2nd Lambda Voltage - The Saab Link Forums
Old 03-04-2012, 08:09 AM   #1
gto47's Avatar
2nd Lambda Voltage
Hey guys, was wondering if anyone knows the average voltage output from the second lambda. Thanks.
gto47 is offline
Old 03-04-2012, 10:09 AM   #2
SPG-GASM's Avatar
.5 volts
SPG-GASM is offline
Old 03-04-2012, 04:05 PM   #3
gto47's Avatar
Thanks. I am running about a .63 at idle, and revving it up to brings it to .78. Does this sound like my catalyst is ineffective?
gto47 is offline
Old 03-04-2012, 06:24 PM   #4
SPG-GASM's Avatar
Do you have a CEL? Or are you curious to see if your cat or o2 sensor is a problem?
Also the voltage will fluctuate when the throttle is depressed and released. It should settle to around .5 v. If you have .63v at idle what about cruise? should be about the same. It could be the o2 sensor starting to fail also, but its not really that bad of a reading.
SPG-GASM is offline
Old 03-04-2012, 07:43 PM   #5
gto47's Avatar
Well, I am not running a catalyst at all. Let me first insert "track use only configuration" disclaimer. I am using an o2 simulator to circumvent the check engine light. See link here I may need to use a different jet, but have done 150 miles now and so far no check engine light has come on. I just wanted to know what the range should be because I was not able to find it in WIS. They only list the range for the first sensor.
gto47 is offline
