Clutch options - The Saab Link Forums
Old 07-27-2015, 06:49 AM   #1
Clutch options
I'd prefer to stay away from SPEC. I've use them, and the stage 2+ I had barely held 250lb/ft on 16s.
The clutch in the wagon-on the other hand, holds better than 300torks, and does it in a 2-ton whale with 18s
The question is: Is there a better OE clutch? is 9-5 aero better than Viggen, or the opposite? I'm sure I'll end up aftermarket, but which is stronger? is there a clear winner?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 07-27-2015, 08:29 AM   #2
Wagon Shaggin'
Saabeh's Avatar
Viggen clutch is the way to go with 9-3s. The 2002+ 9-5 Aero clutch is bigger than the Viggen one, but cannot be used in a 9-3 apparently. Considering you have a hydro clutch in that 9-3, slap a Vig clutch kit in and call it a day.
Saabeh is offline
Old 07-27-2015, 12:39 PM   #3
That was my thought. I haven't decided what I want to do for turbo yet, but I doubt I'll be over 400hp and equal torques.
In a google search, it came up that there's a Sachs Racing clutch that abbott used to sell, which was ~400gbp, which would be pretty affordable with the dollar doing well.
do we know much about this thing?
Craig R.
g96nt is offline
Old 07-27-2015, 12:42 PM   #4
Wagon Shaggin'
Saabeh's Avatar
People have "stage 4" Viggens with stock healthy clutches. Most of the 9-3 aftermarket clutches are stock Viggen pressure plates with a more aggressive clutch disc material.
Saabeh is offline
Old 07-28-2015, 12:34 AM   #5
bogan's Avatar
Ive had my Spec stage 3+ for over two years holding stage 5 powa
No problems
bogan is offline
Old 07-28-2015, 04:18 AM   #6
I'm running a viggen clutch and PP with a big T28, w/m, and a very aggressive tune. Still holds fine and has been doing so for 20k.
-Cm
Cm452 is offline
Old 07-28-2015, 01:02 PM   #7
Viggen clutch it is!!!
Are the slave cylinders that come with the sachs/valero kits any good?
Craig R.
g96nt is offline
Old 09-24-2015, 07:28 AM   #8
So, I've been looking into this, as the work's going to start soon.
Sachs seems to be the only company that lists a different kit for the 3 power levels of the 9-3.
Is LUK selling everyone viggen pressure plates, or is everyone getting base model clutches?
The Sachs is only $450 for the kit, which is pretty dang reasonable, but if I could save a few bucks on this, I'd love to.
Anyone know?
Is there a place to buy the sachs racing pressure plate? It's only $400 from sachs, which means it's probably $300-ish retail.
Craig R.
g96nt is offline
Old 09-24-2015, 04:10 PM   #9
chevyman's Avatar
ClutchNet has a full line of clutches on their website now. Might be something to look into.
1995 900 se turbo
chevyman is offline
Old 09-26-2015, 09:40 AM   #10
Greek Mod
grkguy89's Avatar
I'm planning on sending my viggen pp to clutchnet to have it overhauled with new updated better clamping springs and levers
Current Activity: Moderating
grkguy89 is offline
Old 12-31-2015, 11:31 AM   #11
So, my plans have changed. considerably. I've now got a wossner'd b234R with hx35 to shoehorn into the 9-3. This means I'm going to need a stronger clutch than the Viggen.
I don't know what happened to clutch prices, but the last ACT 2600 I bought for my DSM 5 years ago was only $360. what happened that these things are $800 now!?
Do we have any options for lower pricing? I'm looking for a clutch that will hold 500 ft/lb incase I decide to go wild with this thing, and a grand for a clutch seems steep.
Craig R.
g96nt is offline
Old 12-31-2015, 04:20 PM   #12
chevyman's Avatar
Saab clutches have always been expensive. That price may include a slace cylinder if it is from spec.
