Turbo lag - The Saab Link Forums
Old 08-17-2015, 09:23 PM   #1
Turbo lag
Been researching ways around turbo lag. One guy said this "One solution would be with a small charge nitorous kit, armed by a vacuum switch, and operated by a throttle what microswitch. Whe the turbo spools, you lose vacuum and get boost, the nitrous would switch off automatically. a small bottle could potentially last a long time."
Any comments on what this guy said would that actually be practical to set up and has anyone here ran nitrous in there ng900? Can the motor even handle the higher temperatures? Stock cooling would need upgrading id assume. New to car building and any knowledge is appreciated!
Jeffcentola is offline
Old 08-18-2015, 05:27 AM   #2
bogan's Avatar
You cant run Nitrous...the gearbox cant take it...
I run a Garrett 2860 it spools real quick...so does the TD04
bogan is offline
Old 08-18-2015, 06:39 AM   #3
Wagon Shaggin'
Saabeh's Avatar
You could run nitrous, but that isn't really solving the problem and is unnecessary. I don't know about your car, but if you haven't done a 3" downpipe and a free flow exhaust, then you're not experiencing the fast spool up.
Saabeh is offline
Old 08-18-2015, 08:25 AM   #4
Drew in Houston's Avatar
I say try it and make thread on here as you step through it. It's true there's no replacement for displacement, but faster spool is never a bad thing. Even if it's fast already.
Since it's a ng900 I don't think you'll see additional transmission problems over what you'd expect running a stock frame turbo with the waste gate screwed down hard w/helper spring, maybe Bogan's thinking og900?
What turbo are you thinking?
My gut feeling is that there's no huge need until you get to something bigger than gtx3071 because they'll spool quickly enough to keep you right on the edge of traction anyway, and in fact have to be held back. We haven't measured it, but my brother's GTX setup (modified from yllwjet thread fame) makes more power everywhere than a stock viggen setup, including at tip-in and while spooling. I say that not only because of how it feels but also because at anything other than light low load cruising it needs considerably more fuel everywhere.
Drew in Houston is offline
Old 08-18-2015, 11:30 AM   #5
ive been planning on a hx-35 build just because my friend has a turbo coming off his dodge in a month or so. i am open to other turbo options just not trying to kill the bank on a turbo with so many other parts to buy! preferably id like a turbo that can provide me with 400whp or more. although i was browsing the forum and jzw did a ng900 holset build with methanol injection and he did say hed add a pip of nitrous to the tank for a little extra power on race days lol.
Old 08-18-2015, 11:37 AM   #6
the garrett 2860 looks comparable to the power that the stock aero turbos can make. my buddy has a used one off a 2002 9-5 aero im going to pick up for cheap and after reading that another member boosted his stock aero to i think just under 17psi and a little over 300whp. thats my goal for now until i buy either my friends holset or if you guys can find me a turbo id like more!
Old 08-18-2015, 11:39 AM   #7
the gtx3071 looks like an upgrade to the holset. what hp can i make out of that turbo and what style flange would i need to have made on my manifold ?
Old 08-18-2015, 12:43 PM   #8
Wagon Shaggin'
Saabeh's Avatar
HX35's are not too popular anymore because the HE351C performs better.
Saabeh is offline
Old 08-18-2015, 01:47 PM   #9
yea i think im going to use a HE351cw for my build like you just said it performs better is that a t3 flange aswell?
Old 08-19-2015, 05:10 AM   #10
bogan's Avatar
There was a guy on here a while back...cant remember his name... he hooked up a nitrous set up.....blew his box into 28 pieces .....
Maybe he was giving it big squirts ..lol
stage 5 and 6 are just wheelspin machines even with an LSD
bogan is offline
Old 08-19-2015, 05:28 AM   #11
Greek Mod
grkguy89's Avatar
on these big HP builds you want some lag.... if power comes on too soon you start breaking stuff
ask me how I know
Current Activity: Moderating
grkguy89 is offline
Old 08-19-2015, 06:08 AM   #12
Ha I guess I was assuming street tires...and viggen axles.
For how hard the little over driven turbo setups come on (and assuming street tires and regular street launches) you think a large frame turbo with a little dry shot up front would spike torque more? I wasn't thinking it could but who knows?
The way i was thinking was that most cases the tires just let loose in cloud of smoke and at that point you're transmitting very low torque, no matter if there's 300 ft-lb potential there or 600
Old 08-19-2015, 07:11 AM   #13
Hmmm so is it possible to upgrade the gearbox to not only make it more durable but to max out the top speed of the car? Seems like it ld be a lot more work than its worth. But also grk89 you said your tdo4 setup is for sale? Want to pm me with details and price/pics? Thanks
Jeff
Old 08-19-2015, 08:14 AM   #14
Can you shot peen and cryo treat the gearbox for durability?
Old 08-19-2015, 08:41 AM   #15
Greek Mod
grkguy89's Avatar
Jeff
I do have a td04 sitting in my tool box
just the turbo with the intake pipe
I will have my top mount setup for sale really soon too (manifold, up-pipe, support bracket, wastegate, and 9cm housing for an hx35) [pictures to come]
grkguy89 is offline
Old 08-19-2015, 10:19 AM   #16
Id very much like to buy the tdo4 and downpipe how much would you want and how much use has the turbo seen? And i have seen your top mount build its pretty awesome but i am going for a bottom mount manifold otherwise id give you an offer.
Old 08-19-2015, 10:19 AM   #17
Any reason why youre selling your top mount build?
Old 08-19-2015, 10:21 AM   #18
Pm me with photos if youd like or here
Old 08-19-2015, 10:57 AM   #19
Greek Mod
grkguy89's Avatar
only have the td04 now
has less than 65k miles
building a new twin scroll manifold
this is pic of when it was being tacked up.
I'll have pictures of it out of the car this weekend
grkguy89 is offline
Old 08-19-2015, 12:43 PM   #20
You going to upgrade to the he351 cw holset? And how much for the turbo ive found rebuilt ones on ebay/amazon for 350$
