Quick question about 2.3 head - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Classic 900 Forum '78-'93 > Performance Modifications for the Classic 900
Performance Modifications for the Classic 900 This forum contains PERFORMANCE related Q&A's for the Classic 900. This may also include suspension.
Old 02-18-2009, 02:58 AM   #1
justineffingp's Avatar
Basically i know everbody says 2.1 and 2.3 head from 9000 n/a or 900 n/a but at my dads shop there are two newer n/a 900's a 95 and a 98 with the 2.3n/a. Could I use this? is there anything else i could steal off of them? Theyre seeing the junkyard and anything i want is free, any help is greatly appreciated, thanks guys.
justineffingp is offline
Old 02-18-2009, 03:03 AM   #2
spgeebee88's Avatar
no those heads wont work,
you need like a 90-93 9000 2.3 head but then it only makes your motor a 2.1 not a 2.3.
spgeebee88 is offline
Old 02-18-2009, 03:17 AM   #3
i wasnt aware it changed to a 2.1 i thought it just gave it better flow when ported and polished? eh, i figured for free it would be worth asking lol
Old 02-18-2009, 03:27 AM   #4
spgeebee88's Avatar
the stroke of the 9000 motor makes it a 2.3 not the head but the head helps a little but you can get the same head off a 91-93 900S 2.1ltr
Old 02-18-2009, 03:33 AM   #5
Yeah i must've misread what you wrote earlier lol, but the 2.3/2.1 head head is good to know, thanks a bunch for the insight I appreciate you walking me through it at 7:30
Old 02-18-2009, 03:50 AM   #6
spgeebee88's Avatar
hahaha no problem just board at work...
Old 02-18-2009, 07:51 AM   #7
yeah....know how that goes unfortunately
Old 02-18-2009, 08:14 AM   #8
c900 Grognard
Jack Straw's Avatar
Well, you can use it, but you have to modify the timing cover to make it fit. It will actually breathe better than the older one anyway. Search for Gorper's posts on the subject on saabcentral.
Originally Posted by IronJoe
Jack Straw is offline
Old 02-18-2009, 08:15 AM   #9
IronJoe's Avatar
It doesn't change your motor to a 2.1L.
What it will do is lower your compression ratio. This will allow you to run higher boost without knocking, as long as your other engine parameters are taken care of.
Unfortunately there aren't any back-to-back dyno runs showing gains from the 2.1L head/intake combo, but the intake runners are larger in diameter as well as the ports.
When I did this mod two years ago I noticed that I was able to run higher boost before knock occurred.
IronJoe is offline
Old 02-18-2009, 08:19 AM   #10
IronJoe's Avatar
It's not just the timing cover unfortunately. The PS bracket, RH engine mount bracket, and intake manifold have to be reworked. This is why I have put that project on the back burner for now.
IronJoe is offline
Old 02-18-2009, 08:45 AM   #11
Thats what i thought, and it sounds like it may be more complicated than the older one but still totally doable and for free i'm thinking if it can be done i should do it....is there anything different between the 95' or 98' 900 head because i have my choice
Old 02-20-2009, 05:11 AM   #12
jjorgensen52's Avatar
The other way I've seen of doing this is actually removing the end of the old head and welding it to the new head, making the old timing cover and brackets functional. I saw it done on a T-7 viggen head for a C900, I think on saabcentral.
J.Jorgensen
88 900 SiS 'vert (Dad's baby)
88 900 SPG SOLD
93 GMC Typhoon 492hp/521ft lb turbo a2a AWD
jjorgensen52 is offline
Old 02-20-2009, 07:01 AM   #13
spgeebee88's Avatar
i think that would be the best way of doing it
Old 02-20-2009, 08:52 AM   #14
Wagon Shaggin'
Saabeh's Avatar
I am dumb for not buying this, it was $150 with the T7 intake manifold.
Saabeh is offline
Old 02-20-2009, 08:55 AM   #15
IronJoe's Avatar
Idiot.
IronJoe is offline
Old 02-20-2009, 08:58 AM   #16
spgeebee88's Avatar
Hey Dummy!
i have a couple of those heads hanging around out back.......hmmm
Old 02-20-2009, 09:20 AM   #17
Wagon Shaggin'
Saabeh's Avatar
Idiot.
Go ceramic coat your balls.
Saabeh is offline
Old 02-20-2009, 09:25 AM   #18
Green9kAERO's Avatar
Originally Posted by Saabeh View Post
I thought mike D was going to buy that for his 9k a long time ago? he would not disclose the location for fear that someone else would pick it up.
JP
Green9kAERO is offline
Old 02-20-2009, 09:39 AM   #19
Wagon Shaggin'
Saabeh's Avatar
The head was going to be for my SPG and he bought all of his suspension from the guy.
Saabeh is offline
Old 02-20-2009, 09:42 AM   #20
IronJoe's Avatar
Finally, you're back!
IronJoe is offline
