Pop goes the motor - The Saab Link Forums
Old 01-21-2010, 03:17 PM   #1
Saab99Super's Avatar
Pop goes the motor
The head on the 9-5 is junk now. So now is the time to replace the weaker parts with better parts.
Basically no warning what so ever. Was idling at a stop sign after driving through town for quite a ways and I heard a small pop then the motor dies. So at first I was like WTF that's weird cranked the motor over and yep definately 2 dead cylinders.
So Dave () helped me push the car off to the side of the road to try to figure out what the hell happened. I crank it over again this time another pop and a ton ton of ticking. Look under the hood and sure enough I have a nice hole in my valve cover and I'm staring at the exhaust cam gear in the hole.
So tow it back to the shop, I take off to finish my trip to the Meyer store in another car and Rob () sends me this picture after he took the valve cover off.
Great. The cam gear decided to destroy it's self hence after taking the head off bent all 16 valves.
So to remedy this problem the computer went to Nick to get re-burned from stg. 2 to stg. 3, scavenged a new set of valves out of an old blown up 205R motor, rounded up a pair of T5 cams, ordered a set of GS upgraded valve springs and ARP head studs, and ordered a whole timing/balance gear rebuild set.
This should take care of the head next will be the bottom end once I melt down a piston.
1979 99 GL "99 Super"
1999 S10 ZR2
1991 Mazda Miata
78' Turbo
Saab99Super is offline
Old 01-21-2010, 03:19 PM   #2
Deez Nutz
Palmer's Avatar
Stereo.
I'll keep this one open, because it's your car.
Higher RPMS? Doing any porting?
S55/LC100/KL
Palmer is offline
Old 01-21-2010, 03:22 PM   #3
User
zingZACH's Avatar
That's the first time I've seen that happen to the cam gear! Nice work!
1988 900 Springtime in Sweden
zingZACH is offline
Old 01-21-2010, 03:22 PM   #4
Well higher rpms is some what in mind.
I look at the springs as a cheap insurance policy in case I miss a shift.
Porting wise I'm going to leave it alone for now. I figure when it comes time for the bottom end I'll do that.
1999 S10 ZR2
1991 Mazda Miata
78' Turbo
Old 01-21-2010, 03:24 PM   #5
Deez Nutz
Palmer's Avatar
Those cams are going to be fun.
S55/LC100/KL
Palmer is offline
Old 01-21-2010, 03:25 PM   #6
Nick Taliaferro
GenuineSaab's Avatar
Had that here to finish up for you..
No need for studs or different valve springs(t5 only, the valves not cams) on that setup.
I had an -85 16v do that but chocked it up to first year. That is pretty wild.
Nicholas Taliaferro
GenuineSaab is offline
Old 01-21-2010, 03:36 PM   #7
stromer's Avatar
Did the valves hit the pistons?
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 01-21-2010, 03:36 PM   #8
User
zingZACH's Avatar
Assuming so since he bent all 16 .
zingZACH is offline
Old 01-21-2010, 03:38 PM   #9
stromer's Avatar
Sorry, I meant damage as in score or otherwise.
stromer is offline
Old 01-21-2010, 03:51 PM   #10
WyldSaabMan's Avatar
x2 Damn!!
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 01-21-2010, 04:20 PM   #11
Harvey's Autohaus's Avatar
Thats Funny, Sorry, Is it a 2000? 95, I Did an Emergency recall For saab in 2000 where Saab Called back a Select few 2000's for an Emergency Cam Sprocket recall. The Sprockets were Supposed to have been replaced at the port of entry but a few slipped through.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 01-21-2010, 04:21 PM   #12
User
zingZACH's Avatar
Also like the Saab Airplane tattoo on your wrist...
zingZACH is offline
Old 01-21-2010, 04:58 PM   #13
I've heard of that happen to one person with the V6 motor. Sucks though.
On a related note, Tuesday night I pulled the head off of a friends Neon because her timing belt wore out. Ruined all the valves, but the pistons look OK. $350 in partslabor from the machine shop.
I'd rather a freak failure than have a failure due to neglect.
Tboy is offline
Old 01-21-2010, 05:33 PM   #14
The tattoo is on Robs arm. I have an idea similar to that but I haven't gone through with it yet.
The pistons were fine just the slightest dings from the valves. Nothing a little green scotch bright pad action couldn't handle.
1999 S10 ZR2
1991 Mazda Miata
78' Turbo
Old 01-21-2010, 09:11 PM   #15
mike d's Avatar
holy hell, that my friend is a rare failure.
cam sprokets are one of those parts which typically excede the life of other major parts of these cars,,
MikeDTuning.com
mike d is offline
Old 01-22-2010, 06:46 AM   #16
Green9kAERO's Avatar
Not really, sometimes the bolts break when you torque them to spec.. ohh and sometimes people dont tighten them enough so the keyway strips and puts the cam out of timing...
so yea, torque camsprockets to 63nm!
Green9kAERO is offline
Old 01-22-2010, 07:21 AM   #17
What happend to the pic? Nevermind I see it.