1995 900 se turbo
chevyman is offline
Old 12-31-2015, 08:03 PM   #13
Find a local clutch shop and have them make what you need. The basic pieces are straight off the GM style parts shelf for them and they should be able to easily build to suit your need.
Increase the clamping force of the pressure plate and get a dual friction disk built. You can get the ease of a street clutch on engagement, but the lockup of a race clutch. Possibly not a "perfect" solution, but makes for a drivable/streetable solution for high torque needs.
win_k is offline
Old 01-27-2016, 09:25 AM   #14
So, I pulled the trigger. Spec stage 3+.
Spec says 650 lb/ft capacity which is certainly overkill, but I've been told it's also the most streetable.
I tried ordering through a Saab vendor, but ebay was about $100 cheaper.
Should be here shortly.
new question; lightening the stock flywheel. I haven't held one in 5 years or so, but I seem to remember them being 20lb or so. Aside from the $600 option from spec, are there others? are there instructions online to hand to a machine shop to have the stocker lightened? These cars have high-ish idles, so I can't imagine that they really NEED the heavy flywheel.
Craig R.
g96nt is offline
Old 01-30-2016, 04:13 AM   #15
bogan's Avatar
The flywheel I would get is from Abbott motor sport in the UK...Its the best..
Or a cheaper option is to get a machine shop to lighten you stock flywheel...There is lots of metal on the back that can be cut away....I done this ..
You will love the Spec Stage 3+
bogan is offline
Old 01-30-2016, 05:27 AM   #16
Drew in Houston's Avatar
That forged Abbott unit looks nice, single piece, probably safer at high RPM... but I went the other way and have been running the aluminum flywheel that Nick sells for years now, looks like he's asking $400 for it these days (I think it's the same SPEC that you mentioned?). It's listed as 7.5 lbs compared to the forged Abbott at 9lbs and stock at 15.4lbs.
Mainly I like that the friction surface is replaceable for not a lot of money and no machining--the no machining part is nice if you're working on a weekend and want to get it back together.
It did need to be balanced brand new out of the box which was a little disappointing. I'd buy it again from a technical standpoint. If you go with SPEC and have a problem don't expect any help from them, after I had one of their clutch disks fail in less than 10k miles, the engineering support guy I spoke with was a total flaming asshole--it was really outrageous how much of a jerk the guy was with no provocation, it's been years now but I've been boycotting SPEC ever since lol.
Aluminum Flywheel For NG900/9-3, GenuineSaab.com
Drew in Houston is offline
Old 01-31-2016, 08:31 AM   #17
Wagon Shaggin'
Saabeh's Avatar
Local machine shop in NH has been resurfacing and lightening all of Mike D and I'd flywheels over the years.
Saabeh is offline
Old 02-02-2016, 07:03 AM   #18
srp
srp's Avatar
Send a message via AIM to srp
I've got the aluminum spec one as well. I love the fast reviving.
srp is offline
Old 05-15-2016, 04:53 PM   #19
turbojohnny's Avatar
I may have made a mistake. I ordered a spec stage 2 clutch kit. supposedly good for 468 ft./lbs.
I've never had a problem with a viggen clutch kit, but I've never tuned up a b234r in an ng900 before. Hopefully the Spec clutch kit holds up for me. If not, it will be a waste of the $450 it cost.
for some reason there is a spec line of clutches for the ng900, and also the og9-3. stage 2 for each car is good to 468 ft./lbs. but the og9-3 clutches are quite a bit more money.
I guess we'll see what happens. I'll just try to be nice to it.
turbojohnny is offline
Old 05-16-2016, 01:37 AM   #20
bogan's Avatar
I've never had a problem with a viggen clutch kit, but I've never tuned up a b234r in an g900 before. Hopefully the Spec clutch kit holds up for me. If not, it will be a waste of the $450 it cost.
Ohh noooo....
Good luck mate...
bogan is offline
