Fitted Konis and Eibach pro kit - The Saab Link Forums
Old 06-23-2004, 01:00 AM   #1
Yep did it big time The whole lot is on new strut mounts washers bearings Adjustable Koni's and Eibach pro kit.
Glory be the 900 is now a Go-Cart
Whole job took a while working on my own but not really a problem apart from 1 troublesome track rod ball joint that refused to hold tight whilst being undone no matter how hard it was clamped.
I just took the steering arm of the rack and pulled the whole lot through
This weekend I shall be fitting the Ala Blaque out Viggen styleeeee aerial and my car passed emissions test yesterday so I can now fit my Abbott decat pipe.
Waheeyy
Dead Centre
Dead Centre is offline
Old 06-23-2004, 07:40 AM   #2
Sweeeeeeeeeet
I can't wait to get more suspension parts on too.
ooooooohhhh Eric........ :P
Old 06-23-2004, 08:13 AM   #3
ERP
ERP's Avatar
Send a message via AIM to ERP
They're coming, I'll have more info later today.
2005 9-2x Aero Stg 2
1996 900 'Aero' 2.3t Sold -
ERP is offline
Old 06-23-2004, 08:26 AM   #4
HNNLIC
Blaque's Avatar
Sounds nice Dead.
Let us know how it turns out.
Blaque is offline
Old 06-23-2004, 11:32 AM   #5
i cant wait to redo my suspension like that. i think for starters i may do the rear sway bar and steering rack and brace. then wait a while to get the money to do springs, shocks, and struts. does anyone have any thoughts on whether thats worth it or not to do it like that? if i did the springs/shocks/struts, would that rule out the reason for the rear sway bar and all? or just make it that much better?
thanks,
-Frank
roadkil34 is offline
Old 06-23-2004, 11:37 AM   #6
The car just keeps suprising me no end. It really is different. The confidence in high speed cornering is awesome. She just rounds the corner straightens up and boosts.
The drop 35mm really suits the car with 17's it would look great.
The Eibachs are great I got them even though the koni kit came with a set of sprinhgs. For once I wanted to treat myself. They hold the car very steady and very comfy. The Konis were on max hard for the first run I did'nt like it. Great fun for hammering on the back lanes but I want to get to where i'm going without a headache
So mid turn is where they are set at. You get a 720 degree rotation on the shocks so I set mine at 360.
Works really well. Mind-you even on soft they are still way harder than standard.
Bodyroll is not just down its hardly there so this weekend coming its a double stack rearbar
I shall report on more later once all this is soughted its off for a stage 1 and Polys at the front.
Dead
Old 06-23-2004, 02:40 PM   #7
thanks,
-Frank
In a sense it wll make it "that much better." A rear sway bar will help to eliminate the understeering characteristic of the car.
IMHO, on the NG900/9-3 chassis, the suspension priorities are like this:
1) "Viggen rescue kit" items (steering rack brace, etc)
2) Springs and shocks
3) Rear swaybar
driver found is offline
Old 06-24-2004, 03:01 PM   #8
I am going to go ahead and disagree with Driver Found here.
Go with the Sway bar for the rear. Its cheap, and very effective.
Maybe then go with the front sway bar from the 9-3SE. Its larger than the rear, so the car will have a hair of understeer again. Again under $150
Next, MP performance should have some affordable front and rear shock tower braces. Again, cheaper than shocks and springs. I am guessing less than the price of springs still.
You may want to install Poly bushings now, or just go right to the shocks and springs.
The VRK stuff, i.e. mainly the rack brace and clamp, should be considered during heavy perf modding.
Old 06-25-2004, 08:37 AM   #9
The Double rear stack will be on tomorrow (Saturday) so i've had a week with the shocks and springs so I shall be able to gauge the difference with the 2nd rear A R bar.
Car passed its emmisions so also going on is the Abbott decat down-pipe
Fun shall be had.
Dead
Old 12-11-2004, 08:50 AM   #10
Can you post some pics of the car from the side after you installed the spings thenks.
Dan
snow4_1man is offline
Old 12-11-2004, 05:44 PM   #11
these r eibach kit cars
this is mined
16" rims
this is my buddy josh's
15" rims
17" rims
ricot83 is offline
Old 12-12-2004, 02:03 PM   #12
DC_SAAB's Avatar
Now I'm probably thinking ...this must be my imagination...but are these Koni coilovers for SAAB NG's.
http://www.partsforsaabs.com/product...oducts_id=1252
I suspect I'll be placing an $800.00 order soon if I don't find the air suspension I'm looking for...
DC
DC_SAAB is offline
Old 12-12-2004, 02:36 PM   #13
i thinki they mean the dampners are adjustable in hardness
turbokick is offline
Old 12-12-2004, 03:02 PM   #14
DC_SAAB's Avatar
obviously...but they do indeed look like coil-overs comparibly...notice the pics above seperate the struts from the springs...the link shows them together..
DC
DC_SAAB is offline
Old 12-12-2004, 07:02 PM   #15
Does Eibach still make the Pro-kit for the NG900?
deleonl1 is offline
Old 12-12-2004, 07:21 PM   #16
yes eibach still makes them i dont remember the part number off hand
and those are not coilovers, they are just shocks with springs... not adjustable coilovers!
ricot83 is offline
Old 12-12-2004, 08:19 PM   #17
DC_SAAB's Avatar
Yea, I know.., just wishful thinking I guess...
wonder why no-one makes an adjustable coil-over for SAABs...
DC
DC_SAAB is offline
Old 12-13-2004, 05:42 AM   #18
Yes those are for the NG900. MP Performance sells those for like 540 i think. I also have a guy on ebay that will sell them for 440 + 20 shipping. So don't pay to much. I need a set also because no coilovers are going to be made at all.
Old 12-13-2004, 05:49 AM   #19
i thought you were trying to get coilovers going snow, what happened to that petition for coilovers?
saabvos is offline
