Lowering a Saab 9-5 Wagon... - The Saab Link Forums
Old 11-02-2013, 08:10 PM   #1
Winglessflight97's Avatar
Hello Saablink.net!
I'm a proud owner of a slick all black Saab 9-5 Aero Wagon , and recently was told at a recent alignment servicing that my rear springs were sagging, so why not take this opportunity to replace the old springs and struts all at once and get a new stance at the same time? I have two questions.
1. Is this kit a suitable option for the Aero wagon, considering it isn't listed as one of the compatible vehicles (extra rear weight)?
Eibach 7810.780
2. Has anyone had issues with the existing plastic wheel wells with their lowered cars? It seems that they might make contact. Thanks in advance!
Winglessflight97 is offline
Old 11-02-2013, 08:13 PM   #2
oliversexpedition's Avatar
Yes don't run 235-45-17s on lowered wagons, it will rub.
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 11-03-2013, 06:37 AM   #3
mike d's Avatar
if you are looking for springs, look for wagon specific springs. that way you wont need to put spacers in,
im a fan og B&G products like this one
B G lowering Springs 99 07 9 5 2 0 2 3T Wagon 78 1 011 | eBay
MikeDTuning.com
mike d is offline
Old 11-03-2013, 09:21 AM   #4
The thing with the Eibach kit is that I can get that whole kit for under $100, believe it or not, complete with springs, struts, and all, thanks to a supplier that just wants to get rid of them. Unbeatable deal! So where could I get spacers, and do I really need them? We're only talking about 150 lbs weight difference between the sedan and wagon, and my headlights are self leveling anyway, or is there more to it than that?
Old 11-04-2013, 06:59 AM   #5
As long as you never plan on carrying anything in the wagon, you should be OK. The different spring rates and brakes for the wagon are specified for the additional load carrying capacity of the car in addition to the extra sheet metal and glass.
Old 11-04-2013, 07:11 AM   #6
bergie's Avatar
why have a wagon and plan on not carrying anything in it ? get spacers son.
bergie is offline
Old 11-24-2013, 09:53 AM   #7
I got significant front rubbing and some rear rubbing when the rear is loaded on my 03 9-5 aero wagon with 235/45/17 on BBS RKI rims. I drive on bad roads and do carry passengers and load in the bad, so I decided not to lower my car. I also installed ride height spacers and shims in the back to rectify the negative camber issue.
Escargot is offline
Old 11-25-2013, 05:43 PM   #8
Saab95Aero's Avatar
55 is massive... 17's should be running 45 profile
i bought these the rears sag and the front sit super high worst option.... trust me eibach i think is the way to go
Saab95Aero is offline
Old 11-25-2013, 05:46 PM   #9
Saab95Aero's Avatar
Im running 245/40/18's rubbing goes away once your tires melt all the plastic away, this is the stance i ended off at loved it...
but this was about 80mm lowering vs stock but it was veryyyy hard to drive the tire would sit on the fender most of the time lol and the jack would not come out :s you also need a lot of camber adjustment, some people do for camber bolts but im getting my coils modified with a custom strut mount / camber adjustment plate...
Old 11-26-2013, 08:14 AM   #10
Do NOT buy the eibach struts
I thought I had found a great deal, but they are TERRIBLY soft, and under damped.
you'll blow them out quick and be looking for a set of bilsteins in less than a year.
With my B&G springs and TSW spa's, I rub the front with a 235/40/18
rear never rubs.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 11-26-2013, 12:21 PM   #11
Saab95Aero's Avatar
rear never rubs.
ahaha it was even worse when i added a 10mm spacer but its SOOOOO flush i also have TSW rims i love them
I actually have a used set with of bilstein sport struts with eibach springs on my parts car it drove like a couch on wheels soooo smooth its insane..
Old 12-13-2013, 05:33 PM   #12
Well, as it turns out, the online store that had them refunded my money, probably because they were out of stock. C'est la vie. Looking for a new solution to my rear camber issues without raising my car. Someone said something about camber bolts/kit? And what is a good spring/strut combo for my car? I'm looking to lower it no more than an additional 1 to 1 1/2 inches.
Old 12-15-2013, 06:06 PM   #13
Saab95Aero's Avatar
for real camber issue they have shims to fix them genuine saab sells them, the two rose buds in the rear control arms tend to let go and get very loose, the main trailing arm also tends to fail and that can cause a lot of bad camber..
check this out that's the rear trailing arm moving a crap load. lol
Old 01-13-2014, 08:58 AM   #14
I tried to replace the rear springs on my 03 9-5 aero wagon with new factory ones but that did not solve the sagging rear end. I think the factory springs are simply too weak and I've been advising people to do shims and spacers instead of wasting money on new springs. Hope your lowering springs don't have the same problem. Also check for worn bushings in the rear suspension.
I live in a place with bad roads so I tried to preserve the stock ride as much as possible with a little more stiffness and durability. I've been running my Eibach struts and shocks for more than 5 years/~70k mi now, still good *knock on wood*.
Escargot is offline
