can I use an aero clutch with my lpt flywheel? - The Saab Link Forums
Old 05-03-2010, 04:41 PM   #1
Does anyone know?
For some reason, the SPEC 204mm clutches are a LOT less than the lpt clutches, but I wasn't sure if I could interchange clutches, or if I had to buy an aero flywheel when I do the upgrade.
Thanks, guys!
-Craig
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 05-03-2010, 04:45 PM   #2
I just looked on Eeuroparts.
The flywheel is the same from 99-09
Craig R.
g96nt is offline
Old 05-03-2010, 05:45 PM   #3
DeLorean's Avatar
yep, aero clutch will bolt right into a 99 LPT flywheel. It's the clutch you should use in that car, no doubt about it, especially if you have a tune.
DeLorean is offline
Old 05-07-2010, 09:25 AM   #4
Dudethe9-5isfast's Avatar
Yes it will work - might need to resurface the flywheel
There could be a wear ridge where the LPT flywheel ended causing a hot spot on the aero flywheel - easily taken out with a resurface
Dudethe9-5isfast is offline
