Slight leak from automatic transmission case - The Saab Link Forums
Old 09-09-2014, 09:17 AM   #1
So I recently changed my auto trans a few months ago, and while changing it I changed the filter inside it. So in doing that it ment I had to take the trans in half. So I did and cleaned off the old rtv sealant really well. I then used anaerobic sealer to seal it. Let it sit together for a few days before being put on the car and filled up. Also filled it up with dex VI instead of orginal dexIII.
Fast forward to a few weeks ago I noticed I had started loosing coolant and burning it off. Later diagnosed it with a bad headgasket. So I decided to park my car in my garage for the last few weeks while I aquire all my part. The other day I noticed a very small wet spot on the ground right above the trans. So wiped the bottom of the trans with a paper towel and sure enough it was trans fluid.
Now before I noticed any fluid from the trans i was always checking under my car where ever I went for and puddles, never had any other than from a leaky coolant line on the turbo.(which is also getting fixed w the hg job).
So now my question is what caused this leak?
Not a good job on the sealant?
Could it have anything to do with sitting for a few weeks?
Could it be that the synthetic dexVI is to thin?
Now how to fix it? Any other ideas other than taking the trans off and redoing it?
Any safe to use trans stop leak?
Maybe try re tightening the bolts on the trans?
Maybe switch back the fluid?
Or can you doing something ghetto and re apply sleant on the out side? Or is that a dumb idea?
Looking for any input!
Thank you Connor
condaddy is offline
Old 09-09-2014, 09:22 AM   #2
B202nut-2.0's Avatar
try resealing the tranny properly. if it wasn't leaking before and now leaking after you troubled it, seems like it didn't seal well...
I like RTV over anaerobic.... what is recommended by your manual?
B202nut-2.0 is offline
Old 09-09-2014, 11:03 AM   #3
I don't if it leaked before I had it, and I also don't know what the manual calls for. I would like to avoid dropping the trans if possible. It didn't leak until it sat for a few weeks
condaddy is offline
Old 09-09-2014, 11:33 AM   #4
USUALLY:
Most mechanics would suggest against any additives to fix a leak....
From my knowledge, additives that are suppose to stop leaks do so by softening/swelling old gaskets.
According to your post, you used anaerobic stuff, so if you put in an additive, I am not sure its gunna help you.
I know its not what you wanna hear but it may require you to try again...
but maybe others will have another out for you.
Old 09-09-2014, 01:34 PM   #5
Lol you are probably right, I just don't want to take it out again and what if it happens again lol. Hopefully someone will say something that's worked for them but prob not. O well we shall see
condaddy is offline
Old 09-09-2014, 03:23 PM   #6
soccerrplyr's Avatar
Here's the half-assed approach answer. If you don't have the time/patience to redo the drop, just live with the small leak and top off the auto-fluid every now and then until you feel like it or until you run the car into the ground. The weather is turning colder so you'll have a decision to make soon.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 09-09-2014, 06:38 PM   #7
Lol well I will be keeping my eyes on the fluid level forsure. I suppose it will come back out in the winter and do it in my garage. I just don't understand why it didn't leak at all till it sat for a few weeks..
condaddy is offline
