Fuel setups for "big" HP - The Saab Link Forums
Old 02-19-2016, 04:46 AM   #1
Just looking for some advice, here.
I've ordered most of what I need, and the 9000 has the fuel pump and injectors that I'll use in the 9-3, but I'm curious- based on my experience with DSMs. Do "we" just drop the pump in, and leave the stock wiring/fuel lines alone?
There's no need to run a beefier power feed to the fuel pump for the higher load?
Maybe this is already common practice? or is the stock wiring good-enough?
For reference:
Fuel pump rewire
For the fuel lines- I assume they're big-enough. They certainly seem large-enough to handle a high volume. are the check valves a big bottle-neck?
Is there a need to open the valves and the holes in the top of the fuel sender?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 02-19-2016, 11:28 AM   #2
Drew in Houston's Avatar
I've kind of wondered the same thing myself. On my 400whp (or so) 19t setup I'm running deka 875's with a Bosch -044 in the tank, plugged the stock outlet connection, and ran an -AN bulkhead fitting through the top of the cap. Then ran braided hose with an -AN to metric banjo to go to the stock fuel filter in the stock location. That works well, without the check valve I just pause a second before engaging the starter motor to let the pump purge any air.
My brother's Viggen also 875's but with GTX3076, he used an in tank -044 but kept all the factory stuff. He's probably making a 100 more hp at least That works too.
To know for sure you'd have to watch your fuel pressure and look for too much fall off, or tuning wise you'll just eventually run out of enrichment adjustment--where you increase injector duty cycle and it won't get richer, or you just can't adjust values any higher, and at that point you'll know you have too much restriction somewhere.
Drew in Houston is offline
Old 02-19-2016, 11:43 AM   #3
That's actually pretty smart.
The fuel line looks to be up to the task. I like the idea of skipping the check valves and eliminating that (potential) bottle-neck and going right for the fuel filter.
I assume you use the stock return, right?
Have any pictures of the setup?
Did you use factory wiring?
Craig R.
g96nt is offline
Old 02-19-2016, 11:51 AM   #4
Yep, stock return. Sorry, no pictures, I did it a few years ago. I got the bulkhead fitting and stuff from Summit Racing. Also stock wiring--which I'm not convinced is such a great idea, but fuses exist and are sized to protect wiring (generally), if the OEM did a good job sizing things and the factory fuse ratings aren't exceeded, it should be safe I guess..
