Possible to get Viggen on Ramps? - The Saab Link Forums
Old 05-04-2006, 05:28 AM   #1
Ice Man's Avatar
Question Possible to get Viggen on Ramps?
I was going to put the Viggen on the Rhino Ramps to do my oil change but the bumper is fucking low it was not possible. Do I have to make custom ramps? Anyone done this?
I ended up using the Saab jack and axle stand for back up. I gave enough room to work with but ramps make it so much easier. Of course the plug was on so tight I had to hit the end of the wrench with a hammer. Rest went ok.
I also loosened the wheel bolts and re-torqued to 85 ft-lbs. Could not find the torque setting in the manual but that is what the 98 900SE manual said for alloys. It's a good thing I did because the lugs were so tight/corroded that I needed to use a 3 foot breaker bar to snap them loose!
Ice Man is offline
Old 05-04-2006, 05:52 AM   #2
WyldSaabMan's Avatar
I cant even used ramps on my lowered 9-3s, couldnt even use them when it was at stock ride height. All though maybe the rhino ramps are lower profile. Either way ramps tend to be a no no with our cars.
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 05-04-2006, 06:07 AM   #3
stevehayes01's Avatar
You can do what I have done with ramps. Jack the car up and put the ramps under it when I have it up and then reverse the process for getting them down. Side note is I did this when i did not have a set of jack stands handy.
stevehayes01 is offline
Old 05-04-2006, 06:27 AM   #4
marky373's Avatar
Send a message via AIM to marky373
What if you add really long boards to the ends of the ramps?
Simply, The Saab
marky373 is offline
Old 05-04-2006, 06:46 AM   #5
Tried that with my stock 9-3 HOT and I still could not get the front lip to go up peacefully.
Old 05-04-2006, 06:53 AM   #6
Trollerator
abdukted1456's Avatar
probably not ramps.
my car has viggen kit and lowered too.
it is soooo low.
HOW LOW IS IT?
the mechanic tried to put the arms for the lift under it and the side skirts were too low, almost touching the ground. he could not get it on the lift without first jacking it up using a floor jack in the front. and so he gos to the front and almost cannot fit the floor jack under the front bumper
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 05-04-2006, 06:54 AM   #7
Trollerator
I am dreading the next time i get an alignment. if they can get it on the rack without damage.
1990 900 turbo vert
2004 9-5 aero sedan
Old 05-04-2006, 07:12 AM   #8
If you look on my cardomain page I was able to use ramps to do my rear sway bar without screwing up the front airdam.
Jameson is offline
Old 05-04-2006, 07:13 AM   #9
backing the car up onto ramps is a lot differnt then pulling it up. The rear bumper has a lot more clearence.
I guess what your saying is, when the back was up on ramps the front didnt touch the ground?
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
Old 05-04-2006, 07:16 AM   #10
Trollerator
that would not work on mine ^^^^
the front would touch if the back got raised much at all
you should see the crazy angles/manouvres i pull to get in and out of parking lots with even mild ramps
viggen bumpers are pimp but not for everyone. you do lose some ease of entry into certain places... but then again when lowered on my SE kit I still had to be careful, just not as careful as now
1990 900 turbo vert
2004 9-5 aero sedan
Old 05-04-2006, 07:32 AM   #11
perkj's Avatar
why not just use jack stands!?!?
2000 Viggen
x-VWer:
perkj is offline
Old 05-04-2006, 08:01 AM   #12
Deez Nutz
Palmer's Avatar
Or,
http://www.griotsgarage.com/catalog.jsp?&SKU=10144
I have these, and they work great!
S55/LC100/KL
Palmer is offline
Old 05-04-2006, 08:23 AM   #13
I have heard people crushing their fog lights trying to use ramps with Viggen front bumper.
nbndtrain is offline
Old 05-04-2006, 08:28 AM   #14
Deez Nutz
Palmer's Avatar
I have done that on my base 9-3. Hence, the ramps.
S55/LC100/KL
Palmer is offline
Old 05-04-2006, 09:28 AM   #15
Ice Man's Avatar
Not many options I guess. I may have to make one out of 2x10's. Or use the jack for now.
In Europe some garages were made with a pit so you walk below the car for service. And cover up with steel plates for safety.
Ice Man is offline
Old 05-04-2006, 10:08 AM   #16
Trollerator
when I wen tto jiffy lube back when i had the old 325e their garage was like that. dude was under the car standing in a cool pit
1990 900 turbo vert
2004 9-5 aero sedan
Old 05-04-2006, 10:28 AM   #17
exactly. So thats encouraging that it can be done with the front for an oil change.
Jameson is offline
Old 05-04-2006, 01:53 PM   #18
I have a thick roll of carpet pad I put in front of the ramps. It lifts the front end enough to clear everything.
Of course, that was on my old non-lowered 94. Not sure how well that would work on a lowered car, but it's worth a shot!
Peregrine is offline
Old 05-04-2006, 01:59 PM   #19
VWSAABVT's Avatar
just use 2x4s and drive up onto them to raise the hieght of the car until you can get onto the ramps. We do this at work when we can't get the lift arms under the sideskirts of cars.
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 05-05-2006, 08:25 AM   #20
dip
dip's Avatar
Send a message via Skype™ to dip
Ramp extentions is the answer. My car is lower than a stock Viggen, and they work just fine front and rear.
dip is offline
