Intercooler project - The Saab Link Forums
Old 04-13-2010, 03:16 PM   #1
quick4door's Avatar
Intercooler project
So i would have gotten further, but FED-EX is a liar....said it was in the truck for delivery, yet nothing showed up today.
anyway, pulled the front end off, came off really easy.
was thinking about where to put the IC and decided i want to yank the stock IC and move the A/C condenser back. this was easier then I thought. i cut the brackets that hold the stock IC, unbolted the a/c fan, moved things around and the IC dropped out. then the a/c just went into the holes that it would go into if the car were N/A.
i now have 3.5 inches between that support and the a/c. as soon as the IC gets here tomorrow I hope. ill make the brackets to support it.
1998 9000 CSE 5 Speed
1989 Classic 900 Sedan SPG
1988 9000 Turbo
1995 Jeep Wrangler 4.0 Turbo
quick4door is offline
Old 04-14-2010, 04:10 AM   #2
mcrowley's Avatar
Nice! That looks like a fun project.
You bringing the c900 or the 9k to SiS?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-14-2010, 04:40 AM   #3
quick4door's Avatar
thanks, the 9k is going to sis, the c900 is still in need of a tranny
1988 9000 Turbo
Old 04-15-2010, 05:05 PM   #4
quick4door's Avatar
well got it finished today, so far so good with the results. hot side i used one 90 deg. 2.5in pipe and 2 90 deg. elbows, cold side was 2 90 deg. pipes and 2 90 deg elbows.
1988 9000 Turbo
Old 04-15-2010, 06:22 PM   #5
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Did you roll a bead on the pipe ends so the hoses don't slip off? I've done some research and most people stongly recommend doing something to flare the ends. You really don't want a hose to blow off. Looks awesome though, I'm glad you did it before me, now I know exactly what pipe to use!
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
Old 04-15-2010, 07:09 PM   #6
Uniballer's Avatar
was this a kit and if don't mind, How much does $ it run?
Mike
'97 9000 CSE
stage 1 by MikeD
Uniballer is offline
Old 04-15-2010, 07:23 PM   #7
quick4door's Avatar
ebay special, it was 186 shipped. its a 28x7x2.5 IC. i got the two couplers for the turbo and TB from http://siliconeintakes.com
for the pipes slipping off all, i only lost one of the rolled edges, to fix it i used the cheapest hairspray i could find, makes it east to slip on and a complete bitch to get it off, with the hairspray and band clamps i hope Ill be fine, if not ill have the edges rolled
1988 9000 Turbo
Old 04-18-2010, 02:30 PM   #8
zach9000's Avatar
that's sweet.
notice any improvements?
zach9000 is offline
Old 04-18-2010, 03:23 PM   #9
you dont even need a full bead, you just need like 4 tiny spot welds on the edges of the pipe...ive never blown mine off with 25 psi
1996 SAAB 9000 Aero , Black on Black - SOLD
2001 SAAB 9-5 Aero, Silver on Black
MikesAERO is offline
Old 04-18-2010, 04:44 PM   #10
quick4door's Avatar
yea noticed a little difference, spools quicker. now for the tune.
1988 9000 Turbo
Old 04-18-2010, 06:33 PM   #11
mcrowley's Avatar
Nice
I bet you'll also notice that the boost doesn't taper/fall off anymore.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-19-2010, 12:01 AM   #12
comtrang's Avatar
Yeah other than whatever hp benefits you get (I found about 10whp across a chunk of the rev range), it felt so damn nice to be able to do consecutive pulls without feeling a loss in power on the butt dyno. Addicting.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 04-19-2010, 07:44 AM   #13
christian900se's Avatar
Very nice, that is probably one of the nicest fits I have seen in terms of centering the intercooler in the lower valence!
christian900se is offline
Old 04-22-2010, 07:32 AM   #14
DanF.'s Avatar
Could you have fit a taller IC in that position? I have a 12x18x3 (core... counting end-tanks) that I have laying around.
Just curious.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 01-01-2011, 04:01 PM   #15
zach9000's Avatar
what is the coupler for the throttle body?
i think its a 3inch to 2.5 inch 90 degree bend right?
zach9000 is offline
Old 01-20-2012, 07:34 AM   #16
2.75 to 2.5 90 degree
im wondering...was it even necessary to move any of the components at all? it appears the new intercooler is mounted in front of where everything was in the first place
Old 09-13-2019, 08:01 AM   #17
What size couplers did you use for the turbo and tb
9000a is offline
