PVC off-road modification - The Saab Link Forums
Old 10-06-2010, 11:39 AM   #1
Hello,
Wondering if anyone has a good reason why I shouldn't do the following for
"OFF ROAD USE"
-Gut pvc value,
-connect to oil separator/collection tank
-vent to air
Thoughts?
cndnate1 is offline
Old 10-06-2010, 11:46 AM   #2
Wagon Shaggin'
Saabeh's Avatar
The engineer who designed the "PVC" system is much smarter than you.
Saabeh is offline
Old 10-06-2010, 11:51 AM   #3
DeLorean's Avatar
venting the PCV system into the atmosphere should be no problem, but if you have any sort of emission test and they spot it, it will fail. Also, the point where the system "vents" will get very oily so make sure it is not near any rubber parts.
DeLorean is offline
Old 10-06-2010, 11:53 AM   #4
dan-the-kid's Avatar
Good to have you back.
dan-the-kid is offline
Old 10-06-2010, 11:57 AM   #5
laxian55's Avatar
Catch can prevents things from getting oily.
laxian55 is offline
Old 10-06-2010, 11:59 AM   #6
Wagon Shaggin'
Saabeh's Avatar
If you have PCV #6, it has a built it catch tank.
http://www.eeuroparts.com/Main/PartD...px?id=55561200
Saabeh is offline
Old 10-06-2010, 12:32 PM   #7
I'm going to hook an oil catchcan in line, and put a filter on the vent end.
Sounds like an easy upgrade to me & no more oil in the intake tract.
cndnate1 is offline
Old 10-06-2010, 12:39 PM   #8
Raven18940's Avatar
2001 Saab 9-5 Aero
Raven18940 is offline
Old 10-06-2010, 12:50 PM   #9
Originally Posted by Raven18940 View Post
Yep, saw that for sure.
cndnate1 is offline
Old 10-06-2010, 12:59 PM   #10
JK
JK's Avatar
You were wondering if anyone had a good reason for not doing it...I'd say that is a perfectly viable response.
Typically when I think of modifying something, I try to think of a good reason why I should do it, not a good reason not to. What will the net benefit be? Do the benefits outweigh any potential issues?
The T7 motors tend to be a bit more sensitive when it comes to the PCV system. I personally wouldn't stray from the latest/greatest OEM PCV update. There is a reason why it has been updated to what it is today.
always a SAAB guy at heart
JK is offline
Old 10-06-2010, 01:10 PM   #11
Actually, when I am looking at the PVC system I think about what it is designed to do, and the constraints the factory designers had to operate under.
I don't necessarily think "hmm someone smart than me made this, I should respect it"
I'm not opposed to RTFM, but I have met plenty of clever ideas that didn't make common sense.
Obviously you can't dump exhaust fumes and oil into the environment (constraint)
But you want to most effectively dissipate pressure (goal)
Now, the factory fellas had to take 6 cracks at this to get it right, that concerns me.
I know what I am proposing will vent the pressure COMPLETELY and keep oil out of the intake.
cndnate1 is offline
Old 10-06-2010, 01:23 PM   #12
Under normal operation the PCV valve allows crankcase air to be drawn into the intake manifold when you have vacuum in the manifold. Once you make boost pressure, the PCV valve closes and the only ventilation the crankcase gets is thru the small hose that was running to the turbo inlet. By eliminating the PCV valve you can get twice the crankcase ventilation while under boost.
cndnate1 is offline
Old 10-06-2010, 02:07 PM   #13
Wagon Shaggin'
Saabeh's Avatar
Without the PCV check valve you will be pressurizing the valve cover/crankcase.
Why modify a proven system on a sludge prone car? Tell your Honda instincts to get out of your head.
Saabeh is offline
Old 10-06-2010, 04:06 PM   #14
JK
JK's Avatar
I think you are operating under the assumption that there is excess crankcase pressure when you are under boost. I highly doubt this is the case, unless you have some issues with your rings.
JK is offline
Old 10-06-2010, 04:13 PM   #15
I'm operating on two ideas:
1. Under boost pcv is closed
2. under boost there is more blowby (in proportion to amt of boost)
cndnate1 is offline
Old 10-06-2010, 04:28 PM   #16
Raven18940's Avatar
WOOOOOOW. Step away from the PCV system, you have no idea what you're talking about.
2001 Saab 9-5 Aero
Old 10-06-2010, 04:30 PM   #17
Raven18940's Avatar
Do you see that big hose that attaches to the valve cover at the same place that the PCV hose does? Follow that and see where it goes.
2001 Saab 9-5 Aero
Old 10-06-2010, 05:07 PM   #18
JK
JK's Avatar
Yup, it goes to the intake. Under boost the intake literally sucks the crankcase fumes and pressure out. The crankcase is certainly not closed under boost
JK is offline
Old 10-06-2010, 05:20 PM   #19
Issues with rings such as low friction pistons? This is where the whole sludge and pvc problems originate.
The 9000 b234 which is nearly identical has a simple pcv system and has none of the same issues as the 9-5 does because it did not have these low friction pistons which actually do NOT seal as well as the b234 pistons (hence the low friction).
I am intrigued by this conversation, and I'm the first to admit I don't understand completely the pcv system on the 9-5. I put update 6 on mine, and still have oil leak that I have read is due to pcv issues.
I'll tell you one thing, I dont agree with "because somebody smarter than you..." when this pcv problem took 6 iterations to fix, and wasn't really fixed till 2003 model years.
Lets dicuss..... I've got alot to learn.
Tboy is offline
Old 10-06-2010, 05:38 PM   #20
DrewP's Avatar
The other function of the PCV system routed to the inlet is that it always (almost always) maintains the crankcase under vacuum, which helps the front and rear main crank seals ... well.... seal. If there is vacuum in the case, oil that would weep past the seals gets slurped back inside.
For those of you not paying attention, the acronym PCV means exactly that, if you vent it to atmostphere it's not PCV - it's what they had prior to the 1970's, when you just have a little breather filter.
Drew
DrewP is offline
Tags
"race" ??? lol!, pvc, race
