04 engine in 00 saab - The Saab Link Forums
Old 11-06-2012, 09:59 AM   #1
marshkid's Avatar
Hey all,
Is it possible to put the 04-07 engine in an 00 aero?
I know the pcv system changed, but just curious if anyone has a more info on this.
Thanks
Mike
marshkid is offline
Old 11-06-2012, 10:07 AM   #2
jssaab's Avatar
Easy Peasy, either use the older manifold ( intake) , and charge air pipe with your sensors or if you get the newer engine with throtle body and charge air pipe, use that and rewire all the sensors
jssaab is offline
Old 11-07-2012, 08:07 AM   #3
marshkid's Avatar
Awesome, that sounds very easy. But what about the PCV system. I thought the newer engine had some additional pipe into the block.
And for the rewire, do I just splice the wires into the newer plugs? do they all match up or what ?
Thanks
marshkid is offline
Old 11-08-2012, 10:21 AM   #4
jssaab's Avatar
Jsut conect the PVC as it is in an 00, same hoses, jsut attach differently.
The older manifold the newr sensors do not have the correct screw holes, but you can cut and slice the wire colrs are the same
jssaab is offline
Old 11-09-2012, 04:52 AM   #5
If possible, get the intake and throttle body WITH the 04 engine. Biggest change in the pcv system is the huge port in the 04+ throttle body (which draws directly from the oil trap instead of the tiny vacuum hose from the valve cover). Using the older pcv system negates the benefits of using a 04+ engine
just my .02
seriks1 is offline
