, or richer, than usual. And this should not happen because the Mass AirFlow sensor itself should still meter the fuel in exactly the same way, mods or not. So if it does not run too lean during a cruising closed loop multiplicative adaption window, it should not adapt badly.
Also, it only allows a 25% adaption before throwing a code.
Nick T is currently watching his modified stage 1 Viggen to see what sort of Multiplicative adaptions his vehicle registers. He's currently at 7% or so, but some adaption is normal.
Strangely, Tionic states that the MAP sensor is not used for anything but a backup. Nick T just got 18% as an "airmass correction" based on the MAP sensor data vs. the MAF sensor data. That means the ECU is "keeping track" of the difference between MAP data and MAF data. I would assume this is for more than just backup. Otherwise if there were a problem with the MAF sensor the MAP sensor would be totally useless as a "backup" because the airmass correction would possibly have corrupted the values stored in the ECU for the MAP system. No one ever makes a backup system dependant on the functionality of the main system. To do so is just bad engineering.
Anyhow ... we will see how things work out soon I hope. I don't mind being wrong at all. I just want it to make sense! For goodness sake then Navier-Stokes fluid dynamics equation is simpler than this! Even in Tripple Partial integral form.
Adrian~
Old 07-22-2004, 05:10 PM   #6
"Also, I still do not understand if or how opening the intake to the turbo would change VE if the overall volume of the intake system after the MAF was not changed....after all, the amount of air entering the engine would not change as is the case with an exhaust where the amount of exhaust gas leaving the engine does change."
But, if it's easier for the turbo to pull air in, it doesn't have to work as hard, if it doesn't have to work as hard it reduces the backpressure by opening the wastegate. This reduces backpressure quite a bit and increases the exhaust scavenging ... more exhaust scavenging means more intake gasses getting into the engine even at the SAME boost pressure. (that's what happens when the VE changes)
So then it changes the VE ... just a lot LESS than an exhaust. It shouldn't be a problem, I ran a ghetto autozone airfilter on the dyno with my car, it adapted upwards with each run!
Things like air filters cause such a small change that it should not affect anything. I'm just saying to be careful!
Ionly want to make the point that any mod CAN cause problems, some don't.
Adrian~
Old 07-22-2004, 05:26 PM   #7
point well taken...and good explaination on the turbo's effort influencing backpressure. In my case where the exhaust system is maxed out and fighting to squeeze the extra boost of the stage 1 through the stock exhaust setup, the intake might be a nice benefit helping to lower EGT's by reducing back pressure...although not to the point of exhaust scavenging.
Old 07-22-2004, 05:38 PM   #8
It wouldn't lower it much, but you're right it probably would lower the EGT a little, as long as it does not run lean.
See, now you're thinking.
A water sprayer on the OUTSIDE of the intercooler (like the EVO and STi) will make charge air temps cooler in warm weather, and that actually lowers EGT too.
Usually the EGT drops about the same level as the intake temp. 20 less degrees for intake, and 20 less for exhaust.
Not a big change, but just thought I'd tell ya.
Adrian~
Old 07-22-2004, 06:22 PM   #9
During rapid load changes, the engine load or calculated air mass/combustion based on mass airflow sensor value can differ from the actual mass being taken into the cyllinder during the induction stroke. This is due to the inertia of the large volume of air present in the intake system. The intake pressure is therefore used to correct the air mass/combustion used in the basic calculation of fuel quantity
Perhaps the intake pressure correction mentioned is performed at the throttle body and not at the turbo/wastegate therefore it is not technically a boost control adaptation but a knock safeguard attempting to reduce airflow into the manifold. With this scenario the MTB would react to the discrepency between the MAF and MAP and not the turbo.
Old 07-22-2004, 09:21 PM   #10
Noooo no. What I mean is that in order for the engine to calculate what amount of fuel to put in, it needs to know how much air soooo ...
When you first open the throttle, the air goes from throttle to intake ports quickly, but the Mass AirFlow sensor doesn't read anything YET because it sits very far away from the throttle.
That would cause it to run lean for a second until the MAF sensor "caught up" ... so they use a MAP sensor which is connected straight to the manifold to correct the value that the MAF sensor is reading. The value is then expressed as milligrams/combust and then used for fuelling. The reverse happens when you quickly let off the throttle.
Now you go and put an exhaust on it, and the VE changes. So the calculated value the MAP reads and uses to correct the MAF is no longer correct. That means the correction in milligrams/combust under quick load changes in inaccurate.
The engine may also continue correcting until the values are the same (or within a certain tolerance). If the values never approach eachother again due to modified exhaust it may not stop correcting. Or it may take a long time, or some other problem.
When two sensors designed to measure/calculate the same thing read very differently bad things tend to happen.
Sorry if I sound like I'm repeating myself.
