Bogans stupid questions thread.. ;) - The Saab Link Forums
Old 09-02-2015, 04:10 AM   #1
bogan's Avatar
Hey there guys..
Is there any reason why I cant run my T25/T25 Garrett in the Top mount position... On a GS Top mount manifold ?
Cheers Greg
bogan is offline
Old 09-02-2015, 05:05 AM   #2
turbojohnny's Avatar
you made a hybrid t25 with another t25?
I think it will be fine, they just mount them on the bottom side to make things more neat and tidy.
it's not like the oil pump will have any trouble pumping oil to the turbo.
turbojohnny is offline
Old 09-02-2015, 08:54 AM   #3
Greek Mod
grkguy89's Avatar
just clock the turbo from the turbine housing and you'll be fine
Current Activity: Moderating
grkguy89 is offline
Old 09-03-2015, 11:20 PM   #4
bogan's Avatar
hahaha...Sorry.. Typo on The T25/T25... WTF ?...lol
I meant the write T25/T28... Pffft
On my RWD engine I am setting up...I can't mount the turbo using the standard manifold...The engine mounts get in the way...
If I use the GS top mount mani....it will fit no worries
While I am rebuilding my 2.3 engine... I will use one of my spare 2.0 engines I have and run my stage 5 set up I have on my Talladega.
I will run the 2.0 with the T28 turbo on the top mount mani..
When I finally rebuild the 2.3 I will drop a gt 3071 onto it (or a HE351cw)*undecided*
I'm still waiting on my custom oil pan to come back...any day now... Pffft
bogan is offline
Old 09-03-2015, 11:23 PM   #5
bogan's Avatar
Thanks Guys... I just thought I better double check
bogan is offline
Old 09-04-2015, 04:34 AM   #6
use 9000 manifold?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 09-05-2015, 03:07 AM   #7
bogan's Avatar
Originally Posted by g96nt View Post
use 9000 manifold?
That's a good idea...why didn't I think of that ?
I got one of those, sittin on the side of my B234..
I'll investigate
bogan is offline
Old 09-05-2015, 11:31 PM   #8
bogan's Avatar
mmm ...Bummer
I tried the 9000 manifold...still no good.
Looks like its going to have to be a top mount..$$$
bogan is offline
Old 09-06-2015, 05:13 AM   #9
Hi Greg, 9000 mani with a downside up adapterplate is working fine. 12mm is enough.
no $$$ only $
good luck, Kay
mocambiqueamazone is offline
Old 09-07-2015, 12:38 AM   #10
bogan's Avatar
no $$$ only $
good luck, Kay
Thats a good idea...
I might make one up...Just to get me through...Till I can buy a G.S Top mount Manifold
bogan is offline
Old 09-10-2015, 02:40 AM   #11
bogan's Avatar
Got some T2 flanges on the way...Up pipe coming
I wonder if this would work..It would make nice flow...the radius might be a bit big though?
http://www.ebay.com.au/itm/171236254...%3AMEBIDX%3AIT
Can I plumb my turbo up with something like this ?
http://www.ebay.com.au/itm/181716501...%3AMEBIDX%3AIT
Thoughts ?
bogan is offline
Old 09-10-2015, 05:00 AM   #12
Greek Mod
grkguy89's Avatar
I have my top mount setup for sale
you can use any t3 flange turbo you want
and external wastegate with a screamer pipe
let your imagination run wild.........
grkguy89 is offline
Old 09-11-2015, 12:02 AM   #13
bogan's Avatar
Thanks Christos.. I got T2 flanges on the way,... and postage to the otherside of the world might be a drama ...lol
I'm going to run my T28 and stage 5 setup in a B 204 For a while ..Till I get my B234 engine rebuilt.. I'll proberly drop a 3071 on it.
bogan is offline
Old 09-11-2015, 12:09 AM   #14
bogan's Avatar
has anyone use something like this to plumb a turbo?
bogan is offline
Old 09-11-2015, 04:00 AM   #15
mvadenais's Avatar
^Yes, My GT3071 set up utilizes braided lines. I made mine 7 years ago
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 09-11-2015, 06:51 PM   #16
bogan's Avatar
Thanks..
Sooo, If i use that braided line kit to plumb my Turbo...I would have to get "threaded" banjo bolts for the connections ?
Is that right?
bogan is offline
Old 09-12-2015, 05:04 AM   #17
Drew in Houston's Avatar
Summit has a pretty good selection for finding conversion fittings. Even if you don't buy from them, you can maybe get OEM part numbers, maybe find vendors in AUS
Like here's -AN like those red/blue fitting to Metric
http://www.summitracing.com/search/d...3%2B4294920733
I don't know what your space constraints look like, but I bet the turbo side is metric female, and you may be be able to skip the banjo thing totally and just thread an o-ringed/crush/sealing washer Metric to Male -AN fitting. Then use female -AN hose ends like the pic above. If you haven't used -AN fittings before watch those hose end fittings some are swivel type and some aren't
Drew in Houston is offline
Old 09-12-2015, 09:33 PM   #18
bogan's Avatar
Thanks Drew...Cheers
bogan is offline
Old 04-22-2016, 08:23 PM   #19
bogan's Avatar
Update...... ***
Hey there Guys...
Ok...Question.!
I have a B234 and 3x 204's sitting in my Garage
I want to work over my B234...
when I am buying Cams....are the Aftermarket b204 and b234 cams the same ?
I just noticed that G.S doesnt sell Enim cams anymore too !
Should I go with the mild upgrade Cams...or the big upgrade Cams to go with my Holset HE351cw.? .(similair to HX35) but better.
This car will not be a daily driver...It will be a weekend thrash / race car..
What head is better...B234 or B204 ?
What is the ulimate combnaition of parts..?
I'm thinking of boring the block and running big pistions with big cams...
As I said.. 1x b234 and 3 b204's
Whats is the ulimate b20X build ? In combination with my Holset He351cw ?
any input and advice is good !
Help me build an animal motor
Cheers
bogan is offline
Old 04-24-2016, 05:16 PM   #20
as far as I'm aware, the 234 and 204 heads are the same.
