Spark Plug Talk Your Insight - The Saab Link Forums
Old 10-20-2010, 04:33 AM
So I was looking at Spark Plugs online today and I am amazed at how many new plugs are on the market for the Saab's...I would like some insight on these plugs if anyone has any...they range from...cheap to ouch
NGK Spark Plug Basic 1.95 each
NGK Spark Plug Double Platinum 23.00 each ouch !
This is a massive difference in price...I dont think there is another car part for our cars with such a huge price difference !
My source
http://www.autopartswarehouse.com/se...BMvH0hB8VNk-ag
cking1975 is offline
Quick reply to this message
Old 10-20-2010, 07:03 AM
Personally I do not use platinum plugs, I always run NGK Iridium IX plugs. Platinum plugs are very expensive, wear out faster, and are not as reliable in boosted engines as iridium...not to mention iridium produces a more powerful spark than platinum. You hardly see them in OEM applications because they last so much longer than any other plugs on the market...have to keep people coming back to the dealer you know.
I usually can get 40,000 miles on my plugs and they still have some tip left.
AutoXer01 is offline
Old 10-20-2010, 08:00 AM
jssaab's Avatar
There are only 2 plugs that will work on trionic and they are listed in your manual
BCPR6ES ( use 7 if you are tuned) and the Aero Platinum plugs.
All of the others WILL NOT WORK, they may fit but will not work with the Trionic system as required. ( It uses the plugs for knock detection and the system was only calibrated to work with the plugs listed in the manual)
jssaab is offline
Old 10-20-2010, 08:56 AM
Raven18940's Avatar
Use the plugs listed in the manual in the heat range specified by the manual.
ie Don't fuck with it. It ain't broke, so don't try to fix it.
2001 Saab 9-5 Aero
Raven18940 is offline
Old 10-20-2010, 12:54 PM
Its crazy to think someone would pay 100 dollars for sparkplugs...that is my thing...I use the 4 dollar plugs and they are perfect.
Old 10-20-2010, 03:02 PM
Snabb SAAB's Avatar
Are you sure that it isn't $23 for a set of four??
Current SAABs: 2000 9-5 Aero SC - 1987 900i 8v Past SAAB: 1995 900 SE Turbo
Snabb SAAB is offline
Old 10-21-2010, 06:06 AM
Same here. Even in my high horsepower cars I use zfr7f's. Ya they start to suck around 1500 miles but its seven bucks for 4 and i change the oil around that time anyways. (takes me 3 months to put on that many miles and thats pushing it).
FIND YOUR ANSWERS HERE!
frogg5872 is offline
Old 10-21-2010, 06:07 AM
I priced them on google for $11.20 a piece
Old 10-21-2010, 06:14 AM
jssaab's Avatar
If you using them on a high power Saab you are destroying your engine. Check Knock Detection and MIFI on your Sid and get the grim story
jssaab is offline
Old 10-21-2010, 07:24 AM
what about the bkr7e-11's? the Vpower plugs? How would that be different than the standards?
bigsyke is offline
Old 10-21-2010, 07:34 AM
How is changing sparkplugs really going to add horsepower?
Old 10-21-2010, 08:04 AM
Raven18940's Avatar
It's not, but once again people think they're cleverer than the engineers. If different spark plugs could net you 20 hp, don't you think the factory engineers would have done it?
Here's the facts on the matter. The SAAB Direct Ignition module is a complex and extremely high voltage ignition system. It doesn't matter whether your plug is copper or platinum, it has more than enough energy to jump the gap even when the gap is out of spec wide. It also uses the plug to do ion sensing. This allows the ECU to detect the conditions of knock before it actually happens. The use of stock plugs is imperative to this function. The stock ECU runs as close to knock as it can to extract the most power possible. This is not a system you want to mess with and experiment with different plugs.
The standard model copper plugs are $7-8 for a set of 4, the aero platinum plugs are $45 a set or so. How $8 is too much for plugs I don't know. If you have an aero and you're a cheap bastard who can't cough up $45 every 1-2 years, then just use the standard model copper plugs.
2001 Saab 9-5 Aero
Old 10-21-2010, 11:10 AM
jssaab's Avatar
There is a V groove in the electrode that will change the electrical flow pattern. Trionic was engineered to measure ions to determine proper air/fuel ratio and detect knock, at the very limits of knock detection to allow the engine to run at its best and the engineers did not ( as raven points out) care to test every freakin plug you can screw into the dang hole with the proper thread size and reach ( that is all equivalence does in plug matching) with the proper heat range.
so why spend more ( sometimes) or less that can screw it up and make the engine run harmfully lean or expensively rich?
And there have been so many people that I can; remember how many who have come on here ( and other forums) with all sorts of issues that magically go away when we say change the plugs.
There are a few that don;t listen but funny they don;t stay on the forms long..
jssaab is offline
Old 10-21-2010, 11:35 AM
Raven18940's Avatar
Spark plugs are still my first recommendation for a CEL that has no symptoms.
2001 Saab 9-5 Aero
Old 10-22-2010, 12:49 PM
Who said plugs add more power??
They can allow you to tune your ecu for more power...even then we're talking 30+_ psi levels that it makes a dramatic difference, but simply replacing them does jack.
Old 10-23-2010, 05:48 AM
I don't think anyone said spark plugs add more power...the thread is based on spark plug options for the DI saab engines and what if any reason is there to buy the most expensive plugs versus the cheaper plugs...from what I have read online in regards to DI systems for pretty much any engine...the spark capability of the DI is much higher than the engine actually needs and the OE plugs recommended for the engine are more than enough to support the performance of the engine...the only time spark plugs have ever EVER added HP is if the OE plugs in a car did not ignite air and fuel at maximum efficiency...In conclusion...why buy the expensive plugs...?
Old 11-09-2010, 06:16 AM
Dudethe9-5isfast's Avatar
Actually you can gain 30 hp from changing plugs.
If you have the wrong plugs in there, you can lose 30 hp due to T7 being conservative when it cannot complete the Knock sensor circuit. Replace it with correct BCPR6ES /7ES & you will get your 30 hp back.
Dudethe9-5isfast is offline
Old 11-09-2010, 08:28 AM
jssaab's Avatar
Other engines that use a DI are not Saab Trionic!!!! You MUST USE ONLY those designed ( as raven says) for the Saab Knock detection, or you will lose HP ( see below) as Trionic tries to compensate for what it believes is a problem with your engine when using these other plugs to detect knock
jssaab is offline
Old 11-09-2010, 08:46 AM
Raven18940's Avatar
SAAB Trionic is a sleeping dragon you do not want to wake up.
2001 Saab 9-5 Aero
Old 08-17-2012, 06:52 AM
Dear wicked old thread from forever ago.
I was wondering about this, as I've been running the v-power plugs in my aero. (okay, it's a Gary Fisher, but it's all Aero'd out)
Has anyone had any positive experience yay or nay on them?
I've ALWAYS used them for DSM's and even my old t5 cars, and didn't even consider that t7 may be too sensitive for them.
I just decided to search'em out on here since I'm doing a oil/plug change today.
I get that we're not *supposed* to change from the norm, but does anyone have any actual proof that they are good/bad?
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
