Replacing the Valves in a B235R Head - The Saab Link Forums
Old 04-01-2014, 04:13 PM   #1
Posted this at saabcentral, but thought I would bring it here as well.
I work at a vocational school that has an automotive program and the automotive instructor has been helping me with my engine rebuild for my Viggen. Recently, we had the motor sent to a machine shop. He has a history with this shop so I don't feel like I am being ripped off. However, I am also far from an expert in machine work and have never had machine work done before.
The motor was previously built (by JZW, previous owner) and I am having it inspected and rebuilt. The machinist is recommending that all intake and exhaust valves be replaced; two exhaust valves were bent, and he believed they were too thin for him to cut. The rebuild did not have many miles on it, maybe at the most, between 5,000 and 10,000, but was burning oil for the previously owner before I bought it. Is this reasonable to believe that all valves need to be replaced this quickly?
Also, if I do replace all of the valves, do I need to look for a specific intake and exhaust valve? Because I have seen numerous ones listed at different prices for the Viggen and for the 9-5, both B235R. Is there a specific manufacturer I should be looking for? The cheapest I found were:
http://www.autopartsnetwork.com/saab...IakBm-Ouj0NhAE
and
Saab Engine Intake Valve W0133-1842225 - AE at Auto Parts Network
Do these prices seem to good to be true? I know eeuroparts, under Viggen valves, lists the intake at about $20 each the exhaust at over $100. Meanwhile, under the 9-5, the exhaust valves are listed at about $19. Any advice on where to get these valves?
He did mic the block and pistons and said everything looked great there.
Also, RockAuto sells exhaust valves under the Viggen subcategory:
AE Part #V94364: Valve stem diameter [mm]: 5.000; Valve Head Diameter [mm]: 29.000; Valve Seat Angle []: 45; Chrome-nickel-magnesium-steel; Surface: Nitrified; Stellite covered valve seat; Length [mm]: 108.000
Engine code [B235R]
Are these considered the nimonic valves?
Any help or advice is greatly appreciated!
rl0089 is offline
Old 04-01-2014, 05:52 PM   #2
oliversexpedition's Avatar
Here is a listing from eEuroparts, one of the site sponsors, 9179219 Genuine SAAB - Exhaust Valve - Free Shipping. If you order enough there is a discount code and free/reduced shipping.
Someone was selling a done 235 head for ~$400, get that your in votech, but might be cheaper to find good used valves or a head that is done.
Congrats on going down the path!
99 9-5 Wagon
01 9-5 Sedan
99 9-5 Wagon parting out
94 C900 Vert - Sold
94 325i Vert
oliversexpedition is offline
Old 04-01-2014, 06:41 PM   #3
DrewP's Avatar
The expensive valves are nickel alloy (trademarked name is Nimonic).
The cheaper valves are sodium cooled stainless steel of some kind.
If the car runs lean enough it will still melt the Nimonic valves tho.
I almost never replace all the valves when I do builds - the factory stuff is plenty strong. However, if your T7 head has lots of miles and you plan on tuning it then it'd be a good idea to do the exhaust valves. Having a good fit between the valve seat and valve sealing face is how the valve transfers heat from the valve back into the head (some heat transfer happens in the bronze guides too, but the end of the valve is the hottest, especially at the sealing face). If they don't have a good contact area the valve can't shed enough head and will start to melt. Once that happens combustion pressure just blows out the soft melty portion and your compression goes away.
The only thing that will damage the intake valves is if the engine ingests something and bangs up the seat, or if they contact the piston(s) and bend, so I'd leave them if it were me.
You can also retrofit the thicker T5 valves by changing to the larger diameter valve guides and stem seals (and the valve seat angle might be different, so you'd have to have the valve seats ground special too), but that's more labor at the cylinder head shop (unless they were already quoting you to press the old guides out and press new ones in).
DrewP is offline
Old 04-02-2014, 01:27 PM   #4
Thank you very much guys for the info. Right now, I'm going to try my best to source a good set of used exhaust valves. If anyone knows of any, please keep me in mind!
rl0089 is offline
Old 04-03-2014, 06:15 AM   #5
Greek Mod
grkguy89's Avatar
hold on you might need to contact JZW
if this is the engine that i think it is it may have T5 valve in it
so if you order the stock valve they will be too small due to the port work and valve job done by JZW
have the valves measured before you order anything
T5 valves are much cheaper
Current Activity: Moderating
grkguy89 is offline
Old 04-03-2014, 07:31 AM   #6
Thank you! I had forgotten to ask the machinist for the measurements of the valves. I was thinking that maybe it had T5 valves from the build but couldn't find anything mentioned in the history of the motor other than they were new, but that would make much more sense! I believe you knew the original owner grkguy (from the for sale thread), the one who was working on the 99 viggen but ended up parting it out. Would there be a way to identify this specific engine if I wanted to contact JZW? Again, I can't thank you enough, especially coming from someone who is learning as he goes and gets most of his help from these forums. The advice and help is invaluable!
rl0089 is offline
Old 04-03-2014, 08:37 AM   #7
One more question, I'll have to get exactly measurements, but should these valves be the ones that came on the turbo 2.3 9000? Thanks again.
rl0089 is offline
Old 04-03-2014, 09:33 AM   #8
Yep, that's a B234 engine. T5 engine management...
Old 04-15-2014, 01:25 PM   #9
Measurements came back as T7 valves so it looks like I'll be in the hunt for some Viggen/Aero valves.
rl0089 is offline
