Brake Lights and Reverse Lights - The Saab Link Forums
Old 05-08-2006, 03:05 PM   #1
dasaabguy's Avatar
Anyone know what the problem may be or has anyone had this problem?
My brake lights seem to only work when they want to these days.
I checked my #12 fuse (stop lights) and i checked the #31 fuse (reverse lights) and both are not burned.
I took the panel off my trunk the other day and removed the light panels with the bulbs in it, all bulbs are fine. I thought i had narrowed the problem to what seemed to be the drivers side tailight wire harness. When i removed the bulb plate for the tailight and had someone press the brake...the brake lights worked with the bulb panel just hanging there in the trunk (including the middle brake light in the trunk! I then reinstalled the bulb panel and tried the brakes again and got nothing! Very frustrating!
i tried this like 10 times! and about 5 of the 10 times i got the same result!
nonetheless i gave up last night tinkering with it cuz it was dark and late!
this morning i get in and touch the brake and its on! Then i tap it again and it doesnt work! What the heck...................
dasaabguy is offline
Old 05-08-2006, 03:22 PM   #2
guru's Avatar
Check the switch? But I don't know if that'd make your reverse lights go wonky.
guru is offline
Old 05-08-2006, 03:34 PM   #3
dasaabguy's Avatar
which switch are you referring to?
is there a brake light switch that the pedal arm hits when the brake is being applied or something?
Old 05-08-2006, 03:41 PM   #4
guru's Avatar
Yes... I haven't had to look for it on an newer Saab yet, but it's usually somewhere along the pedal arm's line of travel. I always managed to smoosh mine stuck on after I bled the brakes in the old 900's. There's also a switch somewhere that activates your reverse lights. Maybe they've been going weird all this time and you just didn't notice until now?
guru is offline
Old 05-08-2006, 04:48 PM   #5
VincentD's Avatar
This problem happens on the NG900's too...
http://townsendimports.com/Web/elect...round4door.htm
VincentD is offline
Old 05-08-2006, 05:14 PM   #6
JK
JK's Avatar
I agree with VincentD - It is certainly a grounding problem, as SAAB decided to run the ground wire all the way through the wire harness to the front of the car rather than grounding it in back. Essentially just make a "redundant" ground to the lights in back and ground it directly to some bare metal in the trunk area.
always a SAAB guy at heart
JK is offline
Old 05-08-2006, 07:00 PM   #7
kalvinr11's Avatar
It definitely does sound like a grounding issue or some corrosion inhibiting grounds. A friend of mine had a Jetta VR-6 and when he hit the brakes the turn signals stopped. The connectors to the tail lights were all corroded. Cleaned it off and it worked like new. Check all your grounds, clean them and tighten them back down and see if it helps.
-Mike
'99 Viggen with 205k
Status: Mostly OK and studded winter tires
kalvinr11 is offline
Old 05-09-2006, 08:23 AM   #8
dasaabguy's Avatar
does anyone know where saab decided to run the ground to the brake lights on the ng900?
i will crawl under the dash again tonight to see if i can follow the wire's from the switch to the ground!
I guess it would have to be some sort of grounding issue or short, this would explain why it works every now and then.
THis morning i jumped in and tapped the brake and it worked, then when i tapped it again it didnt work! It always seems to work that first time when i jump into the car the next morning! Hmmmm will temperature affect the ground?
Old 05-09-2006, 08:27 AM   #9
stevehayes01's Avatar
I dont think temp will affect the ground but a my guess is that the ground is pedal related on the harnes and when you start pushing it the ground breaks. Why not find the ground wire in the rear of the car and run a temporary wire to ground in the trunk and see if the lights work all the time. If they do then hard wire the ground in and go from there.
Hey what happened to the Mitchell CD i gave you for the NG's..... that has wiring diagrams in it.
stevehayes01 is offline
Old 05-10-2006, 07:52 PM   #10
dasaabguy's Avatar
oh schnapps i forgot about those mitchells....i guess i should use them huh! ha
