14 Point 7 Sparten - The Saab Link Forums
Old 05-03-2017, 01:37 PM   #1
mike d's Avatar
14 Point 7 Sparten
For awhile on Megasquirt cars, i have been using the 14point7 sparten 2 wideband (see link below) and have noticed that is has a narrowband output as well.
https://www.amazon.com/14Point7-Spar...int7+spartan+2
Today i figured i should try to wire it up, and see if the narrowband output works with saabs, Gunnie pig was my 2002 95 aero,, As of now, its working great with T7 ecu. No needed calibration via tuning, or out of the ordinary install work besides splicing 4 wires!
Below is how to wire it in, You can find all needed connection at the front (black) lambda 4 wire plug
pin 1 to red
pin 2 to white
pin 3 to black
pin 4 to brown
Wonder how MPGs will be effected. Will report back after more testing
MikeDTuning.com
mike d is offline
Old 05-03-2017, 01:55 PM   #2
Nice. I have been eyeing the spartan for some time. So if t7 is using the wife and for running the car, what do you think the narrow band will do? Get rid of a cel?
Tboy is offline
Old 05-03-2017, 01:58 PM   #3
mike d's Avatar
i am using the Sparten as a replacement for the front lambda. Not sure what you mean about the narrowband?
MikeDTuning.com
mike d is offline
Old 05-03-2017, 02:06 PM   #4
Oh. I might have mis read. I thought you had your Ecu changed to utilize a wideband, and had additionally hooked up the narrowband output.
So in this case, you have the wideband portion running a gauge, and the narrow band feeding info to the ecu?
Tboy is offline
Old 05-03-2017, 05:52 PM   #5
mike d's Avatar
i have the same sensor running both a guage, and the ecu,
So yes, the narrowband output running the ecu, while the wide-band runs the guage
Even though its a narrow-band output, the response time, and accuracy are still much better going to the ECU. Maybe i'm swallowing a sugar pill, but i swear the car idles better now.
MikeDTuning.com
mike d is offline
Old 05-04-2017, 05:11 AM   #6
So is this car not tuned? Is there a reason you didn't tune the ECU to use the output of the wideband directly?
Tboy is offline
Old 05-04-2017, 07:37 AM   #7
Aren't there others that do this, too?
I sort of thought that AEM UEGO did the same. although that may have been through the gauge, which shrinks the output.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 05-04-2017, 03:42 PM   #8
jk88's Avatar
But how do the tortilla chips affect EGTs?
jk88 is offline
Old 05-06-2017, 05:30 AM   #9
mike d's Avatar
Oh tuning thread, How i spite thee.
Joking aside, i was looking for more of a "plug in" solution. and i just got a CEL from it today, back to the drawing board
MikeDTuning.com
mike d is offline
Old 05-06-2017, 08:43 AM   #10
Drew In Houston
What code(s) are you getting?
Edit:I bet it's either a latency or impedance issue or both. Both acceptable ranges can probably be calibrated-for. I may get one of these to try too, I just started adjusting my stock 03 9-5 Aero for improving drivability and response w/a light weight flywheel. It's surprising how much timing it tries to run everywhere bone stock
Trionic3000 is offline
