So I'm going to do it - The Saab Link Forums
Old 02-08-2013, 06:44 PM   #1
I'm going to start a N/A to turbo swap. Turbo engines been sitting in the garage for too long now collecting dust so I'm going to do the dirt.
ECU's are in my possession,
Turbo is in good condition
Wiring diagram is in hand (3 to be exact)
Gasket kit is being ordered and work is being done.
Oh and car hitting 200k a few weeks ago made me think a lot about it and my thought is before anything happens it's got to be done.
Things I need........ Turbo transmission from a classic 9000.
SS929k is offline
Old 02-09-2013, 03:40 AM   #2
Aerohead's Avatar
Good luck, assume the body shell is rust free is motivating the upgrade, rather than buy a different car?
Sort the brakes and suspension bushes, maybe inspect the cv joints, they will get more of a workout.
Aerohead is offline
Old 02-09-2013, 10:49 AM   #3
What model year 9000 are you starting with (the keeper)? What model year is the donor?
Are you transplanting the entire engine with turbo and plumbing?
Are you transplanting the entire engine management system, too?
If you want something nice, I've got one from an '87 9000T with low mileage since an Eriksson rebuild... but it's not a good fit for a low-budget project.
Used Saab Parts:
'92 9000T, 5MT, Black
dantinne is offline
Old 02-13-2013, 06:21 PM   #4
The engine is a 92 turbo. Mine is a 92 N/A and the turbo engine is going into the N/A body. I have the The computers and intercooler. I could use some of the couplers so I will be going to a yard soon for those. I may need a new MAF since when I bolted a turbo to my N/A, it fried. looking at the wiring diagram it seems the only thing I would need to add is the pins for the APC solenoid and maybe the air intake temp sensor as well (I honestly thought the MAF did all of that). I think this is going to be doable without changing the entire harness.
SS929k is offline
Old 02-13-2013, 08:18 PM   #5
What is your plan for dealing with TCS (ETS)?
What couplers are you referring to?
Used Saab Parts:
dantinne is offline
Old 02-14-2013, 09:17 AM   #6
the intercooler bends are what I'm talking about. As far as the ETS goes, the computers I scavenged were from a non TCS CDE or just the CD I believe and they were already chipped.
SS929k is offline
Old 02-26-2013, 06:23 AM   #7
Did some research over the weekend and came to senses that if I wanted to sort out a down pipe issue. I think I want to go 3", would it be better to fab one out now since the engine is out of the car, or should I just capitalize and buy one?
SS929k is offline
Old 02-26-2013, 07:28 AM   #8
nowhereman's Avatar
if you have the ability to fab one then why buy? if you cant easily fab one then buy. lol simple but true
2008 9-3 SS: Stg 1
nowhereman is offline
Old 02-26-2013, 09:46 AM   #9
MattCSE's Avatar
I am a firm believer in the JT 3" system for my 9000's. I just installed one this past weekend on my '93 9000. Even leaving the T25, what a difference!!!! I've usually swapped to the TD04 when I've done downpipes, but I ran into a bit of a snag this time with a broken tap in the turbo exhaust housing.... By the time I got that out I just bolted the system in and will do the TD04 another day.
MattCSE is offline
Old 02-26-2013, 09:59 AM   #10
I just figured that the 180* bend makes things difficult. I was thinking about making one but I thought that there would be an air flow issue with the sections that I was going to make.
SS929k is offline
Old 02-26-2013, 10:47 AM   #11
Fab one! I've found a couple of components that might be helpful, depending on whether you want to go stainless or carbon steel and whether you'll use v-band clamps.
Used Saab Parts:
dantinne is offline
Old 02-26-2013, 07:07 PM   #12
I will fab one and I was thinking of going V-Bands.
Was doing some ebaying and going through the pics in my camera I found this picture. The night I hit 200,000 in my baby and that's when I decided it was time to swap out the engine, just in case anybody was wondering.
SS929k is offline
Old 02-28-2013, 11:27 AM   #13
So today while going through wiring, I did not see anything on the diagram for the boost sensor. Did pre 91's not have those?
SS929k is offline
Old 03-22-2013, 09:56 AM   #14
Update status really quick before I go into work. After extensive searching through the threads I got the idea of adding pins to the harness for the boost controls. I originally was going to go with the rout of spicing the harness from a turbo onto the non-turbo (so a piggyback setup) but I wasn't sure if the color coordination was all the same. Will post pictures up Monday after I add the wires.
SS929k is offline
Old 03-22-2013, 11:00 AM   #15
I clicked on your pic and had a pop-up for a porn site. At work.
FUCKING AWESOME
Used Saab Parts:
dantinne is offline
Old 03-22-2013, 02:29 PM   #16
VWSAABVT's Avatar
FUCKING AWESOME
that's bullshit, you get porn and all I get is a lame pop up about saving the environment with windmills
EDIT: nvm, I got the porn when I closed the pop up.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 03-25-2013, 09:25 AM   #17
sorry will use different hosting site from now on lol.
SS929k is offline
Old 04-16-2013, 09:00 PM   #18
Quick update. I sourced out a 93 Aero transmission for my build. Going to pick it up Thursday. I can ask the guy if he is willling to part things out from the car. He's located in Tewksbery MA. Anyone need anything? I'll see what he has.
SS929k is offline
Old 04-16-2013, 09:38 PM   #19
Scarab Green fender flares.
Sent from AutoGuide.com App
Used Saab Parts:
dantinne is offline
Old 04-17-2013, 06:32 AM   #20
People still get pop ups? What is this, 2003?
BuHuSPG is offline
