BSR stage 1 tune not performing - The Saab Link Forums
Old 08-05-2014, 11:19 PM   #1
Hello fellow Saabers. I have a 2005 9-5 Aero with BSR stage 1 tune. It came with the car. I was curious to see what the performance difference was between the tune and original, so I switched it back to original and found no performance difference at all. Then tuned it again to find same. I contacted BSR and they advised it most probably be a mechanical issue with my car if there is no power gain with the tune on.
How would I best look into this. where could the fault be. The car drives fine. However I did actually notice that the original tune was a little bit more responsive and the boost needle actually went into the red sometimes, while when on tune I never really see the needle go inside the red (over boost)
I had the car for 2 years and thought this was how its surpose to be tuned until I switch back to original. The tune was installed in 2009, does time make a factor to the tune.
Mimosa is offline
Old 08-06-2014, 05:06 AM   #2
Wagon Shaggin'
Saabeh's Avatar
New plugs, vac lines etc. Or have a local tuner look at the file.
Saabeh is offline
Old 08-07-2014, 12:31 PM   #3
bergie's Avatar
bsr tunes are generally garbage.
bergie is offline
Old 08-12-2014, 12:22 PM   #4
mike d's Avatar
time factor doesnt change a thing, A tune should make a car quicker, if it doesnt, one of two things is present
- there is a mechanical error with the car
and/or
-the software is not setup correcty,
To get to the bottom of it it may not be a bad idea to get ahold of somebody who knows how to diag these issues, If i can help feel free to give me a call
978 877 9862
Mike d
MikeDTuning.com
mike d is offline
