Big Turbo T28 GPopShop - The Saab Link Forums
Old 08-24-2015, 10:36 AM   #1
-One question about the new turbo I did install, a full upgrade from a T25 to larger compressor wheel and clipped exhaust wheel.
Under hard acceleration, I hear this loud hissing sound when the engine is hot and during high external temps. I tracked down the boost leaks known to me and I am wondering if this sounds comes from any type of valve where the T5 system is cutting power/boost during hot temperatures?
The turbo boosts really hard when the external temp is low, lets say 20 degrees, at 28-30 degrees you get a significant drop in boost and power and this hissing sound.
maybe someone here can point me in the right direction, in case this is not normal? thanks a lot in advance!
saab 900se 2.0 turbo with ETS IC, 3" Exhaust, Forge Blow Off Valve + Stage 3 ECU
Mato is offline
Old 08-25-2015, 11:24 PM   #2
bogan's Avatar
Just sounds like major boost leaks to me... Big time !
Are you running a boost gauge ?
the waste-gate will open and let boost out (to protect your engine) but that exits out the exhaust..
If you had a external waste-gate you would hear it !
You may need to upgrade your Recirc valve/ blow off valve ..
I also run a "big"T 28 from the G-pop shop...Great turbo...had mine for nearly two years now
bogan is offline
Old 08-26-2015, 08:35 AM   #3
hmm, the forge blow off valve from genuine saab is installed,
that thing works great.
So I guess I have to look more for boost leaks.
When does your turbo give full boost?
I think mine does not come on before after 3200rpm.
Also if you can point me to a good boost gauge that would be great.
Mato is offline
Old 08-27-2015, 12:24 AM   #4
bogan's Avatar
The forge valve is good..
Yeah sounds about right...I'm in full boost around 3200.. I got mine screwed up to 28psi..
lots of boost gauges out there ..all of them similar...Glow shift make lots
I have a Turbosmart Gauge..
Ebay
bogan is offline
Old 08-29-2015, 02:26 PM   #5
Found it, the waste gate rod wasn't screwed down tight enough.
So it cracked open when hot cause of the hot spring and loose installation.
-At least that is what i think it was
Mato is offline
