Viggen Transmission - The Saab Link Forums
Old 06-19-2006, 12:48 PM   #1
90SPG's Avatar
Send a message via AIM to 90SPG
Viggen Transmission
This is a question for my friends 99 viggen, he just lost 2nd gear unless hes at a completely dead stop, at any real speeds he cant shift from 1st to 2nd or downshift from 3rd. He took it into the shop today and they quoted him about $1600 to put in a used one. I told him about Eriksson to rebuild his tranny but this is his daily driver so he cant have it laying around for a while, which is why he also cant change it himself unless I really convince him we could. Anyway, my questions are; does $1600 sound about right for all of this, and can he be sure that his tranny is totally busted? The shop he took it is near me and theyve tried to screw me over on several occasions with what seemed to be unreasonable items which needed to be fixed so I dont trust their opinion 100 percent, but they do good work. They quoted him $900 alone for a transmission which according to them came out of a 99 (assuming its a viggen) with 33k miles on it. They said it would be more expensive to rebuild his current tranny even though most of the labor is going to be in removal/installation. Basically what it comes down to is I have a feeling the shop is being a little inflated here, so what are his other options to get another tranny in there. And am I right in assuming that most 9-3 transmissions are the same, nothing special for the viggen?
'90 900 SPG (RIP rust)
'86 900 SPG (DD)
'86 900S
"A car with an image so immaculate it can hold confession and communion."
90SPG is offline
Old 06-19-2006, 01:01 PM   #2
I would make sure its another 99 Vig tranny. What are the miles and condition of this other tranny? if its another 80-100K plus tranny, it might need work too soon down the road and you will be back at square one. 1600 for trans and install is fine, as long as the trans is legit and less then 80k miles.
Jameson is offline
Old 06-19-2006, 01:42 PM   #3
WyldSaabMan's Avatar
umm, why not try the simple things first? You say he can get into it at a dead stop...is it possible the shift linkage is misaligned? Hows the tranny fluid in the trans?
also 1600 sounds a bit steep. I can swap a tranny in a garage with just a jack and and jack stands in about 4-5 hours. With a lift in a shop it should take even less time.
so even if this place is charging 100 bucks an hour, I dont see why labor should be over 500. A used tranny from the right place can be had for as little as 300.
You should really just do it yourselves.
Order a trans, wait for it to come and then put the car up for a day while you do a swap.
You probably also want to change the clutch and slave cylinder while you are in there.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 06-19-2006, 02:00 PM   #4
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
thats what happened to my transmission after i swapped my new one in.
problem #1 is that the shop accidently gave me a drilled out shifter linkage and the pin was not held tight.
#2 was the rubber bushing on the linkage was cracked and allowing tiny adjustments.
Even the smallest movement of a linkage can make it so a gear cannot be selected. My issue was that i couldnt put it into 1st if my wheels were rolling at all. Also couldnt downshift from 4th to 3rd.
Im not sure how a 9-3's linkage goes together but if its not the transmission itself i would really inspect that.
If 2nd gear is there when stopped then it doesnt sound like the tranny. I could be wrong though. Have you tried to go from a stop in second gear and see if its funcioning properly?
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 06-19-2006, 02:17 PM   #5
90SPG's Avatar
well thanks for the insight guys. i cant really speak about how it drove before 2nd didnt work, but it does sound strange to me too that it stopped working all of a sudden. he brought it into the shop and i can only assume they checked for simple things like the linkage. im gonna suggest to him changing out the fluid too, even if the 2nd syncho is a little old i think the fluid might be a cheap fix for a while. if it were me i would definitely want to save on labor and do this DIY but if hes got the money for it, then more power to him, though id love to help him fix this for cheap.
the tranny they want to put in is out of a 99 something with 33k, can any 9-3 trans be used? when i priced some transmissions for my car i saw them well under $500 so im sure we can find a better price especially because of the people selling this to him, they tried to sell me an exhaust manifold for $500, i promptly told them to go to hell. anyway, now my question is does the viggen have any specialties besides the driveshafts(i believe) or can we just look for any low mileage trans?
thanks for your help, i'll be sure to pass all of this along to him.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 06-19-2006, 02:19 PM   #6
No, the Viggen trans is specific to the Vig. Aero trans wont bolt up and 9-3's have different gearing etc. IF its a 99 Vig trans with 33k, thats pretty rare.
Jameson is offline
Old 06-19-2006, 02:23 PM   #7
90SPG's Avatar
really? my other friends 2001 SE has identical revs as my dads 2001 viggen, i know they could have internal differences but they drive the same and seem to have the same revs, what else could be different.
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 06-19-2006, 02:31 PM   #8
The gearing is diff.....2nd goes to 60 or 62 at redline in the Vig. I am 99% sure 9-3's and Viggs differ, someone else can confirm.
Jameson is offline
Old 06-19-2006, 03:41 PM   #9
i can get 60ish out of my normal 9-3 in 2nd...keep in mind tire size plays a bit of difference as well
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
Old 06-19-2006, 04:46 PM   #10
Deez Nutz
Palmer's Avatar
So does mine, and I'm running the 15" wheels.
S55/LC100/KL
Palmer is offline
Old 06-19-2006, 04:56 PM   #11
90SPG's Avatar
yeah the gearing in the SE seemed identical to the viggen to me. the friend with the SE also has a 99 9-3 which has shorter gears than the '01 SE. not knowing any technical differences and only judging by the revs on the highway it would seem like they are the same between the SE and the viggen. would most 9-3 transmissions bolt up?
'86 900 SPG (DD)
'86 900S
90SPG is offline
Old 06-19-2006, 05:41 PM   #12
JK
JK's Avatar
ALL 9-3 transmissions will bolt up, the gearing may or may not differ, but they will certainly all bolt up and be drivable.
always a SAAB guy at heart
JK is offline
Old 06-19-2006, 06:59 PM   #13
Send a message via AIM to Viggensegg Send a message via MSN to Viggensegg
I'm fairly confident that all 1999 9-3s with manuals had the exact same tranny, including the Viggen. I know this both from driving both (mom's 9-3, my Viggen), and all the published material from Saab puts them both with:
First...........3.38:1
Second.......1.76:1
Third..........1.18:1
Fourth........0.89:1
Fifth...........0.66:1
Final Drive...4.05:1
Viggensegg is offline
Old 06-20-2006, 02:04 PM   #14
I reread my press release and they refer to the Vig as having a upgraded clutch and axels, making it sound as the tranny itself is unchanged....oops sorry about that.
Jameson is offline
