who can diagnose this symptom? - The Saab Link Forums
Old 07-05-2014, 07:40 AM   #1
Car starts only after cranking 10 or 15 sec. and does so grudgingly.as in not getting enough fuel. Once it starts it will idle fine but will stall if you touch the throttle what so ever. It is a problem that would appear and disappear without warning and all at once. Either 100% or not at all. The last time it did this while I was driving on the highway- lost all power all at once- as if some one flicked a switch. Once I came to a stop showed same symptoms described above. Was actually able to get off the highway with the engine idling and in first gear. Had this problem before and after changing fuel pump. Now car won't start at all, I think I might have burnt out my fuel pump driving it like that to get it off the highway? I think this is now a 2 layered problem if you know what I mean.
edwardc053 is offline
Old 07-05-2014, 08:22 AM   #2
Also noticed the positive on the old fuel pump was cooked when I removed it, plastic melted etc.
Old 07-05-2014, 12:57 PM   #3
Drew in Houston's Avatar
If it were me, I'd put a fuel pressure gauge on the fuel rail and see what it's reading and confirm the new pump as good. And if that's good, then next I'd suspect a failing/failed crank position sensor.
Drew in Houston is offline
Old 07-05-2014, 02:05 PM   #4
installed new CPS, tested pump-it's good, power getting to relay, tested relay-it's good, no power to fuel pump.
Old 07-05-2014, 03:55 PM   #5
Needs more info. Year/model/mileage/CEL?
seriks1 is offline
Old 07-05-2014, 07:40 PM   #6
srp
srp's Avatar
Send a message via AIM to srp
When my evap purge valve crapped out I had similar symptoms after filling my gas tank.
srp is offline
Old 07-06-2014, 10:12 AM   #7
1999 9-3 2.0 turbo
225,000 miles not original motor in it. That's all the info I have on it bought it 4 years ago was up on blocks for the last three. Just got it going again last winter. When I initially broke down it would start as I described, Now no power to fuel pump. Two different problems? Related? When I changed cps plugged in both ends. Did I miss something? How do I trouble shoot between CPS and Fuse? It goes ignition-relay-cps-fuse-pump, right? I'll look into the purge valve thing, that's for the stalling thing obviously. Thanks
Tags
bad cps?