Adrian~
Old 07-23-2004, 10:04 AM   #11
It seems from reading the excerpt from WIS that the MAP sensor value is only used for the fuel quantity calculation when there is a discrepency between the MAP and MAF sensors. All other times the MAF sensor is strictly responsible for fuel calculations. If this is the case, adding an exhaust would cause a constant discrepency therefore involving the MAP sensor in the calculation at all times. If the MAP sensor is then being used to calculate fuel quantity at all times due to the change in VE and the sensor discrepency that insues, wouldnt the change in VE be accompanied by more fuel to compensate for the extra air coming into the engine, therefore increasing power above stock levels? What causes the downward adaptation? Is it a fuel cut? Is it opening of the wastegate? Is it closing off the throttle body? What is the engine doing to adapt down when logic tells us the MAP sensor reading should be over riding the MAF sensor reading and the engine should be providing more fuel to compensate for the extra air in the engine not accounted for by the MAF sensor (and providing MORE power over stock)?
Old 07-23-2004, 12:43 PM   #12
Firstly the WIS is not explicit in exactly what defines a "rapid load change" ... so even if there is a discrepency between the MAF and MAP, it may only use the MAP for a correction factor when the throttle angle is a certain percent, or the load request (pedal potentiometer) changes at a certain rate.
Secondly, adding fuel actually causes a DROP in power. That's part of where the downward adaptation comes into play.
On Nick T's car the 18% airmass correction between MAP and MAF readings tells me that the ECU may be using the difference between the two values when cruising and applying it at full throttle. That should theoreticaly FIX the problem, except that the change in VE at part throttle may not apply to full throttle, and different RPM bands.
Coincidentally though, Nick T does not seem to have any downward adaption. It's possible (though not likely) that the downward adaption was "fixed" after the '99 model year. (Nick has a 2000 I believe)
Still a number of things that are uncertain, but I still can't see where Tionic's theory fits into any of this, and I am trying to. The O2 sensor's readings shouldn't be affected by modifications to anything but the fuel system, and the O2 sensor itself. Oh well.
You're on the right track with the idea that the MAP sensor may be getting used all the time instead of MAF. Even if I think it may have some other factor to determine when it's used, I was suspicious of that as well.
Adrian~
Old 07-24-2004, 06:40 AM   #13
The downward adaptation sounds as if it is an overcompensation of fuel in order to create a rich fuel mixture so knock will not occur while the MAF sensor is "catching up" to the MAP sensor or while there is a discrepency between MAP and MAF readings. Is this accurate?
Old 07-24-2004, 11:33 PM   #14
I think you're getting the idea, but remember that a modded exhaust will make the MAP part of the program run lean rather than rich.
Still not exactly sure on what's going on with it, but I think it may run lean enough during spool up to cause knock, which will cause the timing to be pulled back, and fuel to be richened up.
If knock occurs during spool up due to an unusually lean mixture the ECU will think it cannot run as much boost pressure as it realy can. So the knock system will limit the boost more than it would normally need to.
Only a possiblity, but that's kind of the gist of what I'm thinking at the moment.
Adrian~
Old 07-25-2004, 08:40 AM   #15
I might be straying off topic here, but how does a performance ECU compensate fuel supply for the changes in timing and boost? Does it simply know more fuel needs to be added due to the increase in flow over the MAF? Does the MAP come into play the same way as with stock programming where it is used during rapid load changes or when discrepencies exist? Are new MAP values introduced with the software so there are no longer discrepencies between the two values when the stage's designated hardware is in place? If the program is a stage 1/2 program which is the same software (at least in BSR's case...not sure about the other tuners) designed to operate with or without an exhaust, it would seem there would have to be discrepencies with one of the two applications as there can only be one VE expected by the ECU yet there are 2 different VE values with or without an exhaust. I also find it interesting that Nordic and Maptun use uprated FPRs in B235R applications over 280hp while BSR, SQR and Hirsch do not. Hirsch uses a larger intercooler and turbo inlet pipe (but oddly the stock exhaust) perhaps using cooler intake temps, better VE and less aggressive tuning to control knock while creating more power. BSR and SQR do not make any intake changes or any changes to the FPR. Perhaps because of this the BSR or SQR software are more likely to create knock due to high intake temps and a lack of adequate fuel supply. Boll did say Nordic was regarded as the most reliable tuner in Sweden and we know Hirsh has a proven reputation. ERP also stated when he had his ECU custom tuned by SQR, the boost was brought down to make a smoother power band while still keeping the target power levels intact. I am guessing this was done because VE improving mods were already in place and the higher boost levels were not necessary to reach the target power levels.
Thanks again for the discussion...hopefully it is not growing tiresome to you. If it is just let me know...it's all good. I have a lot more to learn than you so I am very eager to try and figure as much of this out as possible. I don't want to be that guy that says "ohhhh this stuff will give me lots of power" but not have a true understanding of how or why.
