no gas gauge - The Saab Link Forums
Old 03-09-2014, 09:57 AM   #1
no gas gauge
97 900SE talladega vert.
2.0t 5speed 150k.
absolutely no light on on dash everything works properly except the gas gauge. its stuck on empty with the gas light on.
is there any simple fixes to this or if one gauge goes bad do you need to replace the entire cluster.?
Saabkid900T is offline
Old 03-09-2014, 10:49 AM   #2
soccerrplyr's Avatar
could it be an issue with the float arm on the fuel assembly?
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 03-09-2014, 10:52 AM   #3
would there be any way to test that.? could the float just get stuck at the bottom like that.?
Old 03-09-2014, 12:41 PM   #4
Bruce's Avatar
Have you checked for OBD fuel sensor-related fault codes?
P0460 Fuel Level Sensor Circuit Malfunction
P0461 Fuel Level Sensor Circuit Range/Performance
P0462 Fuel level Sensor Circuit Low Input
P0463 Fuel level Sensor Circuit High Input
P0464 Fuel level Sensor Circuit Intermittent
Bruce is offline
Old 03-09-2014, 12:57 PM   #5
turbojohnny's Avatar
It isn't uncommon for a sending unit to go bad
turbojohnny is offline
Old 03-09-2014, 04:21 PM   #6
there are absolutely no codes on the dash cept for the actuall little low gas pump light itself..
could it have a stored code that might be in the computer.?
and in the vert how difficult would it be to change a sender unit.?
Old 03-09-2014, 05:03 PM   #7
srp
srp's Avatar
Send a message via AIM to srp
You have a multimeter? You can ohm out the plug under the rear seat.
srp is offline
Old 03-09-2014, 05:53 PM   #8
To change the sending unit is the same process as changing a fuel pump. You can either drop the fuel tank, or cut a hole in the sheet metal under the seat. Cutting the hole is common practice. I've done it a couple of times.
Old 03-09-2014, 07:21 PM   #9
Bruce's Avatar
The socket for the OBD-II is located below the steering wheel and towards the bottom of the dash. You can buy a reader, but I'd just go to Autozone and have them read the codes for you. I don't believe they generally charge for this service.
Bruce is offline
Old 03-10-2014, 06:52 PM   #10
i lifted up the rear seat and there is a small plastic cover underneath there i would assume that is where the fuel pump is.. now is the sending unit and fuel pump separate or is the sender a part of it.?
and yes i have a code scanner but there are no lights on the dash except for the low gas light. no check engine light at alll.
Old 03-10-2014, 07:55 PM   #11
Stupidly, you can't pull the fuel pump through tht hole. It is offset by a few inches. The fuel pump and sending unit are all in one assembly.
Old 03-11-2014, 05:02 AM   #12
so i need to buy a new fuel pump and that should solve the problem assuming the gauge itself inside the cluster is functional.?
Old 03-11-2014, 06:11 AM   #13
If you haven't replaced your fuel pump yet it wouldn't be a bad idea. But you wouldn't necessarily need to if you can't afford it. I have a couple of spare assemblies with good pumps if you'd rather not buy new. But there's always a chance you just have a bad connection somewhere.
Old 03-11-2014, 07:54 AM   #14
Ditto what turbojohnny said. If you're replacing the sending unit, then you should replace the pump at the same time. You'll need to CAREFULLY cut a flap above the tank to make a hatch. Use tin snips, not a dremel or a cutoff wheel.
