T5 Plug & Play Conversion - The Saab Link Forums
Old 06-14-2009, 07:03 AM   #1
adshaft's Avatar
Here's my DIY to convert your DI/APC to T5 plug & play style.
My car's a 91 9000 Turbo and the T5 harness is from a 95 9000 Turbo. I have yet to attach it to the motor, cause my pistons are out to get coated, so will have to update once it actually works.
I went this route of using plugs from other harnesses to make a harness which can be removed easily and can be adapted to another car with very minimal work. You can just use your existing plugs or just tap into whatever wire if you'd like. My way there are only three wires that I have to tap into (BCV GRN/RED --- Purge Valve YEL/RED --- Switched Ignition --- BRN/WHT)
they are covered inside. You can use your existing Speed Sensor since it is attached directly to the Instrument Cluster. You will need to get a CPS (Crankshaft Position Sensor) and you will have to install a Timing wheel. There are a few threads on this:
https://www.saablink.net/forum/showth...t=28125&page=5
https://www.saablink.net/forum/showthread.php?t=33456
**I would strongly strongly suggest using the grey plug which connects to the T5 harness. It will make your job incredibly easy.**
From the list of wires coming from the Grey Plug, There are a few which I did not tap into:
#10 Blu/Wht - Diagnosis
#18 Wht - Engine Torque Limitation
#20 Grn/Wht - Can Bus (Small Plug)
#33 Wht - Brake Light Switch (might use this one, not sure yet)
#39 Grn/Wht - Cruise Control
#49 Grn/Red - A/C Out
#50 Grn/Wht - A/C In
If anything changes, I will update the thread.
MikeD helped me out on a few things, so big thanks bud.
I've spent many many hours and days studying all these diagrams and wiring. Now with this DIY you can probably have your car T5'ed within only a few hours. Enjoy
Adam
Diagram of 91 9000
[IMG][/IMG]
Diagrams of 95 9000
[IMG][/IMG]
[IMG][/IMG]
Harness used (95 9000)
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
**Uses a different type Coolant Temp Sensor**
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
**Just use your existing speed sensor, cause 95+ use this type of plug**
[IMG][/IMG]
[IMG][/IMG]
[SIGPIC][/SIGPIC]
adshaft is offline
Old 06-14-2009, 07:03 AM   #2
adshaft's Avatar
Onto the good stuff:
I think the pictures will tell you all you need to know.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
***update***
Siliconed the Fuel ECU plug & tapped into the purge and switched ignition wires located in the main harness near the battery tray.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Still have some little things to do like siliconing the Fuel ECU plug, taping off the harness etc... Will update accordingly.
[SIGPIC][/SIGPIC]
adshaft is offline
Old 06-14-2009, 07:38 PM   #3
Green9kAERO's Avatar
good stuff!!!!
Green9kAERO is offline
Old 06-15-2009, 07:03 AM   #4
tuner4life's Avatar
Looks awesome, I'll have to have my tame wiring expert look at it to see If he can do this. Have you thought about making these to sell?
-Jason
1992 Saab 9000 Turbo - Cirrus White
1986 Saab 900 Turbo SPG Clone - Admiral Blue
1992 Saab 900 Base - Talladega Red
tuner4life is offline
Old 06-15-2009, 07:34 AM   #5
adshaft's Avatar
Thanks guys, it's kinda time consuming to make, don't have time to market them. Still gotta see if it works though, with my luck the ignition will turn and.........nothing. Haha hope I'm wrong.:
[SIGPIC][/SIGPIC]
adshaft is offline
Old 06-16-2009, 12:52 AM   #6
That's whicked cool you'd probably be the first guy doing a plug and play set up you should advertise it. I just want to know what are you doing with your old DI/APC box and the LH ecu I've been looking for them because I have an extra motor sitting on the side but I really can't do anything without the computers I need would you be willing to part them.
SS929k is offline
Old 06-16-2009, 04:30 AM   #7
adshaft's Avatar
They were sacrificed for this project. I actually only needed the Fuel ECU (located in the aquarium) to be sacrificed, but it was trial and error. Don't know if I have any left, if I do I will PM you.
[SIGPIC][/SIGPIC]
adshaft is offline
Old 06-16-2009, 09:38 AM   #8
BPC.....
2 wires go to the grey plug... isnt the other one a ground? pin#2 on the BPC plug
Old 06-16-2009, 04:03 PM   #9
adshaft's Avatar
Don't have my specs pages with me, by memory I think it was hot wire that went to the fuse box. Will let you know tomm.
Edit: Yes it is a hot wire running through fuse # 5.
[SIGPIC][/SIGPIC]
adshaft is offline
Old 01-17-2010, 01:43 PM   #10
bump so i dont need to keep searching for this thread when i want to look at 9000 wiring diagrams
Old 01-19-2010, 11:37 PM   #11
Are you using the T5 crank position sensor or the one made for the motor
SS929k is offline
Old 01-20-2010, 09:11 AM   #12
im using a t5 engine and transmission in my 92.....
Old 01-20-2010, 11:28 AM   #13
saabingforlife99's Avatar
dont forget your intake temp sensor.
can i get enough boost to put the head into the hood??
saabingforlife99 is offline
Old 01-20-2010, 12:09 PM   #14
JK
JK's Avatar
Why don't you tag the thread?
always a SAAB guy at heart
JK is offline
Old 01-20-2010, 01:16 PM   #15
Oh now I fully under stand what your doing. I thought you were just going to use the t5 ecu with the 92 motor. So basically your negating using the full car harness (Headlight to tail light) by splicing the important wires together to get the car running.
SS929k is offline
Old 02-09-2010, 09:25 AM   #16
ok i have t5 out of a 1996 9000 cse installed in my 91 9000 my trionic box is from a 96 cs. my car runs but i need to know who is experiencing what with the crank sensor wheel i have mine on the crank pully and set on the 20th slot.my car was missfireing a lot and i went through alot of diag and came down to timing issue so i unbolted the bracket for the sensor while the car was running and moved it down about 2-3 slots car started running alot better.. so my question is what slot should the sensor be on with the engine at TDC and my second question is does trionic 5.2 and 5.5 have different settings for where the sensor is
thanks in advace guys
white9ktalladega is offline
Old 10-23-2010, 02:41 PM   #17
SOAB's Avatar
How much of this would be aplicable to T5ing a classic, cause I need this level of detail soo bad! This is just too awesome!
until something like this is available for saabs, there will be no slammage.
SOAB is offline
Old 11-04-2010, 05:29 AM   #18
Wiring diagram T5.2 needed
I'm going trough the same steps you are addshaft. I'm converting a classic 900 to trionic 5.2. I only have a 5.5 wiring diagram and compared with T5.2 there are some considerable differences. Can you or anyone help me finding a 5.2 diagram? Regards Torsten
Torsten is offline
Old 11-04-2010, 07:58 AM   #19
mike d's Avatar
t5.2 is BS its not worth the effort
i promise, it is much easier to fab a CPS wheel and bracket, than to sort out a t5.2 harness. Trust me, ive done both
never mind that the scarcity of ECUs can turn tunng into a nightmare
MikeDTuning.com
mike d is offline
Old 05-16-2011, 12:38 PM   #20
SOAB's Avatar
Hey! I might have an opportunity to pick up a good bodied 1992? 9000 with an N/a 2.0 for the cost to tow it. I currently have a pretty beat up 1995 9000 Aero. Would this be the thread I would want to foolow if I were to take the heart of my car (engine and harness) and put it into the 1992? Or would that be a whole different project?
SOAB is offline
Tags
t5 conversion