Old 07-25-2004, 09:25 AM   #16
this is an excellent thread, i am learning quite a bit from here.
if an exhaust would make the car run leaner, how would bsr stage 1/2 software compensate there... Stage 1 is just a filter where stage 2 is filter/ exhaust. Now if Nordic and Hirsch are adding FPR then r they changing the injectors or keeping the stock ones on?
In the turbo cars i have modded in the past with maf sensors, there has always been a way to lock the voltage on the maf so it can only make one reading. The problem on T7 cars comes with the Map sensor... now we would have to lock that as well but to what values.?
ricot83 is offline
Old 07-25-2004, 10:01 AM   #17
With T7 constantly changing and adapting, this is not something you would want to do. The MAF reading is too critical a component of T7 to lock in a static MAF value tricking T7 into believing there is a certain amount of air coming in when there is really a completely different amount coming in. This sounds like a recipe for disaster to me...unless I am missing something and not understanding what you mean by "locking the voltage".
I don't believe there are any changes in the injectors (at least none are listed) unless you start getting up into serious power levels. I would think the stock FPR simply doesnt provide enough pressure to supply the amount of fuel needed to make a stoich mixture if the boost is upped a large amount.
Old 07-25-2004, 11:03 AM   #18
Generally a higher FPR is a "bandaid fix" as it really doesn't flow much more fuel, and it can sometimes put too much strain on the injectors. But it's better than accidentally running lean.
And yes you would NOT want to force the MAF sensor to give just one reading. I've always been an advocate of adding more sensors. Disabling one of them means there is that much less the ECU has control over. Granted there are occasions where you cannot control the ECU, so you bypass it out of desperation. But idealy you just want to gain control over the ECU, and then give the ECU as many sensors as it can handle (within reason) so that it is that much better informed of the conditions in the engine.
Interestingly, Nick Taliafferro has the following mods and does not have any serious issues whether using stock or modified software:
Upgrade Turbo > 18t compressor + clipped turbine + larger exh house
Intercooler > Race aluminum
3" Complee exhaust one muffler race cat
Open air intake feeding Large bore turbo intake pipe.
So the exact cause of the downward adaptation must not be a consistant trigger. Sometimes it happens sometimes not. Still looking into things further.
As for T7 though. As much as T5 fans tend to diss it, it's a very adaptive engine management system, and in the right hands can be very powerful. The fact that it uses both MAF and MAP gives it a huge advantage over T5 when programmed properly.
Being able to measure a putative value for intake air gives it the ability to "learn" modifications, even if the factory software doesn't always take advatage of that ability.
It also has the processing speed and capacity to be programmed to do neat things with Ionization traces. It could theoretically be programmed to measure EGT, Rapid Burn Angle, and a number of other things using the Ionization Gap Sensor. Of course that's all in theory, but the point is that it has the processing power to be able to do it if someone could work out the programming.
Very good stuff.
Adrian~
Old 07-25-2004, 11:51 AM   #19
found this online...pretty interesting stuff
Mecel AB Within the business area "Engine & Powertrain" at Mecel AB, engine control and diagnosis have always been the core business. We see our participation in the competence center ISIS as an effective way to address these issues. To provide valuable information for advanced engine control, combustion feedback through ion current sensing has become very important. In 1984 Mecel filed the first basic patent in the area of ion current sensing in an internal combustion engine. The technology was developed to include some base functionalities such as cylinder identification and pre-ignition detection. The first system with this functionality was introduced in Saab cars in 1988. The functionality was further developed, and the more complex knock detection function was introduced in the model year 1993.
Over the years we have found that the ion current signal contains a lot more information than what has been exploited so far. Information about air/fuel-ratio, in cylinder pressure, cycle to cycle variations and EGR-content (Exhaust Gas Recirculation) are examples of combustion data that we believe could be extracted from the ion current signal. Within Mecel we do not have the competence to do signal interpretation of the complex signals we have to deal with. The signal is complex not only because of the wave shape itself, but also because of the dynamic effects, fuel variety, environmental impact and engine ware. One ISIS-project is defined within this area and very encouraging results have already been presented.
4.5 Saab Automobile AB The background for Saab Automobile's interested in advanced control and diagnosis can be described as follows: In 1985 Saab started development of an Engine Management system (EMS). This was originally meant for experimental use, to make it possible for Saab to have shorter lead-times developing different functions and control strategies. The system was very successful and it was decided that the EMS should be further developed to be used for production cars, Model year 1993 "Trionic 5" was introduced controlling the 2.3 liter Turbo engine in the Saab 9000 vehicle.
Five years later the next generation of Saab EMS, "Trionic 7" was introduced in the Saab 9-5. The Trionic 7 implements an airmass based control strategy with ion sense, cylinder individual knock control and electronic throttle control. It also features full diagnose capability.
http://216.239.41.104/search?q=cache...hl=en&ie=UTF-8
Old 07-25-2004, 12:06 PM   #20
Here is another good write up explaining many of the principles we are discussing...for whoever is interested
http://www.fs.isy.liu.se/Publication...LIC_934_PA.pdf
