I bought a Miata - The Saab Link Forums
Go Back   The Saab Link Forums > Showoff Forum > Other Pictures
Other Pictures Have something you just want everyone else to see? It can be you, your dog, family, a cute girl next door, your other car...anything!!
Old 07-11-2014, 10:41 AM   #1
gm
gm's Avatar
I bought a Miata
So weird car shopping and not being able to look at new-r saab's
Sending out the loan paperwork today for a new to me Miata. 2013 Club in Silver is what I finally went with, it has just over 13K miles
My hope is to make it a more reliable (compared to my old SPG) track car & also daily driver 9 or so months out of the year
Thus.... Yes a bunch of go-fast stuff is already being added to the car
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 07-11-2014, 10:47 AM   #2
Nice, good luck with it!
Jameson is offline
Old 07-11-2014, 11:01 AM   #3
Powar's Avatar
Send a message via AIM to Powar
Excellent choice.
Powar is offline
Old 07-11-2014, 11:09 AM   #4
Turbo00's Avatar
Nice! The club has the lsd, correct? Big improvement w/that alone. Expecting a build thread!
Turbo00 is offline
Old 07-11-2014, 02:39 PM   #5
gm
gm's Avatar
Yes it has a LSD! LSD, soft top 6 spd and any color except black was what I was looking for.
Pics will come when available, should be approx 400hp with similar (I would think) torque when it's done. Hopefully have car first or second week of August.
I am doing this opposite of mods in the past. I always added hp last and worked on the chassis first but this time its getting hp mods first, then in a year or so some new coilovers and wheels.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 07-12-2014, 07:17 AM   #6
stig's Avatar
Nice! Excellent choice
'96 Miata - Simplify and add lightness
'96 9000 Aero - Complicate and add torque steer
stig is offline
Old 09-02-2014, 08:00 PM   #7
gm
gm's Avatar
Little update on my miata
Turbo kit is running behind schedule. I ordered a turbo kit which was suppose to take 4 weeks..... Been almost 8 weeks and it still hasn't arrived.
Found a used set of coil-overs for the car. They are double adjustable fat cat motorsports coil-overs and the previous owner also included a rx8 yellow front sway bar. The mount for the external oil reservoir was broken on the front two coil-overs so I had those sent to the manufacturer for repair. Fat cat stated 2 weeks to repair. I was suggested to disconnect completely the rear sway bar with these coilovers which were setup for str solo II. Hopefully they will be comfy enough for street use as well as so,e track days. Fat cat can revalve the suspension and set them up for my weight and all that stuff.
New motor is also ready to go.... Just waiting on the turbo
If I can't swing it this year.... Next spring at the latest new wheels and tires. At this time leaning towards 17x9 with 245-40-17's, possibly pilot super sports.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 09-03-2014, 07:34 AM   #8
Wagon Shaggin'
Saabeh's Avatar
Holy cow!
Saabeh is offline
Old 09-03-2014, 11:33 AM   #9
srp
srp's Avatar
Send a message via AIM to srp
Wait, new engine for a basically new car?
srp is offline
Old 09-03-2014, 07:08 PM   #10
gm
gm's Avatar
Yes.... Selling the stock motor which has 13,??? Miles and putting a 2.5L in the car which has been slightly built up to allow It to take boost. Stock 2.0 can't take the power I want reliably and I also worry about lag since I had the same turbo on my old SPG.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 09-05-2014, 07:41 AM   #11
mike d's Avatar
congrats on the miata, they are pretty awesome
Also, you will be happy to know your old SPG is doing very well, and has been pretty reliable since T5 was installed. a big portion of the lag n your old SPG was due to autronic not knowing how to spool a turbo. the cars current setup on a holset hy35 is now making very good boost below 2800 rpms
Im surprised you didnt look into GM LS swaps for it? they make 400hp, and can be treated like a punching bag Cost of conversion probably isnt much different than built miata motor
Think about it...........
Pictures??
MikeDTuning.com
mike d is offline
Old 09-05-2014, 10:52 AM   #12
gm
gm's Avatar
Brian & I still keep in touch a bit on my old car. Saw the video he posted on facebook today I think.... I do miss that car except for the transmissions
Thats interesting on Autronic not knowing what to do with the turbo. If I recall it was at 10PSI at 2K rpm's & 22-26 PSI at 3700 or so. How much better is the holset + T5?
I thought about the LS swap however it would be over $20K if I did it myself for what I would want plus I do not have the time or equiptment to do everything myself. Flyin Miata charges approx $43K for a turn kep LS swap which would be I believe the 430HP crate motor.
Junkyards have the 2.5's for $800-150 and can be swapped with a tune and exhaust and make just over 200 whp/wtq w/o boost. I am adding boost thus pistons/rods/cams add another -$2k.... shop I am using charges approx $5K for the built motor installed, tuned etc & is installing the turbo for nothing since its his first turbo 2.5 conversion. He has done a few supercharged 2.5's.
Hopefully have pics in a week or two
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 09-05-2014, 11:00 AM   #13
Cark's Avatar
Gary this looks awesome!
And BTW, thoughts on the new Miata? Looks pretty badass IMO.
08 9-5 Aero S/C
85 900 turbo - T5
Cark is offline
Old 09-06-2014, 02:55 PM   #14
mike d's Avatar
Flying miata charges a lot for everything, im sure a built miata motor from them would be big bucks as well!
likewise a boneyard LS with trans goes for around 6k, is just a matter of what you want t do with it in car
either way keep us posted!
the holset + t5 is well into any pressure you want it by 3300 rpms, Remember this is coming from a larger, journal bearing turbo, making a lot more power!
MikeDTuning.com
mike d is offline
Old 09-08-2014, 07:53 AM   #15
gm
gm's Avatar
Flyin miata just uses crate motors from gm thus usually not a need for the motors to be built up beyond that. Plus getting the crate motor they come with I believe a 2 year unlimited mile warranty. Flyin is working on a Exocet with the cts v motor.... If I recall that motor is approx $25,000 from gm!
Someone of I know has one of if not the nicest na monster v8's I have seen. Its a few years old thus uses the old 5.0 mustang motor. He had a new motor built for the car which I think it a 347 or something like that. Fun car and great fun on the track but man does it get hot in there. He saw a monster miata a few weeks ago when at a track weekend and told me it made his car look like a kit car! He was extremely impressed with the flyin miata swap but yea.... Lots of money
I didn't want to deal with the heat, added weight and the additional work of the v8.
In regards to thoughts. I was considering a mazdaspeed nb or the nc and the wife and kids didn't like the looks of the inside or outside of the nb, thus my decision was made for me. In stock from on my test drives I felt its a bit soft for me. To much leaning and wiggling.... but I hope after my fat cat suspension is installed that I will enjoy it more.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
