Koni Kit - The Saab Link Forums
Old 07-01-2010, 07:01 AM   #1
Koni Kit
Hi,
bought yellow koni sport kit for my 95.
http://www.partsforsaabs.com/product...oducts_id=1255
received it from PFS but this is what i found:
Same for rear dampers.
The springs looked used
after contacting PFS paul and alex told me that i would get a new one free or charge, i only had to ship everything back.
so 6 weeks later i received them....
The shocks and springs look fine, no damage.
But now im wondering if i am missing 1 metal ring. because i only have 3...
Also where can i find the manual how to install them. I have no clue where all those white plastic parts are going.....
I checked http://photo.platonoff.com/Auto/2007...nt_Suspension/
and its seems rather ok, but platonoff is not using any koni´s...
so if anybody can tell me where those 3 rings are going and all those white plastics i would be a happy person....
dajazzz is offline
Old 07-01-2010, 08:20 AM   #2
JK
JK's Avatar
Are you located in the UK?
always a SAAB guy at heart
JK is offline
Old 07-01-2010, 08:27 AM   #3
Finland...
started on the front and I just removed the passenger side damper and spring.
Do you know if i need to re-use the bump stops? Or if there is a difference between left and right side.
dajazzz is offline
Old 07-01-2010, 08:48 AM   #4
pete93t's Avatar
Send a message via AIM to pete93t Send a message via Yahoo to pete93t
the front swap is easy i can send you some pics of my install on my 9-5 i did the full koni kit with vogtland springs as well its much easyer than it looks. and on the bump stops i think it would all depend on condition i re-used mine but they only had 40k on them and looked like new so i guess it would be more of personal preference. good luck
and the white plastic peices slide down the strut
-05 9-5 aero (BOOST2)-
-1980 900 Holset t5 monster-
pete93t is offline
Old 07-01-2010, 09:11 AM   #5
Hi Pete,
Well it would be great if you could give me some pics where those plastics are going.
Can you see from the picture i attached those yellow bump stops? First i was thinking that they were packing matterial and almost placed them in the trashbin.. i see that the original bumpstops are longer and a lot softer,
But im still wondering hy is there no manual with this kit?
Br jasper
dajazzz is offline
Old 07-01-2010, 09:34 AM   #6
so it should be like this?
If these shocks are adjustable how can you do that?
isnt it so that you adjust them from the top?
dajazzz is offline
Old 07-01-2010, 01:06 PM   #7
Chadwick's Avatar
Shouldn't there be much more strut rod sticking out in that last photo? That looks way too short.
Chad Lowers
'00 9-5 Aero
Chadwick is offline
Old 07-01-2010, 05:18 PM   #8
jssaab's Avatar
THye Koni Yellows are not adjustable on the car on teh 9-5 you need to take em off to do that...
jssaab is offline
Old 07-01-2010, 09:49 PM   #9
OW! really?
how to adjust them then? because now they are not the same.
and where do those metal round plates go?
dajazzz is offline
Old 07-01-2010, 11:47 PM   #10
Hi dajazz,
Those metal plates look like they slip over the rear dampers and become the spring platform???? you would only need 2 as you have 1 per side
9000 Aero STG 6 + , 900 SET STG 3
lastaero is offline
Old 07-02-2010, 03:20 AM   #11
Originally Posted by lastaero View Post
Hi dajazz,
Great that would explain those yes!
Now i only want to know how to adjust those front and rear shocks. What is recommended as i have the koni sport kit that includes the springs. (-30...-40mm)
do i just need to turn the silver pipe that goes in the shock to left or right??
dajazzz is offline
Old 07-02-2010, 03:37 AM   #12
Raven18940's Avatar
To adjust the shocks you compress them fully and then turn the shaft while they're fully compressed.
2001 Saab 9-5 Aero
Raven18940 is offline
Old 07-02-2010, 03:38 AM   #13
aha,
so it did not matter that i have turned them while they were not fully compressed...
any recommendations or just leave them as they are?
dajazzz is offline
Old 07-02-2010, 08:46 AM   #14
Yes the Koni front strut setup sucks on the Saab 9-5...I recommend going more towards the stiff side on the ajustments...I went right in the middle and it is too soft in my opinion...but now I have to take them off to adjust the ride...it sucks
cking1975 is offline
Old 07-02-2010, 08:58 AM   #15
yip i can confirm....
its still very soft, i can push the car up and down...
so if i knew this 2hs ago i would be more happy, well something to do, but not today anymore :P
dajazzz is offline
