b234/235 hybrid what turbo should i use - The Saab Link Forums
Old 03-06-2010, 06:19 PM   #1
jssaab's Avatar
Well got all the parts and machine work done on my 234/235 hybrid (T7 head 234 lower end)
Got everythigng all balanced up and ready to go back togehter
Just need the glass beading on the exhaust side, so now the question is what turbo to use.
It wil be a daily driver so I want soem spool dowm low and torque there as well, so what are my options?
Let me know what turbo would work best for that application and if/how I can bolt it up ( would I need a spacer or new manifold) and how much I need to change the downpipe from the stock turbo to fit it up.
It would be nice to get 400 WHP
I currently have 50# injectors, and will be using T7
jssaab is offline
Old 03-06-2010, 06:23 PM   #2
saabkid37's Avatar
hx35
saabkid37 is offline
Old 03-07-2010, 04:21 AM   #3
mike9000aero's Avatar
Ditto
97 9000 cse stage x Holset hx35w 330whp 373lbft sold
09the VW GTI day stg 1
mike9000aero is offline
Old 03-07-2010, 06:10 AM   #4
jssaab's Avatar
Ok SO the HX 35 comes wi the T25 flange?, can i fit it in a 9-5 straight bolt up to the cobra, downpipe ( at least to the dp flange, we can weld and cut it to fit) will it squeeze in there with the fan/radiator in the stock locations, will I need to space it from the head???
Sorry for al the q's but I need to get an idea before I grab one and get into it. Just want to know what to look out for. I have not seen any 9-5s with the HX35
jssaab is offline
Old 03-07-2010, 06:50 AM   #5
No its a t 3 flange u will need custom header AFAIK and most. Likely will need a differant fan,modify dp and custom intake
Old 03-07-2010, 06:51 AM   #6
saabkid37's Avatar
it bolts up to the manifold normal.
you need to redo the entire intake and the dp flange tho.
Old 03-07-2010, 06:52 AM   #7
You should get td04 19t its bolt on and will give you 300 plus whp
Old 03-07-2010, 08:56 AM   #8
Wagon Shaggin'
Saabeh's Avatar
Well, a 19t on a regular b234 made 410whp and 388wtrq with JZW. I imagine that a T7 headed car with a 19t and a good tune would be interesting.
Saabeh is offline
Old 03-07-2010, 09:15 AM   #9
saabkid37's Avatar
that is extremely hard to believe, as that turbo cant flow that much.
an 18t is a 300-310whp turbo, a 19t is not 100whp more.
Old 03-07-2010, 09:27 AM   #10
Wagon Shaggin'
Saabeh's Avatar
http://www.youtube.com/watch?v=tl5WmFOwAoY
-edit- Nevermind, he was doing his mile high trickery.
Saabeh is offline
Old 03-07-2010, 09:51 AM   #11
saabkid37's Avatar
yeah i didnt want to come right out and say it...but i figured the numbers would be wacky.
not that the 19t is a bad turbo, but it runs HOT egt wise, and unless it was a 6cm i would not run it.
i also think the hx35 would almost spool faster and be an easy 400whp turbo.
Old 03-07-2010, 10:44 AM   #12
Holset not bolt on and I doubt that it would spool as fast. as a 19t I have hx35 on my car and while I don't have experiance with 19t I am betting it will spool 1k sooner then hx
Old 03-07-2010, 11:53 AM   #13
saabkid37's Avatar
youd be suprised how late the 18t and 19t spool
Old 03-07-2010, 11:59 AM   #14
Legit's Avatar
Why not a GT28RS?
2002 Viggen Convertible
Legit is offline
Old 03-07-2010, 12:05 PM   #15
DanF.'s Avatar
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 03-07-2010, 12:07 PM   #16
saabkid37's Avatar
Originally Posted by DanF. View Post
there are plenty of better turbos that are cheaper. a 28rs truly only flows a tad more than an 18t
Old 03-07-2010, 12:08 PM   #17
I was just looking at Dallas dump on johns site, max tourqe at 3000 rpm hx is not at 20 psi till 3800, I can't imagine a 19t with a clip would spool slower then hx35 but could be wrong
Old 03-07-2010, 12:57 PM   #18
saabkid37's Avatar
i never dynod my 18t but ill see if i can dig up some videos.
it definitely didnt spool till 3-3200
Old 03-07-2010, 01:04 PM   #19
NahumCC's Avatar
Well I guess I'll be able to let you all know once I have the time to get mine together.
19t without the clip on the turbine and a Spec flywheel should be fun. Just a few other tid bits to piece together.
2013 FR-S
NahumCC is offline
Old 03-07-2010, 02:34 PM   #20
jssaab's Avatar
I currently have a T25 6cfm with T28 on both sides now on the 2.3 t7 seemed to flow a littel less that you would need for 300 it hit 290+ whp at 330 wtq
Originally Posted by LeGiT SaaB View Post
Why not a GT28RS?
Nick has said go fro the GT3071 rs instead that there was really no difference
Money is not a major object, ease of use tune and max out of the engine is my major issue.
Got spool at 2500 with the Big T28 works fine but I wnat near 400 WHP if I can.
Loosk like a meed a header or spacer liek Nick T uses. I can get a narrow fan its just headers are a pain...
Thanks for the info
Sounds like Nahum may have some info if he gets around to the HX that will help, but I should be ready to get the turbo on soon...
jssaab is offline
