New suspension and summer wheels/clear corners - The Saab Link Forums
Old 04-03-2011, 05:16 PM   #1
2006 9-5 SportCombi with 19" Rial Nogaro's, clear corners, B&G Springs and Koni Yellows
By tuttiface at 2011-04-03
tutti is offline
Old 04-03-2011, 05:24 PM   #2
jssaab's Avatar
THanks for posting the suspension details here, any rubbing?
jssaab is offline
Old 04-03-2011, 05:31 PM   #3
They've been on for less than a week and no rubbing yet.
The tire's are 225/35/19.
tutti is offline
Old 04-03-2011, 06:46 PM   #4
HIDSPG's Avatar
Nice looking car!
88 SPG, 08 TX Combi
HIDSPG is offline
Old 04-03-2011, 10:15 PM   #5
132417SAAB's Avatar
car looks great with the 19's on it
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 04-04-2011, 02:42 AM   #6
mvadenais's Avatar
great looking wagon and cool dog.
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 04-04-2011, 05:48 AM   #7
Wagon Shaggin'
Saabeh's Avatar
Wow, awesome.
Saabeh is offline
Old 04-04-2011, 05:55 AM   #8
chevyman's Avatar
That looks great!
1995 900 se turbo
chevyman is offline
Old 04-04-2011, 01:18 PM   #9
Thanks all!
tutti is offline
Old 04-04-2011, 01:24 PM   #10
How does that set up feel on the road?
Also what % is the tint??
Old 04-04-2011, 01:52 PM   #11
I just did that setup minus the B&G, I did Eibach Pro Kit and set the Koni's in the middle, I also use the MOOG balljoints and barlinks (much thicker than the OEM links). Had the allignment for Aero spec and wow !
cking1975 is offline
Old 04-04-2011, 02:19 PM   #12
mcrowley's Avatar
Great looking car.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-05-2011, 04:15 AM   #13
romanoaf's Avatar
The b&g's look great.. Makes me wish i didn't go with the Vogtlands..
Out of curiosity, where are you from? I think see Ontario plates there
romanoaf is offline
Old 04-05-2011, 09:15 AM   #14
I'm in Mississauga.
To be honest, I've been wishing for the vogtlands. I was not happy with the B&Gs when I put them on last fall. The back end was o.k (it's on the upper perch with a 3mm spacer, tight now) but the front didn't seem to drop at all. Maybe they have settled/sagged over the winter.
tutti is offline
Old 04-05-2011, 10:07 AM   #15
I had the same problem in the rear with the Eibach springs, I actually took the metal sleeve off and tightened the bolt down more, this allowed the spring to compress tight. In addition I used rubberized 3M spray on the shock housing, strut housing etc, especially on the parts the spring rest, fender wells, etc, this had made the suspension super quiet and other than having a little come off onto the inner wheel in the beginning, which I cleaned off with wheel cleaner, I am very please with the lack of road noise, etc
Old 04-05-2011, 10:52 AM   #16
romanoaf's Avatar
Originally Posted by tutti View Post
I'm in Mississauga.
I thought so, I remember seeing those wheels for sale in the area.. I'm in London.. I have the same problem with the Vogtlands, the rear sits perfectly, but the front looks like it barely dropped
https://www.saablink.net/forum/custom...-9-5/54517.htm
More pics at the bottom
romanoaf is offline
Old 04-05-2011, 06:22 PM   #17
Your car looks great!!! How many fingers can you fit between the tire and fender? I used to be able to put 3 and now only two. Might settle, I'd say wait a bit and see what happens.
tutti is offline
Old 04-06-2011, 05:52 AM   #18
romanoaf's Avatar
Thanks! Right now, 2 in the rear, 3 in front (there's probably a joke in there).. I'm running some pretty tight tires though, and moving up to 225/235's would probably help fill the gap for me..
romanoaf is offline
Old 04-06-2011, 02:51 PM   #19
ma61's Avatar
Looks great tutti.
Would you be able to post a profile picture from the front or rear to show how the wheel sits with the edge of the fender?
ma61 is offline
Old 04-06-2011, 06:25 PM   #20
Do these help
By tuttiface at 2011-04-06
Camber much?
tutti is offline
