Anyone using Wossner pistons in 9K? - The Saab Link Forums
Old 02-03-2008, 05:21 AM   #1
mvadenais's Avatar
Ive heard JE pistons might clack or make noise (even if fitted correctly) anyone hear anything about Wossner or currently running them- in a 9K. A friend of mine is running them in his MY Viggen. Quietest engine Ive heard.
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 02-03-2008, 05:54 AM   #2
jssaab's Avatar
I have them in my 9-5 super wuitet but anohter guy has them in his viggen and they clack a bit when cold for a few seconds or a minitue or two til warm especially when cold out...
jssaab is offline
Old 02-03-2008, 06:11 AM   #3
mvadenais's Avatar
Do you think that is a common issue with aftermarket pistons? (the clack?). As longs as you don't get clack when its warm I suppose? Are you running the JE or Wossner
88 900 SPG Black
95 9000 Aero Green
Old 02-03-2008, 06:46 AM   #4
The "clack" you're describing is attributed to slight piston slap of a cold engine. That's common to most forged pistons when they're cold, which should just serve as a reminder to let the car warm up slightly before beating on it...
But you really don't need forged pistons with a 9000 unless you're planning to run huge boost, or if your original pistons fail....
Old 02-03-2008, 07:28 AM   #5
mvadenais's Avatar
Im rebuilding an engine at the moment. Looking for 350-375hp range. Having short block rebuilt and head done along with lots of other things. I predict boost from 20+? depending on tuner. I want to stick with SQR.
88 900 SPG Black
95 9000 Aero Green
Old 02-03-2008, 07:45 AM   #6
ohlins8990's Avatar
Send a message via AIM to ohlins8990 Send a message via Yahoo to ohlins8990
well Kaylan has 476whp on stock internals, just to give you an idea how tough that engine is.
ohlins8990 is offline
Old 02-03-2008, 07:50 AM   #7
daveship's Avatar
no clacking of pistons in my 9-5. very happy with the JE's so far.
dave
daveship is offline
Old 02-03-2008, 08:12 AM   #8
JK
JK's Avatar
I believe she has less than 1000 miles on the motor with that amount of power, so that really says nothing.
always a SAAB guy at heart
JK is offline
Old 02-03-2008, 08:26 AM   #9
mcrowley's Avatar
Last time I talked to him, Terry from NC said he was still on stock pistons (at 400whp).
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 02-03-2008, 11:40 AM   #10
saabingforlife99's Avatar
forged pistons are small when cold, so when running lots of power which makes alot of heat, they can expand without blowing up. thats why race cars smoke and sound like crap when they are cold.
can i get enough boost to put the head into the hood??
saabingforlife99 is offline
Old 02-03-2008, 01:37 PM   #11
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
Im not the only person to ever do this with a 9k motor... just the only one in the US. (that posts on teh interwebz*)
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 02-03-2008, 02:50 PM   #12
mvadenais's Avatar
Im not saying the stock components can't handle the power, just doing a rebuild and want to know what people are running. AeroDynamic: Did you use the original pistons in a rebuild (or did you rebuild)? I know of your car (its nasty by the way).
88 900 SPG Black
95 9000 Aero Green
Old 02-03-2008, 02:58 PM   #13
Nope everythings stock and never been rebuilt. Blew the first head gasket last month and replaced it with stock.
Old 02-04-2008, 06:55 AM   #14
JK
JK's Avatar
Oh, I know
I'm just pointing out that your car was used as a reference that the motor can handle it safely, but with very little milage I don't think your car is a good example of longevity (yet) because of how few miles you have put on (thus far).
I'm not insulting you, so don't take it down that road
Just put some miles on that thing!
JK is offline
Old 02-04-2008, 08:37 AM   #15
Soon.
Old 02-05-2008, 11:02 AM   #16
JZW
I get some light clacking when the motor first starts especially when its 0-20F and then it goes away as it warms up. I run the je forged pistons with the coatings on the top and sides.
You should be perfectly fine with stock pistons up to about 450bhp.
I did break some, but I was drag racing it with 30psi and mixed nitromethane with my w/m injection. It was a power-house and I now suspect my stock fuel pump was not up to the task. After installing my walbro 255 fuel pump, my a/f dropped a half a point and it went from 11.0/1 to 10.5/1 past 5500rpm with 27psi of boost.
John
JZW is offline
Old 02-05-2008, 12:37 PM   #17
ylee coyote's Avatar
When I rebuilt the engine at 200,000 miles one consideration was to go to forged pistons
however the prospect of increased clearances ,worse oil consumption and a re-build at 50 k put me right off
so changed the rings deglazed the bores and ....well nothing else
60k running at 400 hp + I think I have proved the longeivety...
still using no oil between services (apart for gearbox oil which likes to spread itself on the floor every few thousand miles)
ylee coyote is offline
Old 02-05-2008, 09:27 PM   #18
JZW
HHHMMM, I thought you can make you're end gap pretty darn tight and with something like total seal rings, the blowbye is very minimal if the motor is set up tight. The min for my set-up was .015", Turbo charged .017-.022" then nitrous at .022-.024"
These end gap settings of the compression rings and oil rings would determine the amount of oil blow*bye I would think.
The saab oe ring specs are around .021" I think, that might let some bye, but my motor is not using hardly any oil at all.... Forged JE with .017" for gt3071 and 400+bhp
John
JZW is offline
